Old 09-17-2013, 04:22 PM   #1
DualDude450 OP
DualDude450's Avatar
Oddometer: 13
Garmin 78 - How do I "link" my tracks together?
I have a Garmin 78. Let's say I have 6 tracks loaded onto the unit. How do I get the tracks to "seamlessly" connect to one another, so I do not have to select them each manually? Thanks!
KTM MXC 550 "Smoker"
Yamaha WR450F "Plated"
DualDude450 is offline   Reply With Quote
Old 09-17-2013, 07:05 PM   #2
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,511
You can't "connect them" on the gps. You can in Basecamp, though, then transfer the track to the gps.
But why connect them anyway? It's not like they'll allow you to navigate.
It's better to just go to the Track Manager and set them to "Show on Map". You'll need to do them all individually.
Old 09-17-2013, 07:24 PM   #3
Countdown
Oddometer: 5,321
If the tracks actually touch, they will be seamless and appear as just one long Track opn the screen. Obviously you must have them all turned on.
What do you mean by "Select" a track? Are you trying to Navagate the Tracks? Very few people do that, they just follow the track at a zoom level of 0.2 or 800
Jerry Counts
Countdown is offline   Reply With Quote
Old 09-18-2013, 08:32 AM   #4
wbbnm
wbbnm's Avatar
Oddometer: 2,050
If you really want to connect them, you can do it in Mapsource or Basecamp.
In Mapsource you can use cut and paste operations.
Basecamp has a track join tool. It is a little tricky to use to the get the tracks in the right order.
I don't know what the track size limits are for the 76. Could be a factor.
I used to do this a lot to get around the 20 track limit on my 60. But not an issue with the Montana.
I have friends who routinely navigate tracks. They like to see the thick purple line. To each his own.
wbbnm is offline   Reply With Quote
Old 09-18-2013, 09:37 AM   #5
Countdown
Oddometer: 5,321
He has 78, not an issue.
Sorry I refered to you and your friends as "very few people".
Have you checked out my final GWT? Found some great single track in ID.
Jerry Counts
Old 09-18-2013, 05:27 PM   #6
wbbnm
wbbnm's Avatar
Oddometer: 2,050
Well it probably is very few. I don't do it. One guy says it helps see the screen without having to put on glasses. So that's a plus.
Haven't downloaded the new GWT stuff. We are riding out of Blanding UT now and I was busy getting ready for this trip.
I'll take a look at the new stuff when I get back home. Idaho is a little outside my range right now and the medium future.
Times are GMT -7.   It's 01:48 PM.
