Old 09-18-2013, 04:20 PM   #1
GoGoGavin41 OP
Isn't this that guy?
GoGoGavin41's Avatar
Oddometer: 830
How Hard is Trials (on the bikes that is)
Trials noob here with a question. Having watched a lot of trials (and pretended to do it on my bicycle haha) how hard is it on the bikes? Seems like there's a lot of suspension bottoming, low psi wheel stomping, thin skid plate crushing stuff going on, even with the professionals. I imagine my purchasing a trials bike would produce a lot of dished wheels and destroyed suspensions.
GoGoGavin41 is online now   Reply With Quote
Old 09-18-2013, 05:02 PM   #2
laser17
Oddometer: 809
Trials riding has one of the cheapest consumables costs of any dirt bike comps that ive been part of. Ridden with reasonable care and proper maintenance, they are pretty bulletproof. That said - if you ride full blast into a rock smashing the bash plate over and over, eventually it will fail and crush in against the cases.
Suspensions and wheels are not that stressed unless you ride at the highest levels. Much better life than say desert racing or enduro riding - mainly due to the lower speeds.
laser17 is offline   Reply With Quote
Old 09-18-2013, 05:30 PM   #3
DerViking
Shred
Oddometer: 339
I have to agree. At least on Gas Gas's the only thing I have had real wear problems with is the rear suspension linkages, and the rear shock. Otherwise, pretty easy keepers. I am about 210lbs with full ride gear on, your wear may very depending on heavier or lighter. Trail riding is particularly hard on things, I usually need to tighten all the linkages after an event like Ute Cup with lots of trail time.
ATGATT: When you fall off your motorcycle, you will be wearing what you were when you got on your motorcycle. Dress accordingly.
DerViking is offline   Reply With Quote
Old 09-18-2013, 05:58 PM   #4
broncobowsher
broncobowsher's Avatar
Oddometer: 1,589
In the lower classes, no real destruction. You just can't get that crazy until you get good enough. And by the time you get good enough you know what you are doing to not just destroy stuff.
Keep in mind that stuff you see on the net is typically the .01% that rarely happens. Here is more typical video http://www.youtube.com/watch?v=NNzfGEvee6U. and this is the upper class stuff. Entry level stuff is even more tame. Expect the biggest destruction to be broken levers from falling.
broncobowsher is offline   Reply With Quote
Old 09-18-2013, 06:46 PM   #5
Johno33772
Johnny Africa
Johno33772's Avatar
Oddometer: 883
Ain't that the truth!
KTM 1190R / XR500 Street tracker project/ KTM 500XCW / KTM 300XCW / Sherco 2.9 / Honda ZA50,Ural Patrol
Johno33772 is offline   Reply With Quote
Old 09-18-2013, 10:12 PM   #6
motobene
Motoing for 44 years
Oddometer: 1,267
Trials is about sustainable. If you are machine aware, and thus kind to your steed, especially.
motobene is offline   Reply With Quote
Times are GMT -7.   It's 02:06 PM.
