Old 09-18-2013, 06:26 PM   #1
sweenrace OP
Oddometer: 65
Tight turn on steep hill... How?
At the bear valley trial at the weekend there was one section which required a very tight turn (close to full lock) on a steep decline. I never got it clean and resorted to a dab and a floater turn over the gate (it wasn't nearly as elegant as that sounds!)
At the "bottom" of the hill Leaning the bike into the hill and applying lock felt like it was going to drive the bike into the ground and fold the wheel under the bike (going past full lock). In hindsight maybe I should have done the opposite and leaned the bike out (and me in) to have the bike closer to perpendicular to the terrain.
I'm kinda flummoxed (yes, that's a technical term) as to how to successfully navigate that type of turn. Thoughts?
Ian
sweenrace is offline   Reply With Quote
Old 09-18-2013, 06:39 PM   #2
thegraydog
2 wheels X 6 ways
thegraydog's Avatar
Oddometer: 664
You have identified the essence of trials.
I'll be interested to read other replies. But in fact, this is the essence of trials.
thegraydog is offline   Reply With Quote
Old 09-18-2013, 09:05 PM   #3
motobene
Motoing for 44 years
Oddometer: 1,412
Don't lean the bike out. It's more about where your body is and what it is doing, when.
If you are turning going down hill, that means transitioning out of down hill to level or going back up hill from a descent? Technique-wise, you'll likely trail the needed transition of body centering to more forward. Everybody does this until they learn to transition the outside weight bias more to the front wheel earlier.
You'll need to counterbalance to the outside of course (I'll have to assume you know how to center no matter hat the incline/decline), but it can be counter-intuitive - and critical - to swing your body center of mass out and forward to anticipate the coming turn/transition. If you don't, you'll get 'behind' the bike and push right through the turn and into oversteer.
Assuming you have the right body technique, or despite that, if you are folding the front end under a lot, your bike pitch/attitude may be biased toward over steer. That is, butt high and front end low. Try lowering the fork to fork caps level with the top of the triple clamp, and if that does not calm the steering, back off on shock preload. At least experiment, as you can always reverse the changes.
Hope this makes sense because the simple thing you are asking has a very complex answer
motobene screwed with this post 09-20-2013 at 06:33 AM
motobene is offline   Reply With Quote
Old 09-20-2013, 05:15 AM   #4
Gordy
Team Listo
Gordy's Avatar
Oddometer: 22,757
It is indeed complex, and hard.
All I can offer is;
Be patient through the transition.
Get your weight correct (centered over the contact patch)
Try to get all weight off the bars and onto the pegs.
Your weight on the pegs should be about the same as if you were standing on the hill with no bike.
Try (like we all are) to become a Jedi with the clutch control.
Great, like GreyDog said, we are describing trials!
Gordy is offline   Reply With Quote
Old 09-20-2013, 05:45 AM   #5
laser17
Oddometer: 858
What the others said. Also try and look up the hill as soon as you can. Its amazing to me how often I improve my score just by looking up! The corollary to this is don't stare at your front tire. (I tend to find mine way too fascinating on steep off cambers)
laser17 is offline   Reply With Quote
Old 09-20-2013, 06:14 AM   #6
AirforceGSRider244
Hardcore adventurer
Oddometer: 91
you need to COUNTER balance. you need to put weight on outside of turn on the pegs. especially leaning on an offroad track. you counter balance offroad. counter steer on a road. look up rawhide adventures offroad BMW. itll help ALOT!!!!
http://www.rawhyde-offroad.com/
So if your turning left your weight will be on the right peg as your leaning into turn. you should be able to go in a circle slowly through like your yard or something with both legs on one side. so turn left circle with weight on right side. and vise versa. youll see how it works. itll blow your mind if youve never done it before that is the best and most efficient way to understand the physics of counter balance .
You always think your in control of your bike no matter how fast your going....
Until that split second that your not. and then its all over from there. one second is the difference between life and death.
There are 2 types of riders. those whove crashed and those who havent crashed yet
AirforceGSRider244 screwed with this post 09-20-2013 at 06:25 AM
AirforceGSRider244 is offline   Reply With Quote
Old 09-20-2013, 06:20 AM   #7
AirforceGSRider244
Hardcore adventurer
Oddometer: 91
to further add to this, if you stare at the object your trying to avoid instead of looking ahead it not only reduces your reactionary time but your gonna driving into the things your staring at and trying to avoid. look ahead at what your going to need to avoid. not constantly what you need to avoid at that specific spot your in.
Old 09-20-2013, 07:03 AM   #8
Sting32
Trials Evangelist
Oddometer: 1,387
Ian
How do you handle Hard tight turns on FLAT ground? I ask, because that could be the "basic" skill that has a weakness is exposed on this example, were we're adding to the basic skill, with the example you have asked. Other problem is we're all having to "imagine" in our minds, hoping I see what you saw, sort of. Hope I am close.
SO you come down a steep hill, and have to make a tight right or left hand turn. One of the Biggest difference in technique really "about the TURN" is that your weight is back on the bike, and you are braking hard, unlike flat ground. THe other is a turning technique where you dont throw your shoulder as I call it, with the bars. Most turns you want your shoulders to follow the bars, inside arm is straight, the outside elbow is bent, this keeps your weight counter balancing the bike lean... downhill turns can be handled easier by what I call limp shoulder, or just turning the bars, keeping your torso still, this means your arms try to allow the bike/bars turn, while YOUR FEET do all the balancing.
What I have had to do in the past, and I continue to do, is when I find something that challenged me, I challenge the hell out of it in "practice". I make myself a section or part of a section so I can play on it.
More about me guessing what you have to do to make that turn...
The bike, IMHO, you have to be able to balance at a dead stop on this hill, that is good practice. then you make your tight turn, your knees mush be bent flexible, lower your center of gravity all you can, you MUST do it a little by squatting, knees out. Downhills, I turn the bars without throwing my shoulders out over the bars unlike flat grounds, and uphill turns, it is a different turning technique.
Most of us riders, are paranoid of "high siding" the bike, falling over the bike down the hill, which is that survivor instinct, you have to work against that, practice helps. Not making your shoulders match the angle of the handlbars, like we usually do on normal turns, helps you keep your balance downhill and keeps you from "vertigo" feeling as you turn... We need a video, as I cannot use enough decriptive words for me to make any sense (as you can probably see by now, reading what I have typed so far).
Confidence allows you to move in ways you wont normally allow yourself to do, this is why RAGA, BOU and everyone that is FANTASTIC in trials, have the ability to do what they do, it is confidence, which comes from practicing and pushing your envelope.
Sting32 is offline   Reply With Quote
Old 09-20-2013, 07:53 AM   #9
motobene
Oddometer: 1,412
Righto about this problem. The less skilled the inquirer is, the harder it is to understand text about technique complexities. I wondered if anyone could follow what I said earlier about not getting 'behind' the timing of the bike? You said about the same but with more detail.
I like your descriptions of various relaxed-or-follow shoulder techniques. I'll be checking them out next ride.
Old 09-20-2013, 01:33 PM   #10
sweenrace OP
Oddometer: 65
Thanks everyone. This is very helpful. Firstly the scenario was as people assumed, down a gradient, a u-turn on that gradient and back up the hill through a gate.
A couple of things I've realised in reading the responses and digesting things. - - My basic turns on flat are pretty good but just not tight enough.
- I'm realising there is a lot more work to be done around counter-balancing. For example, I am nowhere near understanding where my shoulders should be relative to the bars.
- I'm definitely using the bars rather than the pegs to balance which I need to work on.
More practice is in order!
Old 09-20-2013, 01:40 PM   #11
lineaway
Oddometer: 2,874
Flummoxed of a turn or obstacle is the why of trials. Gotta love that! Not all turns are cleanable by mere mortals. Was anyone getting through it?
All turns are accomplished with the same technique. And not all riders use the right way to the light. Turns are made with peg pressure. Left to go left. Right to go right. Weight is not on the outside. Weight is on the inside peg. It looks like the weight is on the outside peg if using proper form. But the turn is made with pressure on the peg.
And yes a hard off camber turn can result in the front end doing things not intended. Over exaggerate every turn you make and it will more natural when needed. (been telling my kid this for years and he still rides legs locked straight up) Conquer turning and the obstacles become smaller.
Just as you get that turn figured out, some kid will do a long nose wheelie down the hill into a regular wheelie and float right through. So much for technique.
Good luck.
lineaway is offline   Reply With Quote
Old 09-21-2013, 04:17 AM   #12
Twin-shocker
Oddometer: 1,673
Very very easy to practice figure 8 turns full lock, on flat ground. When that comes easily try the same thing on a hillside.............without having mastered the basics, its very difficult to come to terms with anything more difficult.
Old 09-21-2013, 06:29 AM   #13
motobene
Oddometer: 1,412
General rules that will help you immensely:
- Shoulders should follow the bars as the turn. They should be relaxed and not strained and not as a result of bug eyes and body twist from dead legs and ass frozen over the center of the bike. Ass should flow out from bent legs (a squat) so the torso will allow the shoulders to follow bar angle. Otherwise you WILL arm turn, which is a really bad habit and is exhausting. Much of the time, your hands should be relaxed with some down pressure on the palms, and you arms should be more like cables attaching shoulders to bars. Ass and shoulders really work together. If you fail to move one or the other, the other is constrained. When you move your ass out to counterbalance a lean into a turn, it ALLOWS your shoulders to follow the bars. When you have shoulders following bars it allows your ass to move out. The legs should not be hugging the frame or straight. Feet should be out some on the pegs and legs in at least a moderate squat. Otherwise you ass will be locked to centered over the bike and the whole series of fluid movements are constrained.
- Quick arm movements are for balance and small correction in your line. the shoulders and peg pressure are too slow for micro corrections. for example, rolling over rocks which will push you off balance continually. Quick arm movements are also how you balance in place when you have good front wheel bike
- Initiate turns with peg pressure. Right for right turn, etc. Once the turn is initiated, you can go back to more even peg pressure and provide yourself the solid base to do what I suggested earlier:
- As you go around the apex of the turn at the bottom, you should be counterbalanced such that you can stop anywhere and not fall to the inside. This is your static balance. Now here's where it gets tricky:
- Aspects regarding dynamic balance. Do not get behind the bike in turns that require the change in position of body center of mass to lead the initiation of the turn: transitioning from steep downhill back to uphill. From your base static balance squat, as you pass the apex of the turn you must add a dynamic element of moving your body mass perhaps a bit more out and definitely more forward. It's a slow motion sling that results in you going back up hill sticking instead of blowing the turn. Your upper chest will end up out and up over the number plate, with your outside elbow in more of a bend than the inside. It'll feel like you are having to initiate the slinging of body mass before it's required, but it's right. If you keep your weight back at and beyond the apex you will blow the turn.
KrazyOSU is learning this. Any comments on this, Krazy. He can't answer. He's on his way out to the ranch right now to ride
motobene screwed with this post 09-21-2013 at 06:43 AM
Old 09-22-2013, 10:09 AM   #14
KrAzyOSUcOwBoY
kRaZy
Oddometer: 126
Really enjoyed the ride yesterday. Amazing how superior direct individual instruction is to written explanations. Also, I'm not a fan of big hill climbs as is 'bene, but with the practice I'm becoming much more confident. If you get the chance, you should visit the Buffalo Dream Ranch and ride his excellent natural trials terrain. I am sooo grateful to have such a fantastic friend and teacher. Many thanks, can't wait to head off to the Flint Hills CRTA 2-day.
KrAzyOSUcOwBoY is offline   Reply With Quote
Old 09-22-2013, 09:42 PM   #15
Undertheoaks
Undertheoaks's Avatar
Oddometer: 56
Ian
Where do you practice ? Im in El Sobrante and always looking for new people to ride with. Also a member of PITS but missed last weeks event. I have a few local practice spots always room for more. Sid,
Undertheoaks is offline   Reply With Quote
Times are GMT -7.   It's 04:00 AM.
