Old 09-21-2013, 05:28 PM   #1
BEEF706 OP
King of the dumb dab
BEEF706's Avatar
Oddometer: 746
Pissed OMG help the noob
So, I recently bought a 2004 Beta Rev 3. Being me, I had to clean it. It has always been hard to start, and today I had a really hard time. It seems to catch for a second, then wont start at all. also if I kick it, there was gas coming out of the overflows. I pulled the plug, black as night, and put a new one in, nada. I though it might be crud in the jets or something, so I pulled the carb off, ran guitar string wire through the jest, cleaned out the bottom and put it back on. NOW, when I turned on the gas, the gas was flowing out of this tube:
the floats seemed to be moving OK, but something is wrong I a supposed to ride tomorrow, and have really been looking forward to it, andy help?
NMOHVA Member NMTA Member
04 Beta Rev3 270, 92 Yamaha Wr200,
BEEF706 screwed with this post 09-29-2013 at 05:13 PM Reason: Add emoticon
BEEF706 is offline   Reply With Quote
Old 09-21-2013, 06:03 PM   #2
NMTrailboss
Team Dead End
NMTrailboss's Avatar
Oddometer: 6,375
If you're talking about that clear(ish) tube, that is the vent hose. If fuel is getting that high, then the float is most likely sticking open. There may be a piece of debris between the float needle and seat keeping it open. Inspect the float for free movement and make sure the needle and seat are clean. With the float bowl off, hook the carb. to the fuel inlet hose (or an aux. bottle) and turn the fuel valve on. When fuel starts flowing through the float valve, slowly lift the float up and see if the fuel shuts off when the needle contacts the seat. If so, you should have resolved that problem. May as well check float height while there. Also, if fuel has been flowing due to a stuck float, the engine may have filled with fuel as well. Might need to remove the spark plug and kick the engine through to make sure there is no fuel in the bottom end (keep the spark plug and cap away from the hole while doing this!!!!).
Yet another good reason to have two trials bikes!
NMTrailboss is offline   Reply With Quote
Old 09-21-2013, 07:16 PM   #3
Gordy
Team Listo
Gordy's Avatar
Oddometer: 23,041
Deb recently flooded her Sherco so bad that the crankcase filled up and the exhaust was full of gas!!
I had to pull the plug, turned it upside down and blew compressed air into the plug hole to get it dry enough to start.
Like NMTB said you probably got some dirt under the float needle. Usually when that happens, by the time you get in there to check it out, it has flushed itself out.
I just love working on bikes the night before a ride! .
Gordy is online now   Reply With Quote
Old 09-21-2013, 07:18 PM   #4
BEEF706 OP
BEEF706's Avatar
Oddometer: 746
THANKS Curtis, you are the Jedi master The floats must have been stuck when i put em back together, now back to my regular business, falling over slowly.
Old 09-21-2013, 07:27 PM   #5
BEEF706 OP
BEEF706's Avatar
Oddometer: 746
I didi that to my DRZ when the petcock failed, that was and adventure, I guess I just don't have enough stress in my life You feeling well enough to go?
Old 09-21-2013, 07:30 PM   #6
Gordy
Team Listo
Gordy's Avatar
Oddometer: 23,041
I'm loaded up and will just see how I feel in the morning. I hope so!!
Old 09-21-2013, 07:51 PM   #7
BEEF706 OP
BEEF706's Avatar
Oddometer: 746
Hope to see ya there
Old 09-21-2013, 08:00 PM   #8
NMTrailboss
Team Dead End
Oddometer: 6,375
Did you get her started?
Old 09-21-2013, 08:27 PM   #9
BEEF706 OP
BEEF706's Avatar
Oddometer: 746
Got her started and rode around my back yard loop in the dark, I am not a smart man. So I'm in with my sexy Italian tomorrow.
Old 09-21-2013, 08:39 PM   #10
NMTrailboss
Team Dead End
Oddometer: 6,375
Old 09-21-2013, 09:19 PM   #11
lineaway
Oddometer: 3,098
The Beta mikuni`s are hexed. Put a small V cut high on both vent tubes or they act like a vacuum and drain the carb.
lineaway is offline   Reply With Quote
Old 09-21-2013, 09:21 PM   #12
lineaway
Oddometer: 3,098
PS. You have to turn off the gas always or she will flood. Did you notice what jets are in it. It was a Butler bike.
Old 09-21-2013, 09:41 PM   #13
BEEF706 OP
BEEF706's Avatar
Oddometer: 746
I turn the tap off religeously since the DRZ incident, I didnt notice the jets, do you have recommendations? I will get some brass and re-jet.
Old 09-21-2013, 09:49 PM   #14
lineaway
Oddometer: 3,098
Roswell 140 main, 30 pilot. San Ysidro 135, 30 pilot, Sipapu 130 main 30 pilot. Some bikes even need a 35 pilot. 145-150main at sea level.
Old 09-21-2013, 10:08 PM   #15
BEEF706 OP
BEEF706's Avatar
Oddometer: 746
thanks Bob, I will look later and get some jets to have a range.
Times are GMT -7.   It's 03:35 PM.
