Old 09-22-2013, 12:36 AM   #16
Twin-shocker
Oddometer: 1,673
Mikuni carbs on Beta tend to vent fuel through the atmo tube, due to the angle the carb is mounted, and if the fuel is left switched on, this can drain all the fuel from tank. There is a relatively simple modification that was done back in the day to cure this, which relocates the atmo vent internally, which means no more problems.
Old 09-22-2013, 05:20 AM   #17
Gordy
Team Listo
Gordy's Avatar
Oddometer: 23,042
We are supposed to re-jet?
Gordy is online now   Reply With Quote
Old 09-22-2013, 06:26 AM   #18
lineaway
Oddometer: 3,098
http://www.trialscentral.com/forums/...3-mikuni-carb/
This is the third version of the beta carb fix. which says to buy a new carb. The first version is the Billy T. fix which involved a float height and vent tube fix. The one twinshocker states involved drilling two holes inside the carb body and adding a cross over pipe.
This could take days to read if you have the time, or put the v- cut up high and I can help set the floats if you are still having problems.
lineaway is offline   Reply With Quote
Old 09-22-2013, 06:36 AM   #19
joe cool
joe cool's Avatar
Oddometer: 976
Also when you park the bike try to keep the front wheel higher than the rear to stop the bike from flooding. I now run a dellorto carb on my 05 Rev. which works much better.
"One more day I find myself alive
Tomorrow maybe go beneath the ground"
Garcia/Hunter
joe cool is offline   Reply With Quote
Old 09-22-2013, 02:38 PM   #20
Twin-shocker
Oddometer: 1,673
The only real cure for the Beta Mik carb flooding problem is relocating where the atmo tube intake is inside the carb body. As the carb is mounted at an angle, the position of the intake needs to be moved to stop fuel self siphoning through the atmo tube. Used to be details of how to do this on the net, but cant find them now. Was pretty easy to do though, and involved a small drill and blocking the old intake with epoxy (cant remember exact details though, as not done one for a long while).
Old 09-22-2013, 02:50 PM   #21
BEEF706 OP
King of the dumb dab
BEEF706's Avatar
Oddometer: 746
The nature of the problem was mine, when I put the carb back together the first time last night, I did it with the carb upside-down. The floats then got hung up, and the mayhem ensued. I had no issues today, (not with the carb anyway ) and was careful to turn off the tap when I stopped for a while (several times). Thanks to all that responded, I had a great day out (up until I punctured the front). The impressions of a noob, I can balance the Beta better than the Gasgas, I was able to balance a lot longer using a side to side motion of the front wheel (just like Ryan Young's video), I can turn tighter on it, and a still get brain fade the minute we set up a section
NMOHVA Member NMTA Member
04 Beta Rev3 270, 92 Yamaha Wr200,
BEEF706 is offline   Reply With Quote
Old 09-22-2013, 02:55 PM   #22
lineaway
Oddometer: 3,098
So the road in was not washed away?
Old 09-22-2013, 03:05 PM   #23
BEEF706 OP
BEEF706's Avatar
Oddometer: 746
The middle section was rougher, and the bottom is really sandy, but even my girly man rig made it no problem.
Old 09-22-2013, 06:39 PM   #24
NMTrailboss
Team Dead End
NMTrailboss's Avatar
Oddometer: 6,375
Road is fine Bob. As Larry said, it is pretty sandy at the bottom from the water running down it, but otherwise normal. Many of the arroyo's at SY have had a ton of water through them and still have a lot of standing water and some mud, but it is totally rideable and in good shape...and green!!
NMTrailboss is offline   Reply With Quote
Old 09-22-2013, 07:04 PM   #25
lineaway
Oddometer: 3,098
Great, will try to get out next weekend!
Old 09-23-2013, 07:30 PM   #26
BEEF706 OP
BEEF706's Avatar
Oddometer: 746
As a follow up, I changed the tranny oil, and it was a little dirty, but not milky at all, so no water pump leak, and i changed the tube on the front, so the noob is back in business
Old 09-23-2013, 08:39 PM   #27
AteamNM
Wonna Be ADVrider
AteamNM's Avatar
Oddometer: 3,995
Huba huba Prof. Larry. Lovin' your progression.
Thread - Confessions of a newb trials rider. Start form the beginning because this is gonna get good.
Subsribed.
AteamNM is offline   Reply With Quote
Old 09-23-2013, 08:39 PM   #28
NMTrailboss
Team Dead End
Oddometer: 6,375
Originally Posted by BEEF706 View Post
...the noob is back in business
Old 09-28-2013, 03:34 PM   #29
BEEF706 OP
BEEF706's Avatar
Oddometer: 746
All dressed up..
So I went on a cleaning binge on the Beta,
As I did i found a couple of more things, this bolt was missing:
and i needed to straighten the chain guid out.
and now she's ready to get dirty @ SanYo tomorrow
Old 09-28-2013, 06:03 PM   #30
Brewtus
Buffoonery, Inc.
Brewtus's Avatar
Oddometer: 3,164
So I went on a cleaning binge on the Beta....
It's an ex-Butler bike. Keep going, you're not done yet.
Work hard. Play hard.
Team Dead End. The drinking team with a Trials problem.
2-Time winner of the coveted "Best Shenanigans" award at Capt. Rick's annual BBQ.
Brewtus screwed with this post 09-28-2013 at 06:03 PM Reason: Ex or ex! I'm no Eexpert......
Brewtus is offline   Reply With Quote
Times are GMT -7.   It's 04:19 PM.
