Old 10-01-2013, 03:49 AM   #16
gsweave OP
Yinz, blinkers are on.
Oddometer: 11,470
Originally Posted by Crisis management View Post
I'm assuming a step in the foundation but given it's a level site I wonder too?
Yes,
Foundation steps 5 total. Not as level a spot as it appears.
1Paul 2:15
For it is God's will that by doing good you should silence the ignorant talk of foolish men. 16 Live as free men, but do not use your freedom as a cover-up for evil;... .
gsweave is offline   Reply With Quote
Old 10-01-2013, 06:46 AM   #17
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,650
When's the party?
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 10-01-2013, 07:45 AM   #18
RhinoVonHawkrider
RhinoVonHawkrider's Avatar
Oddometer: 1,481
Originally Posted by sailah View Post
When's the party?
Need to smash some bottles on the new floor. I asked ur new neighbor to help clean up - he said no problem.
FREE Discount Prescriptions http://hta270hs.supremerxsavings.com/
AVO - R.I.P. - "When you don't have goals, you can't fail" - Neil Fallon
"He said, Son, remember where U came From" - LOA
Until the colour of a man's skin - Is of no more significance than the colour of his eyes -Me say war RNM
RhinoVonHawkrider is offline   Reply With Quote
Old 10-01-2013, 11:33 AM   #19
tyrsmkkyle
off the ground.
Oddometer: 250
I too am watching this with excitement.
tyrsmkkyle is offline   Reply With Quote
Old 10-01-2013, 02:05 PM   #20
Crisis management
Latte riders FTW!
Crisis management's Avatar
Oddometer: 1,473
Right, I went back and had another look at the pics, should have done that first!
I have a couple of questions, mainly because I design houses for a living but remember I've never been to Appalachia and don't even live in the same hemisphere....
The ground looks like a natural gully to me, a dip between two higher points, do you have to be concerned with water running through there? Here that would be treated with a sub soil drain around the perimeter to ensure any water was drained away from the foundation, do you have similar concerns there?
What's the climate like, hot , snow, wet? and what do you have to do to the garage (insulation) to make it comfortable enough to work in rather than just for storage?
Why do you have to post the permit signage?
Orange...cause it makes me look like I know what I'm doing!
Crisis management is offline   Reply With Quote
Old 10-01-2013, 06:36 PM   #21
gsweave OP
Oddometer: 11,470
Natural drainage path...
Will handle surface runoff with one collector which is located at upper edge of property. In the before picture you may note the slightly exposed 8" terra cotta pipe which handled the runoff before. I will tie into it with 8" flex and run around front side of foundation. In addition I will run a French (perimeter drain with 4" PVC around the entire foundation.
Pennsylvania is the location... see climate link http://www.bestplaces.net/climate/ci...nia/pittsburgh
snowy 7 months out of the year.
Walls will be R19 batts, ceiling will be about R45 batting Dry wall layer over.
Heat source will be hydronic in floor system electric boiler...Holding 60-65 degrees F.
Permit is township requirement revenue/zoning/code compliance...Yes must be posted http://www.peterstownship.com/index....3223C43BF5E%7D
1Paul 2:15
Old 10-02-2013, 06:49 AM   #22
trailer Rails
trailer Rails's Avatar
Oddometer: 3,825
A local
7 months of winter? Not recently.
trailer Rails is offline   Reply With Quote
Old 10-02-2013, 10:14 AM   #23
Laconic
Anodyne
Laconic's Avatar
Oddometer: 17,508
Glad to see you getting started, looking forward to seeing you succeed!
Laconic is offline   Reply With Quote
Old 10-02-2013, 02:17 PM   #24
gsweave OP
Oddometer: 11,470
Originally Posted by trailer Rails View Post
A local
Been since the 70's
Still lots of cloudy days
1Paul 2:15
Old 10-02-2013, 02:28 PM   #25
gsweave OP
Oddometer: 11,470
It's a far cry from a May start Rick but it sure is drier now, you kids stay out of trouble this weekend, I Really really wanted to make Hot Springs.
Last night had to buy a s40 6" PVC pipe. Needed 12" section for sewer cut out. Damn things are almost 70 bucks for 10' hunk
So I laid out cut outs for city water Natural Gas, cistern water line and sewer.
Also had to run a 10' 3/4" copper, city water line out to a new hose bib for the block layer. another 8 leak free joints
Thought block was arriving today....guess not.
1Paul 2:15
Old 10-03-2013, 03:57 AM   #26
Laconic
Anodyne
Laconic's Avatar
Oddometer: 17,508
Well, it's just me, but I think getting the garage dried-in before the snow flies probably takes precedence over hanging out with a buncha Morans. Though not by much...
I had no idea plastic was so expensive.
Sounds like you're having heat and a bathroom?
Old 10-03-2013, 04:31 AM   #27
madeouttaglass
The AntiHarley
madeouttaglass's Avatar
Location: California bound but stuck in NY for a few months
Oddometer: 3,511
What are you using to insulate under and around the edges of the slab? Our local dumb fucks at our highway garage did it themselves without any insulation. My tax dollars now pay to heat the parking area around the garage with all the escaped heat, not to mention they installed overhead FA heaters later.
Our ride across the USA on a Ural Gear Up- http://www.advrider.com/forums/showthread.php?t=781149
Escape from NY- http://advrider.com/forums/showthread.php?t=955520
madeouttaglass is offline   Reply With Quote
Old 10-03-2013, 06:09 AM   #28
Laconic
Anodyne
Laconic's Avatar
Oddometer: 17,508
Closed cell spray foam might work great, insulation and vapor barrier all in one.
Old 10-03-2013, 06:57 AM   #29
madeouttaglass
The AntiHarley
Oddometer: 3,511
I used closed cell spray foam on the inside of the stone walls of our lodge. More to the the topic though, under the basement floor I used a version of this:
http://www.coler.com/lowe.asp
The below grade version has the aluminum sandwiched between the two layers of plastic. The basement area of the lodge is now the most comfortable below grade space I've ever been in. No heat loss or moisture issues which were a huge problem prior to this.
Old 10-03-2013, 07:11 AM   #30
Laconic
Anodyne
Laconic's Avatar
Oddometer: 17,508
What is the theory behind the aluminum in the under-slab installation?
Times are GMT -7.   It's 02:15 AM.
