Old 10-03-2013, 08:38 AM   #31
madeouttaglass
The AntiHarley
madeouttaglass's Avatar
Location: California bound but stuck in NY for a few months
Oddometer: 3,478
radiant barrier. I thought it was BS until I did some research. It really doesn't add much of anything to cost anyway. I also used it above the spray foam on my roof deck of the lodge before putting down my metal roof. (http://skylodgevacation.com/ecofriendly.html) Unlike my 27 year old home without anything under the slab, the entire old place uses an amazingly small amount of propane each year. I heat the basement at home and it is still cool and damp. The lodge is not heated down there yet the basement is dry and warm just from the small amount of radiant heat coming off the pex lines that go to the baseboards upstairs. Insulation certainly pays for itself and there is only one time to do it unlike cheap heating units that can easily be replaced.
Our ride across the USA on a Ural Gear Up- http://www.advrider.com/forums/showthread.php?t=781149
Escape from NY- http://advrider.com/forums/showthread.php?t=955520
madeouttaglass is offline   Reply With Quote
Old 10-03-2013, 03:50 PM   #32
gsweave OP
Yinz, blinkers are on.
Oddometer: 11,440
Originally Posted by madeouttaglass View Post
What are you using to insulate under and around the edges of the slab? Our local dumb fucks at our highway garage did it themselves without any insulation. My tax dollars now pay to heat the parking area around the garage with all the escaped heat, not to mention they installed overhead FA heaters later.
right now thinking 1" blue or pink board (looking for well priced 2" or 3" foam board) taped sealed seams then overlay that with layer of ....
54 - Low-E Reflective Foil Insulation
Low-E foil insulation is extremely easy to install and has numerous residential, commercial and recreational applications.
It's thermal resistance, water vapor retarding, wind infiltration barrier, pipe and duct wrap properties mean that Low E insulation can be used in various applications where traditional insulation is not practical. While the Slab Shield "Under Concrete Insulation" has the foil insulation in between two bubble foam layers. This protects the foil from the concrete or water - which in both cases - will eat away the foil if not protected.
Yes block will also carry exterior and interior foam board insulation
6761 - Slab Shield Layout Example
Slab Shield Layout Example. This example shows a typical slab shield application.
This is only an example. Actual layouts vary from job to job
1Paul 2:15
For it is God's will that by doing good you should silence the ignorant talk of foolish men. 16 Live as free men, but do not use your freedom as a cover-up for evil;... .
gsweave screwed with this post 10-03-2013 at 05:17 PM
gsweave is offline   Reply With Quote
Old 10-03-2013, 04:48 PM   #33
gsweave OP
Oddometer: 11,440
Block sand and mortar arrived today.
10" block
Guess Block Layer will begin Friday
1Paul 2:15
Old 10-03-2013, 05:36 PM   #34
snowman318
Future Corpse
snowman318's Avatar
Oddometer: 1,133
Dan we put this under most heated floors we pour.
Vapor barrier & insulation in 3/8 inch.
But use rigid on all vertical walls.
This bubblewrap's r-value is bad that way.
Just wondering, why 10" block? Kinda an odd size, nothing wrong with it.
24 beers in a case,24 hours in a day
coincidence?
AMA-PaTRA-PAOHVA-- PA-ABATE-Blue Comet MC http://www.polarbeargrandtour.com/index.htm
http://advrider.com/forums/showthread.php?t=674788
http://sevenmountainsconservationcorp.com/
snowman318 is offline   Reply With Quote
Old 10-03-2013, 05:51 PM   #35
gsweave OP
Oddometer: 11,440
Easier to lug around compared to twelves
Looking at two of the walls as possible pressure walls. One from potential water, the other from interior fill. Only real reason for 10's over eights.
That vap barrier bubble wrap looks just like the low E, I plan on placing over the ridged foam, under slab should give me about r15 against ground and direct heat into slab only
1Paul 2:15
gsweave screwed with this post 10-03-2013 at 06:08 PM
Old 10-03-2013, 07:09 PM   #36
snowman318
Future Corpse
snowman318's Avatar
Oddometer: 1,133
Glad you thought things out.
Just remember under the slab:
Any electric,water, air lines, things you might need in the future.
My compressor is in another building, so I ran a line under the floor to feed air(no noise)
And wire to switch it.
Floor drains are going away because of possible oil/gas leaks.YMMV
coincidence?
Old 10-04-2013, 04:50 AM   #37
gsweave OP
Oddometer: 11,440
That's what I thought but township engineer kinda insisted on em.
No block layin till MONDAY
1Paul 2:15
gsweave screwed with this post 10-04-2013 at 10:14 AM
Old 10-04-2013, 10:51 AM   #38
tommu56
tommu56's Avatar
Oddometer: 1,337
radiant heat
Here is a thread were they put pex in the floor IIRC.
http://advrider.com/forums/showthread.php?t=800260
tommu56 is offline   Reply With Quote
Old 10-06-2013, 04:11 AM   #39
Patriot4570
Trail Blaster
Patriot4570's Avatar
Oddometer: 2,742
Good thread .What is the plan for the electrical?I would pipe with emt if it is going to be concrete walls.Looks like you are on the way to a great looking garage.
I've learned that pleasing everyone is impossible, but pissing everybody off is a piece of cake.
Patriot4570 is offline   Reply With Quote
Old 10-06-2013, 05:57 AM   #40
9Dave
Bazinga!
9Dave's Avatar
Oddometer: 12,940
Congratulations on getting your project started. You can never have too much space.
And if that neighbor gets too pesky, just invite some of your adventure friends over for a little party.
dunno.....
Old 10-06-2013, 11:30 AM   #41
gsweave OP
Oddometer: 11,440
Hmmm.
Block will only be two to three coarse outta ground. 2x6 stick framing over to give me about 10'6" ceiling.
I am torn on conduit.
Like clean industrial look but also nice to have wall plugs flush....
May just put all 12 3 wire in studs.
run all 240 in conduit runs.
need 240 to
boiler
compressor
welder.
Only 100amp service. remote sub panel from house.
That's still a ways away
1Paul 2:15
Old 10-06-2013, 12:39 PM   #42
Crisis management
Latte riders FTW!
Crisis management's Avatar
Oddometer: 1,455
Been away from the computer for a day or two (been busy crashing dirt bikes) so apologies for the late reply, thanks for the info on the area and local ordinances. There are a few things we could learn from you guys, I like the idea of posting the permit, that's good for keeping the neighbourhood involved.
Lots of other good info here and again it's different in so many small ways from our methodology, for example you measure your insulation differently too us, it's a factor of 10 greater (in measurement, not performance) than our ratings.
The garage sounds like a great space, I'm decidedly envious of that much area, hope your blocks get laid today (it's monday here already).
Orange...cause it makes me look like I know what I'm doing!
Crisis management is offline   Reply With Quote
Old 10-06-2013, 02:18 PM   #43
gsweave OP
Oddometer: 11,440
Whatever the space, it won't be big enough.... I have heard this cry from everyone who has built before
Looks like heavy rain overnight and into Monday so I don't have high hopes on block work.
The permits vary. Not sure they keep you involved as much as responsible in following proper construction practice.
Required inspection times are
1 footer
2 framing
3 plumbing prior to cover
4 final
5 Electricial must be done using an 3rd party inspector. All wiring must follow NEC code http://www.nfpa.org/codes-and-standa...e=code&code=70
here's 1000 pages to make your head spin
1Paul 2:15
Old 10-08-2013, 04:14 PM   #44
gsweave OP
Oddometer: 11,440
Weather is nice and sunny again.
Marty came out and started the block all lookin good.
[URL=http://s1164.photobucket.com/user/1150gsgsweave/media/P6190018-1.jpg.html][IMG]
1Paul 2:15
Old 10-10-2013, 05:17 PM   #45
gsweave OP
Oddometer: 11,440
Block is almost finished....
Perimeter drain start.
1Paul 2:15
Times are GMT -7.   It's 03:47 PM.
