Old 10-02-2013, 02:08 PM   #1
sallydog OP
AVERAGE 78.1 MPD
sallydog's Avatar
Oddometer: 5,652
need help with remote fuel tank
i have this tank on my tenere. the fuel pump is in the tank.
i have this remote tank, i can get the hose for it
anyone know how i can pipe this all together?
Its not who dies with the most toys.. Its who wears out the most toys
Just dip me in beer and toss me in the drunk chicks.
if you havent grown up by age 50 you dont have to
Heaven's the place where all the dogs you've ever loved come to greet you
sallydog is offline   Reply With Quote
Old 10-02-2013, 02:20 PM   #2
Kaw4Life
Busted Adventurer
Kaw4Life's Avatar
Oddometer: 6,740
Would love to help but I am electrical smart, talk to MikeWillSmith.
Kaw4Life is online now   Reply With Quote
Old 10-02-2013, 02:30 PM   #3
DRjoe
DRjoe's Avatar
Oddometer: 5,211
That's a merc oil tank.
First thing I'd do is fill it with petrol and leave it for a week or so to see what components can and can't handle the fuel.
After you've proved it will work it might easiest to find the correct fitting for it.
On the fitting one barb is in and one is out so maybe look at running the out hose to the breather coming your stock tank and then the in hose can be the breather.
That way as the main tank has its fuel used up the breather will suck fuel from the small tank.
Does that make sense?
Old 10-02-2013, 04:22 PM   #4
Tammy
Team 2nd Wind
Tammy's Avatar
Oddometer: 1,465
Chris i have a setup like what your looking to do call me and ill fill ya in on how i did it.
08 WR250F
07 G650 X Challenge
Bergen Co, NJ
AMA / CJCR / ECEA
In a world that what we want is only what we want until it's ours
Tammy is offline   Reply With Quote
Old 10-02-2013, 06:49 PM   #5
sallydog OP
AVERAGE 78.1 MPD
sallydog's Avatar
Oddometer: 5,652
the tank will work for gas. the fitting has 2 hoses and is readily available. im thinking i can just route it in thru my vent line
Old 10-02-2013, 06:51 PM   #6
sallydog OP
AVERAGE 78.1 MPD
sallydog's Avatar
Oddometer: 5,652
and it came with 2 gallons of 2 stroke oil. just in time. i am out
Old 10-04-2013, 06:08 AM   #7
sallydog OP
AVERAGE 78.1 MPD
sallydog's Avatar
Oddometer: 5,652
so, it been identified as a remote oil tank for mercury boat motor. but the fitting is obsolete. new style is different. who knows where i can get the part?
Old 10-04-2013, 07:12 AM   #8
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,751
I have no idea about plumping on the S10, but I will jut say I have gone through some growing pains regarding using the vent on a FI bike. For quite awhile the main tank was over pressurizing and blowing fuel out the filler neck into my crotch while riding and onto a hot header.
Especially with a non standard tank you might consider a stand alone setup like a rotopax. I know it's not blingy and you have to actually unscrew the cap but it might be was less of a hassle.
I think on most FI bikes I have seen aux tanks plumbed in through a bulkhead fitting drilled through the main tank like the Iron Butt FJR etc. If it were as simple as going through the vent, I think most of those savvy cats would have been using that method vs drilling a hole in their tank.
Anyways regarding your oil tank, you might call around to an outboard repair shot in your area or ebay or a marina that does repairs.
On your tank diagram, it shows 2 "vent lines" A&B. One is def the slop drain that drains the fuel overflow and water around the neck. That one can not be used to backfill as it doesn't touch the fuel. The other might be a tank vent, but it looks like it's also venting around the slop ring and might be integral to some mechanism in the fuel cap. Shove some stiff monofilament down those drains and see where it comes out. I had to disable the one way valve in my filler cap so that the main tank would vent but my tank only has one straw internally while yours has two.
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
sailah screwed with this post 10-04-2013 at 07:17 AM
Old 10-07-2013, 06:57 AM   #9
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,720
Obsolete from Mercury Marine??? Maybe from the usual Marine suppliers. Looks like it is still listed in the Paynes Marine catalogue, 033486 but Eh they are Canadian. However they sell the same products as the American suppliers.Scepter or Moelller brand. Sorry not on the coast to go check right at the stores.
http://marinecatalogue.ca/#/420/
Have tools, will travel!
Old 10-07-2013, 07:21 AM   #10
sallydog OP
AVERAGE 78.1 MPD
sallydog's Avatar
Oddometer: 5,652
thank you
Old 10-08-2013, 05:28 AM   #11
hogasm
Oddometer: 41
Remove your sending unit on the main tank. Drill and install a bulkhead fitting.
This is a company that sells one for a grvity feed for a goldwing....but you can do the same on your bike using the pump to feed the tank
http://www.dayledesigns.com/qt/Plumbing.htm
He who dies with the most toys still dies
hogasm is offline   Reply With Quote
Old 10-08-2013, 06:15 AM   #12
sallydog OP
AVERAGE 78.1 MPD
sallydog's Avatar
Oddometer: 5,652
thanks for that link. the parts list will come in handy. but i have a couple issues. my tank has the pump on the bottom.
i am waiting for the tank connection fitting. here is what i am thinking.my remote tank will sit higher than my regular tanks gas pump by at least 6 inches. if i run my existing tank vent to the remote tank out as my tank empties it will draw from the remote tank (like a siphon) without putting extra pressure on the pump. my gas gauge will also still read correctly. when unplugged the tank connection fitting would serve as the vent.
is there any reason that wont work?
Old 10-08-2013, 08:55 AM   #13
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,720
I think that will work unless you have air in the line. How about one of them "primer bulbs" on the line just in case you have problems starting the syphoning action.
Old 10-11-2013, 05:47 AM   #14
CollinsB
CollinsB's Avatar
Oddometer: 992
The aux tank a great idea..but at the end of the day, carrying an extra fuel can or bottles is often a better option.
Brian
BMW 1200GS ADV, KTM 625SXC, KTM 950SE
Yamaha R1, Kawasaki BF V750
CollinsB is offline   Reply With Quote
Old 10-11-2013, 06:27 AM   #15
sallydog OP
AVERAGE 78.1 MPD
sallydog's Avatar
Oddometer: 5,652
i dont agree.
rotopax are nice but a rotopax that plugs in is nicer. anything smaller is a waste of time. if you have a tank that plugs in you only have to carry it when you need it, and the plug is hidden when you arent carrying the tank
Times are GMT -7.   It's 07:30 AM.
