Old 10-02-2013, 02:30 PM   #1
JAB OP
Unsprung Weight
JAB's Avatar
Oddometer: 1,286
Deep cycle battery in an RV
Just had to replace the "house" battery in the RV. This battery only lasted 2 or so years. I thought it would last longer since it is always being trickle charged by a solar panel. Is there a charge/discharge routine that helps a deep cycle battery last? What kills this kind of battery?
1991 Honda XR628R
1978 Yamaha XT500
JAB is online now   Reply With Quote
Old 10-02-2013, 03:01 PM   #2
moymurfs
moymurfs's Avatar
Oddometer: 2,227
Did your solar system have a "maintainer"? Meaning, it senses the battery is fully charged and discontiues the charge until it drops to a certain level then starts charging again. A trickle chage can still overcharge a battery if left on, thus shortening its life. 2 years out of a battery of that type seems screwy. If you can, I would take the battery out in the off season and at least bring it in the garage on a Battery Tender.
Sent from my Radio Shack TRS-80 using a keyboard and electricity.
moymurfs is offline   Reply With Quote
Old 10-02-2013, 03:24 PM   #3
JAB OP
Unsprung Weight
JAB's Avatar
Oddometer: 1,286
The charger will stop or taper the charge at a certain level. The battery never needed water or seemed to be "cooked" in any way. The panel always
showed 12.5-13.5 volts. The "starting" battery (not a deep cycle) never gets any love and is about 4 years old and doing fine.
1991 Honda XR628R
1978 Yamaha XT500
Old 10-02-2013, 03:30 PM   #4
Tweaker
Oddometer: 9,623
Interesting the panel has a charge controller. What exactly do you have?
Tweaker is offline   Reply With Quote
Old 10-02-2013, 05:18 PM   #5
hugemoth
hugemoth's Avatar
Oddometer: 3,035
12.5 - 13.5 volts isn't really enough. Really should be brought up to 15 or 16 volts once in a while. The fact that it never needed water indicates an undercharge. BTW a pair of 6V golf car batteries wired in series is a better way to go if you have room. Those are true deep cycle batteries that hold up much better.
Old 10-02-2013, 07:56 PM   #6
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,771
^ and cheaper
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
sailah is online now   Reply With Quote
Old 10-02-2013, 08:10 PM   #7
Beezer
Oddometer: 5,884
many lead acid deep cycle and marine batteries use a lower specific gravity electrolyte. so.... they also may not ever come up to 12.5 volts simply because that chemistry. best thing to do is get in touch with the manufacturer & see what constitutes a full charge, and what method and rate of charge the recommend.
when the plates sulphate is what usually kills them. sulphation is a normal part of the discharge process & is reversed when charged.... but it doesn't necessarily all convert back, and eventually the battery loses capacity. things that make it worse are discharging & staying discharged, loss of electrolyte, exposing the plates to oxygen... doesn't sound like that's what you have.
also, as the battery ages, the sulphate flakes off and collects in the bottom. there is a space provided, but it can eventually build to the point where the residue shorts the plates
another thing is a breakdown of the cell barriers. that can be caused by over heating (rapid/high charge rate) or simply taking a bad bounce.
Beezer is offline   Reply With Quote
Old 10-02-2013, 08:26 PM   #8
JAB OP
Unsprung Weight
JAB's Avatar
Oddometer: 1,286
The charge controller is a Go-Power. It has a float voltage of 13.7 volts and when the battery is charged it will taper the amps to 0. Every 28 days it does a equalization charge of 14.8 volts. There is a boost feature for a discharged battery. There are times when the RV isn't used so there is no discharge to speak of. I wonder if I need to turn something on once a week or month and discharge the battery some.
I would love to have 2 big 6V batteries and another solar panel but don't have a great place to mount the batteries without some surgery. With the existing system and an inverter I hardly have to start the generator.
1991 Honda XR628R
1978 Yamaha XT500
Old 10-02-2013, 08:42 PM   #9
MJS
MJS's Avatar
Oddometer: 1,916
How far do you run the battery down when using the inverter? To deep a discharge hurts battery life. I went from max 2 years of life with the housse batteries in my boat to an easy 5 years once I wired in a smart charger (Heart Interface) with occasional equalization charges. I did have to watch the water level though.
"You can follow me, but it's gonna hurt"
http://www.blackswanmoto.com
MJS is offline   Reply With Quote
Old 10-02-2013, 09:23 PM   #10
chokozip
Oddometer: 194
What brand of battery?
Flooded lead acid,AGM or gel?
Trojans are over priced for the performance I have gotten out of them.
Stay away from the Interstates they are junk.
I will use Deka or Crowns with outstanding performance.
US battery has done well but the Deka has been tops out of the three.
Alot of the new chargers have a pluse mode that keeps the sulfation down.
Confirm your controller is doing what its suposed to.I see alot of chargers crap out and just charge or over charge a battery untill its dead.
Sean
I will meet you on the long road to the middle.
Colorado/Utah 2014 ride report here:
http://advrider.com/forums/showthread.php?t=1019732
chokozip is offline   Reply With Quote
Old 10-03-2013, 02:53 PM   #11
ttpete
Rectum Non Bustibus
Oddometer: 6,071
You might want to replace that solar unit with a Solargizer. These have been adopted by the US armed forces to keep batteries properly charged in reserve vehicles that sit for months in motor pools in between usages. Think of it as a sun powered Battery Tender. AGM batteries are available in the large sizes, and typically last longer than the flooded electrolyte type.
2015 BMW R9T, 2010 Ducati 1098 Streetfighter S
2009 Kaw 650 Versys, 1967 Triumph 650 TT Special
Old 10-03-2013, 06:22 PM   #12
Tweaker
Oddometer: 9,623
I am confounded on why you even need a controller. If the panel is sized properly, there won't be any overcharging. I've had a ~16v 10w panel on a gate battery for years. VW used to send their cars out with small 5w panels. Your company GoPower sells three of them at the appropriate voltage. Why are you introducing this gadgetry into what is a simple process? Battery Management Systems are probably the leading cause of premature battery failure. I don't believe lack of equalization is reason with the apparent light? use that you describe.
Or you have a draw that you don't know about. My RV batteries are lucky to see any attention for months and still last their 5 years but after switching out a pile of deep cycle lead acids for LiFePo4, I will never ever go back.
Old 10-04-2013, 06:13 AM   #13
MookieBlaylock
MookieBlaylock's Avatar
Oddometer: 2,581
Originally Posted by MJS View Post
How far do you run the battery down when using the inverter?.
that's definitely one thing that kills them. Going under 12 volts/50% charge is bad for rv bats
MookieBlaylock is offline   Reply With Quote
Old 10-04-2013, 12:03 PM   #14
JAB OP
Unsprung Weight
JAB's Avatar
Oddometer: 1,286
Bingo. This could be part of my problem. I have pushed the inverter use a couple of times. If I remember correctly, the volts were high 11's and capacity was around 70%. As far as the controller is concerned, I think it needs to be there as the solar panel is rated at 135 watts rather than a 1.5 watt maintainer. When we dry camp, the system does a good job keeping the battery topped up. Our uses are pretty low for the inverter. Usually a pot of coffee or a hair dryer. Can't run the microwave on it, if we need that, we can use the gen, but the gen is noisy and a very poor battery charger. If I could make one quick/easy change it would be to add another battery to the system, followed by another panel.
Might be nice to try a better grade of battery too. Currently using a Napa (Interstate?) battery, the largest that will fit in the current space.
1991 Honda XR628R
1978 Yamaha XT500
Old 10-04-2013, 07:48 PM   #15
RVDan
RVDan's Avatar
Oddometer: 2,695
It could have been a random crappy battery. Ive had plenty of batteries go bad inside of two years while others from the same batch lasted many years.
The Walmart energizer batteries in my camper are over ten years old and still going strong.
Generally I only sell Interstate unless the customer request something else, they are made by Johnson controls, Johnson Controls knows how to build a battery.
Sometimes wheelies happen
Originally Posted by RedRocker
You can never have too much hook.
RVDan is offline   Reply With Quote
Times are GMT -7.   It's 12:52 PM.
