Go Back   ADVrider > Bikes > Battle Scooters
Old 10-10-2013, 03:58 PM   #31
k-moe
k-moe's Avatar
Oddometer: 3,058
Originally Posted by JerryH View Post
I still have the Zuma 125, which is basically the same scooter with a different look.
...and a better engine IMHO.
k-moe is online now   Reply With Quote
Old 10-18-2013, 08:58 PM   #32
steve_k
steve_k's Avatar
Oddometer: 1,064
Are you sure the belt was even changed the first 2 times?
steve_k is offline   Reply With Quote
Old 10-19-2013, 08:59 PM   #33
JerryH OP
Oddometer: 5,069
Yep. I'm the one who changed them. Right around 10,000 miles. Did not see anything out of the ordinary when I replaced them. Both were oem Yamaha, just like the one that shredded.
JerryH is offline   Reply With Quote
Old 10-21-2013, 07:27 AM   #34
steve_k
steve_k's Avatar
Oddometer: 1,064
Ah, good... You did the work so you would know for sure! Have seen few threads on the net about timing belts that were paid for but never changed and motors wiped out shortly after.
It's a bummer to have yours go out so soon.
Old 10-21-2013, 07:16 PM   #35
JerryH OP
Oddometer: 5,069
The problem is I never found out WHY it broke so soon, and am afraid the new belt could break at any time, leaving me stranded again. Plus I have a fairly new Zuma 125 with the same belt and drive system, and it has around 4,000 miles on it. Don't know how much I trust it either. I was planning on putting some miles on it this winter, including a couple of 1000+ mile trips. Now I'm not so sure.
Old 10-21-2013, 08:20 PM   #36
blugg1
Oddometer: 506
Maybe you should sell both the Vino and Zuma and get a scooter with a larger engine, say 200-250cc's. Especially if you're planning 1000 mile trips. You'll have a much better time on a Kymco or a SYM or whatever on longer trips.
2014 Kawasaki 300 Ninja, 2012 SYM HD200 EVO
blugg1 is offline   Reply With Quote
Old 10-22-2013, 09:34 AM   #37
Moat
Moat's Avatar
Oddometer: 128
I'd just bring along a spare belt and the required tools to change one out on the side of the road, if needed - and not worry about it. If one were to compare the time spent over a 1000+ mi trip doing chain maintenance vs. changing a belt... probably pretty close. The price of adventure!
- '01 YZF600r - sport-touring backroad bliss
- '97 KLR250 - 'ol reliable, loveable pack burro
- '12 Taotao ATM50-A1 - cheap Chinese scooter experiment (surprisingly successful... so far)
Moat is offline   Reply With Quote
Old 10-22-2013, 01:54 PM   #38
gogogordy
gogogordy's Avatar
Oddometer: 2,003
An anomaly I'm sure.
Nothing to get your panties bunched-up over. Don't let it ruin your fun. Coulda been a new tire blowing out...that happens too.
Isn't it past your bedtime?
gogogordy is offline   Reply With Quote
Old 10-23-2013, 05:57 AM   #39
Dan V.
Dan V.'s Avatar
Oddometer: 184
Just something that is gonna happen. When we went on out trip to dragon land each scoot had a spare belt even though we could not change it out on the roadside. Wanted to have one aboard so as not to blow the trip waiting on a local mechanic to source a belt if one was needed.
Over the past years, accumulating thousands of collective miles, our club rides have never had a belt failure from normal circumstances. This is with scoots of all different sizes, and with varying states of maintenance and equipment age.
The only belt mishap was from a guy who kept mis-installing his variator, where by the nut was tightened on the shoulder of the crank and not on the variator face itself. This would cause the variator to work loose while riding, eventually ruining the variator, belt, and the crank itself.
That video above with the FU variator had to be caused by a bad install. Obviously something came loose, and friction heated things up to melt the sliders. I can't even imagine how it would run, but someone obviously ran it quite a while like that. I can hear it now "It was making a funny noise while I was riding it"!
Jerry, you got a bad break, or bad belt. Maybe AZ heat has something to do with it. Still no reason to dump the Vino.
How many scoots are too many?
Dan V. is offline   Reply With Quote
Old 12-29-2013, 09:35 PM   #40
Chillis
Land Barge Pilot
Chillis's Avatar
Oddometer: 4,157
Jerry, when your belt broke, were you going down hill traveling faster than your normal top speed?
I say this because on my Aprilia, I can go down a large hill and hit almost 70mph indicated with the Malossi variator due to its ramp design. In pushing the belt out that far it wears on the engine case and that was the last time I went for a top speed run.
If you have pushed the envelope with your bike you could have damaged it prior to its failure.
Chillis is offline   Reply With Quote
Old 12-30-2013, 06:41 AM   #41
JerryH OP
Oddometer: 5,069
I still don't know what happened, but I'm not going to complain about it anymore. There is very little doubt I was abusing the scooter by overloading it and riding it at WOT 95% of the time. It's a stock setup, but yes I did let it run too fast downhill at full throttle several times. I also had the habit of going from WOT to fully closed throttle, and it looks like that might cause the belt to bunch up on the front pulley. I didn't realize until after this happened just how loose the belt was on the pulleys. A chain running anywhere near that loose would either come off the sprocket of jerk around and break.
I plan on selling this scooter fairly soon, and getting something bigger, that won't have to be run at full throttle constantly. I am still at a loss to explain why the first 2 belts lasted so long, being treated the same way, but I've seen stranger things.
Old 12-30-2013, 08:00 AM   #42
blugg1
Oddometer: 506
SYM HD 200, Jerry.
Old 12-31-2013, 05:06 PM   #43
RedArrow
With scootrboi
RedArrow's Avatar
Oddometer: 3,029
Just finding this thread, Jerry. Now understanding your belt concerns a little better. So glad you weren't hurt by your mishap.
1984 Honda Aero NH125 Scooter
1983 Honda CT110
1980 Puch Moped
RedArrow is offline   Reply With Quote
Old 01-01-2014, 05:51 PM   #44
JerryH OP
Oddometer: 5,069
I never did find a clue why the belt broke. The first 2 belts lasted 10,000 miles, and still looked good when I replaced them. They showed some wear on the edges, but were within the service limit. There was no wear or damage on either pulley, though there was a ring of rubber from the belt stuck to the front pulley. This was most likely caused by me riding it at full throttle most of the time, when the front pulley would have been all the way closed. But there was no groove worn in the pulley. I remember cleaning off the same rubber the first 2 times I had replaced the belts.
I had also replaced the rollers with stock oem replacements 4000 miles earlier, when I did the belt. Rollers are covered in plastic, and they were in perfect condition, no sign of heat damage. There was also no sign of any oil or grease on anything.
The first 2 times I replaced the belt, I did not remove or disassemble the rear pulley/clutch assembly. But after the belt broke, I decided to remove it and inspect everything. I cleaned and inspected every part, and found nothing wrong. I put new grease on the inner bearings, the pins and slots, reassembled it and reinstalled it.
It now has over 1000 miles on it since I got it all back together, and has ran perfectly, just as it always has. Top speed is still the same, though I no longer ride it much at full throttle other than on takeoff.
A CVT is a very simple thing. They are easy to understand and easy to work on. The big issue I see with older ones is that they contain a lot of O-rings, rubber seals, pins, and bearings on the rear pulley/clutch assembly, which probably should be replaced, but may not be available anymore. While all CVTs are pretty much the same design and appearance wise, those parts are not interchangeable. They vary slightly from one unit to another. I hope you can find all the parts you need for yours.
Old 01-02-2014, 07:20 AM   #45
Motovista
Parts is Parts
Motovista's Avatar
Oddometer: 507
This is why your belt failed prematurely:
http://advrider.com/forums/showpost....&postcount=203
JerryH describes how he changes a belt-
"When removing the CVT, there are 3 nuts that have to come off. People have come up with all kinds of ways to get these nuts off. Many use an impact driver, and if you have one that's great. I do not own one, the ones at work are pneumatic, and I don't have a compressor big enough to power one. The first thing I did was to use an electric engraver to make a mark on both the nut and the end of the shaft, so I could tell where they lined up before removing them. On the front pulley, there was a toothed gear behind it, and I fed a rag in between the gear and the case. I then put the box end of a combination wrench on the nut, and tapped on the wrench with a hammer (homemade impact driver). Don't hit it really hard, remember that's the crankshaft you are banging on. After a short time the nut came loose.
On the clutch bell, I put a clamp on the rear brake lever, and tightened the lever down against the handlebar, locking the rear wheel, then removed the nut the same way as I did the front one. Once the clutch bell is off, the rear pulley and clutch assembly slides off. There is large diameter flat nut that holds it all together. I used a really large Crescent wrench on that one, put the assembly down on the floor on an old piece of carpet, and held it with one hand while tapping on the wrench with a hammer. Again it came off fairly quickly.
When I put it all back together, I did it the same way I took it apart, lining up the marks I made earlier. I have torque wrenches, but they are worthless unless you have a really solid way to hold what you are tightening. "
The tools to remove a clutch and variator are extremely inexpensive, and it really would be worth investing in a set, because if you do get a bigger scooter and change the belt this way, things are going to go south a lot faster.
Discount OEM, replacement and performance parts for vespa, honda, bmw, yamaha, suzuki, genuine, kymco, piaggio, aprilia, SYM, tgb, tomos and other scooters at http://www.scooterpartsco.com
GT200, GT200, ET2, Italjet Velocifero, Italjet Torpedo, Eton Beamer 3, Genuine Buddy Pamplona 150, Kymco Vitality 50, Honda Elite 50
Motovista is offline   Reply With Quote
Times are GMT -7.   It's 09:36 PM.
