Old 10-13-2013, 03:24 PM   #16
c.vestal
Rally On
c.vestal's Avatar
Oddometer: 4,893
Awesome work getting this rolling Scott "The Oracle" Whitney!!!
c.vestal is offline   Reply With Quote
Old 10-13-2013, 03:57 PM   #17
JMo (& piglet)
Gone a bit Baja
JMo (& piglet)'s Avatar
Oddometer: 4,236
I really want to do this... I will try to make it happen!
Jx
JMo (& piglet) is online now   Reply With Quote
Old 10-13-2013, 07:06 PM   #18
Baja Dad
Baja Dad's Avatar
Oddometer: 2,024
Jx
Anything I can help you with just let me know!!
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 10-14-2013, 10:52 AM   #19
pfdskipper
Westside Trash
pfdskipper's Avatar
Oddometer: 1,074
Hmmm, thats nearly my backyard. More details please.
If you are talking about venturing into the area the locals call "El hueco del infierno", this will definitely be very interesting!
pfdskipper is offline   Reply With Quote
Old 10-14-2013, 12:59 PM   #20
Bicycle Phil
Bicycle Phil's Avatar
Oddometer: 695
"The Oracle" at rest
-Phil-
San Francisco Motorcycle Club
Thank you: MX1West, Renazco Racing, KTM Twins, Rally Management Services
Bicycle Phil is offline   Reply With Quote
Old 10-14-2013, 01:02 PM   #21
JMo (& piglet)
Gone a bit Baja
Oddometer: 4,236
Thank you BD!
I need to work out a few things, but I may well be calling on you!
Jx
Old 10-14-2013, 01:08 PM   #22
HogWild OP
Scott Whitney
HogWild's Avatar
Oddometer: 2,766
Keep in mind there are certain details we will never provide. For example we will never publish where the course goes, because in rally you're never supposed to know until you're on it racing. And we will always be vague about even the general areas where the course is. We will probably wait until the last possible moment to divulge exactly where the bivouac is.
We won't know the length of the stages until they are finalized. And in my mind, the length will tell you little more than what your odometer should read at the finish. While pre-running one stage we averaged less than 15mph, and I used more than double the normal gas for that length. Another stage may have an average speed over 30mph or even 40mph. One thing is for sure, you'll be worn out by the end!
Yesterday I was pre-running one stage that we now believe is not usable because it crosses a "protected" area, even though the land owner was with me and fully approves of the race going there. So I have to go out and make a replacement stage for that one. The course development will probably go on for many more months.
Aside from specific location and course length, what "details" are you looking for?
New desert racing frontiers
It will be Devilish !
HogWild is offline   Reply With Quote
Old 10-14-2013, 01:15 PM   #23
tehdutchie
tehdutchie's Avatar
Oddometer: 1,874
How about bivvy? All in the same place? What can we expect mileage wise? For our bike set up, fuel tanks.
4 dutchies thinking about coming over as the south African is not as certain as your event...
tehdutchie is offline   Reply With Quote
Old 10-14-2013, 01:43 PM   #24
HogWild OP
Scott Whitney
HogWild's Avatar
Oddometer: 2,766
We have been planning for a single bivouac, with each stage starting and finishing there, and NO liaisons. But this weekend we had a meeting with some local officials and they might want a slight modification to that plan. Our goal is to keep the logistics as simple and cheap as possible.
Read my post above.
Old 10-14-2013, 02:18 PM   #25
tehdutchie
tehdutchie's Avatar
Oddometer: 1,874
Read my post above.
Cheers! Exciting
Old 10-14-2013, 03:27 PM   #26
hardwaregrrl
ignore list
hardwaregrrl's Avatar
Oddometer: 7,540
Man, I wish I had the nuts to do this one!!! But man I think it's pretty spectacular you cats are doing this and that the community is supporting you!!! Bravo
Old 10-14-2013, 05:43 PM   #27
drc42
Rally Dreamer
drc42's Avatar
Oddometer: 1,840
Based on what you have said (mostly your comment about needing twice as much fuel as expected) sounds like fuel range is one concern for me. I recently bought an aux tank for my WR450F which would bring me to 23L. Does that sound like it should be doable given the distances/terrain you are planning?
Beyond that I am finding answers to all my big questions on the website... well other than entry fee but I suspect lots of unknowns before you are able to set that.
As far as course details I agree, keep is secret, much more of an adventure knot knowing exactly what is in store
follow my journey: Dreaming of Dakar
drc42 is offline   Reply With Quote
Old 10-14-2013, 06:07 PM   #28
HogWild OP
Scott Whitney
HogWild's Avatar
Oddometer: 2,766
We want to give the racers what they want as much as possible, without detracting from key aspects of rally. We can add a gas stop or two depending on the majority need, but we won't go so far as to put them 60 miles apart as in SCORE type races. For Dakar I think the requirement is 250km range, which is 155 miles. If you have that (assuming "typical" terrain), you're probably ok. If you want a lower requirement, post your request here and if there are a lot of others that want a shorter range requirement then we'll see what we can do. Any stage that cuts your gas range in half due to the terrain would likely be shorter accordingly.
Old 10-14-2013, 06:24 PM   #29
frog
frog's Avatar
Oddometer: 2,790
Being able to get by with a 5-6 gal tank would be awesome.
Sent from my DROID RAZR
Thank you MX1WEST, Highway Dirt Bikes Lindsay Machine, Smart Performance, SPS for the Support
257x Solo Baja 1000
If I had not some strength of will I would make a first class drunkard--Shackleton
frog is offline   Reply With Quote
Old 10-14-2013, 08:06 PM   #30
BAZZER450
Oddometer: 315
+1 on 5 to 6 gal tank
BAZZER450 is offline   Reply With Quote
Times are GMT -7.   It's 02:02 AM.
