Old 10-10-2013, 10:08 AM   #1
tilting40s OP
Oddometer: 57
Easy way to re install rear stealth Sproket??
Cant get at the bolts while its in the rim/cush drive so I can't get all that much leverage, any easy ways to do this I'm guessing there is a special tool as well.
tilting40s is offline   Reply With Quote
Old 10-10-2013, 10:33 AM   #2
spafxer
spafxer's Avatar
Oddometer: 2,599
Since you say it has a cush drive, I assume it is a 9?0 KTM...
You know the cush drive pulls out of the hub, right? Any socket/wrench fits.. Easy Peasy !
WHat am I missing here?
spafxer is offline   Reply With Quote
Old 10-10-2013, 10:38 AM   #3
tilting40s OP
Oddometer: 57
I have a new cush drive that cam with new wheels that the sprok must be transferred to.
Old 10-10-2013, 11:37 AM   #4
Orangecicle
Orangecicle's Avatar
Oddometer: 2,447
Maybe a pic would help. The simple answer is that you remove the wheel, lift off the Cush drive, put that assembly in a vise, and wrench away.
Facebook Page: https://www.facebook.com/brad.horn.9
Orangecicle is offline   Reply With Quote
Old 10-10-2013, 11:55 AM   #5
brooks
Oddometer: 322
cush drive help
the sprocket just pulls right away from the wheel, if stubborn a tap with a rubber mallet will bring it loose. The cush drive just comes out too. Nothing holding either of them in. Put the old sprocket in a vice and take the nuts off(there is metal on the factory sprocket to keep the bolt from turning. If you have the same supersprocket i put on the the bolts go flush in the hole. Torque to 50 NM in a star pattern. Boom!
Brooks
brooks is online now   Reply With Quote
Old 10-10-2013, 11:58 AM   #6
brooks
Oddometer: 322
ps put something around the new sprocket to keep it from getting marred up while installing the bolts! Gotta keep the bling!
Brooks
Old 10-10-2013, 05:21 PM   #7
DirtyADV
DirtyADV's Avatar
Oddometer: 2,184
How to do it without a wise:
http://www.flickr.com/photos/dirtyadv/7034740691/
And dont forget loctite:
From manual to a 2004 bike:
HH nuts on rear sprocket bolts M10x1.25 Loctite 243 + 50 Nm
/Johan
Have changed name, was previously Dirty950
www.dirtyadv.com (under construction)
DirtyADV is offline   Reply With Quote
Old 10-10-2013, 05:34 PM   #8
MAXVERT
Rough Rider
MAXVERT's Avatar
Oddometer: 1,024
Impact wrench.
Max
Da oggi la strada
é senza limiti
MAXVERT is offline   Reply With Quote
Old 10-10-2013, 05:45 PM   #9
Denalidirt
High Plains Drifter
Denalidirt's Avatar
Oddometer: 921
just did it
The locktite takes some serious effort to break. I screwed the sprocket to my work bench in 4 spots and the used my 2' torque wrench to break the locktite grip.
worked for me.
now I'm looking for a 15t front, any ideas who sells a dampened one?
Denalidirt is offline   Reply With Quote
Old 10-14-2013, 09:30 AM   #10
tilting40s OP
Oddometer: 57
DirtyADV, awesome tip! It made it a piece of cake.
Old 10-14-2013, 11:59 AM   #11
DirtyADV
DirtyADV's Avatar
Oddometer: 2,184
If you look in the background you can actually see a bench wise but wanted to show how to do it without a wise, anything you can place in between the teeth on the sprocket carrier to hold it in place works.
Can be harder to find room for a torque wrench on a sprocket fixed to the hub directly since the spokes will be in the way.
Glad to be able to help =)
/Johan
Old 10-14-2013, 08:01 PM   #12
sstewart
sstewart's Avatar
Oddometer: 1,056
Bolts
Are you fucking kidding me? Dammit Boy!
sstewart is offline   Reply With Quote
Old 10-16-2013, 03:53 AM   #13
katoome
Oddometer: 22
Loctite
Loctite lets go with heat , A small LPG flame on the nut until too hot to touch will do the trick.
katoome is offline   Reply With Quote
Old 10-20-2013, 08:28 PM   #14
sstewart
sstewart's Avatar
Oddometer: 1,056
Impact
Originally Posted by MAXVERT View Post
Impact wrench.
Max
The only way!
Times are GMT -7.   It's 07:47 PM.
