Old 10-15-2013, 10:55 PM   #16
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,022
Seen both ways. This is the way they came up to about the mid-1990's. Now the rim strips have several holes and go under.
Works both ways with a rim strip.
Just used a Motion Pro stick on rim strip for the first time. Looks tough, stuck on tough. Slick.
"Son, you can't do both"
Old 10-16-2013, 05:16 AM   #17
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,327
Originally Posted by NWMotohead View Post
That is the correct way. A rim band only has one hole in it, for the valve stem. This means it has to go "over" the rim lock as shown, otherwise it would need and have, two holes. I also pull the band off on my dirt bikes and 950 SE and do about three layers of duct tape(just in the rim's valley) instead of the band. Has worked great for me.
But the duck tape doesn't have any holes,,,, how does that work?
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is online now   Reply With Quote
Old 10-16-2013, 07:55 AM   #18
Rock Junkee
Rock Junkee's Avatar
Oddometer: 220
Drill and Drill bit
Rock Junkee is offline   Reply With Quote
Old 10-16-2013, 05:59 PM   #19
Sheep Shagger
Show me your fleece
Sheep Shagger's Avatar
Oddometer: 2,147
Most dirt bike manufacturers must have it wrong from the factory then.. Every KTM, Yam & Honda ive owned that came with a rim lock from the factory has had the rim strip installed under the rimlock, and had 2 holes. While its a non issue (over or under) to state its wrong to install it under is ludicrous. The reason a new strip only has one hole is because not all spoked wheels run a rim lock.
Sheep Shagger is online now   Reply With Quote
Old 10-16-2013, 06:07 PM   #20
Spacelord
Mutha Mutha
Spacelord's Avatar
Oddometer: 872
Yep' this is the way I've done it for years
"I swear to god that I will beat you senseless with a sanka can before I die"
Spacelord is offline   Reply With Quote
Times are GMT -7.   It's 06:13 AM.
