Old 10-15-2013, 06:41 AM   #16
btao
RIP Lilolita
Oddometer: 1,024
Yep, definitely a good idea. I have a 1550 and it's the perfect size for normal non-travel use. Fits a full tool set, snack, maps, camera, and rain liners.
I made a plate for extra support since I fill it and go off road. If you OR, then I'd use a support plate. It is only plastic...
If you used fender washers outside and inside with the standoffs under it, you should be fine. I used the plate to push the mounting holes to the corners of the box so it's super stable.
_________________________
Current: '13 Tiger 800 XC, '09 Subi WRX, '11 405hp Sti (wifey's) Past: '74 Honda CB 360, '81 Yamaha 650 Special II, '01 Bandit 1200S, '07 Bandit 1250S
btao is offline   Reply With Quote
Old 10-15-2013, 06:57 AM   #17
Dubl-A
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
I use a Seahorse more of a box rather than a brief case...
SE-540 - $42
http://seahorsecases.com/Merchant2/m..._Code=SE_CASES
Dubl-A is offline   Reply With Quote
Old 10-15-2013, 02:57 PM   #18
lqgsrider OP
LQDesert Rider
lqgsrider's Avatar
Oddometer: 384
I plan to do some O/R riding thus I should probably use a metal plate under the Pelican case
http://lqgsrider.smugmug.com/Vstrom-...hoto%203-M.jpg
2004 BMW GSA
2013 Suzuki Wee-Strom
2012 Suzuki DRZ 400s
lqgsrider is offline   Reply With Quote
Old 10-18-2013, 08:01 AM   #19
ROYMACNIC
Oddometer: 63
Great choice of box,they are super tough,I just bolted mine onto original Honda rack,using ,like others have large washers,absolutely no problems on hundreds of km of Moroccan pistes.
Roymacnic
ROYMACNIC is offline   Reply With Quote
Times are GMT -7.   It's 10:28 PM.
