Old 10-14-2013, 12:56 PM   #1
labdog1 OP
Oddometer: 11
2004 950 adv lowering kit
Hey fellow 950 riders,
just picked up a 04' 950 adv with 33k, just a few questions,
first i'm 5'6" on a good day so the bike is to say the least tall, i bought a corbin low profile seat, (has anyone tried the OEM low seat?)i rermoved the bar risers, (anybody need a set?)
had a extra lugged sole installed on my Sidi's, no kidding, i'm determined to make this bike fit,,, right now i'm almost tipy toed when straddling the bike,
my next move is the suspension lowering kit for the forks and rear spring, my wife and i want to ride and camp,, any other safe mods for the little people,,,
oh by the way, mine stalls when stoping for a light or stop sign, idle seems ok?
help!!!!
thanks,
Joel
labdog1 is offline   Reply With Quote
Old 10-14-2013, 01:04 PM   #2
gearheadE30
gearheadE30's Avatar
Oddometer: 966
I can't really help with the lowering, but if you blip the throttle from idle, does it die? That would typically be indicative of a rich mixture, which you can fix by tightening the mixture screws a small amount. If it pops a lot on overrun coasting in gear, it's too lean.
2005.5 KTM 950 Adventure and 2012 KTM 200 XC-W
1991 BMW 318is turbo track car
1989 Chevrolet Caprice Classic Wagon sleeper tow car
1992 Subaru SVX daily
3 Months Exploring the US on a 950
gearheadE30 is offline   Reply With Quote
Old 10-14-2013, 03:12 PM   #3
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,473
Originally Posted by labdog1 View Post
...(has anyone tried the OEM low seat?)...
I have the factory low gel seat, and like it fine. I have heard complaints that it is hard when cold, it gets too hot in the sun, it is uncomfortable for long rides. I have not noticed any of these things. Maybe I have a defective posterior?
The boots are a good idea, I have similar. The combination of the boots and the lower seat has brought me about 1" or 1 1/2" closer to the ground.
I have a 31" inseam; the bike has 9" suspension, and I can just flatfoot it on level ground.
This should not happen.
What gearheadE30 said is good to try. If that doesn't cure it, keep looking, because something is certainly wrong.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 10-14-2013, 03:15 PM   #4
Peanuts
Peanuts's Avatar
Oddometer: 1,698
I put 17" rear, 19" front wheels in my Adv and its much lower now :)
Peanuts is offline   Reply With Quote
Old 10-14-2013, 03:25 PM   #5
Ladukebob
lost in hood river
Ladukebob's Avatar
Oddometer: 1,884
I'm 5'7" around 160lbs and I went with a softer rear spring that was also a tad shorter and 0.64 front springs that are a tad shorter. Overall the bike sits about .75" lower. The biggest change was how well the bike rides having the softer rear spring. Work was performed by a local suspension guy. Bike handles washboards so much better now. I have a 32" inseam and I can now back the bike up out on the trail without having to jump off every time. I really hated to make these mods to such an awesome bike but after a summer of riding I'm glad I did.
It's not an adventure until you cross a bridge , 2011 WR250, 2015 ktm 690r
findLadukebob
Ladukebob is offline   Reply With Quote
Old 10-14-2013, 03:27 PM   #6
Dale950
Dale950's Avatar
Oddometer: 986
I'm a shorty ( 28 '' inseam ) currently have the low gel seat but I had the hard gel removed and softer foam inserted - much better .
Fitted lighter rear spring so it's has a little more sag .
Dale950 is offline   Reply With Quote
Old 10-14-2013, 06:29 PM   #7
bomose
bomose's Avatar
Oddometer: 1,285
Can you still get a lighter spring for a 2004? All I've seen is for 2005.5 and later, which is a shorter shock.
I prefer a short life with width to a narrow one with length-Avicenna
http://www.advrider.com/forums/showthread.php?t=810149 Ouray Adv
http://www.advrider.com/forums/showthread.php?t=800723 Cortez & Moab
http://www.advrider.com/forums/showt...=955211Chasing Dinosaurs
bomose is offline   Reply With Quote
Old 10-14-2013, 06:39 PM   #8
renogeorge
Oddometer: 1,424
You can easily lower an inch or so by having the shock shortened and just raising the forks in the clamps. Rear spring should be fine as to length. Just back the pre load adjuster off to accomodate the shorter shock. Set preload as always. Front springs don't have top for length.be changed. I have performed these mods successfully on many dirt bikes and 950 SM.
KTMs--300, 518, 990
renogeorge is offline   Reply With Quote
Old 10-14-2013, 07:17 PM   #9
hudson6161
hudson6161's Avatar
Oddometer: 30
I bought an 04 from a short guy. I am short as well (5"6"). The bike when I bought it has WP shorter front fork springs and a shorter rear spring. I'm sorry I don't have more details for you than that but that combined with a logger style boot has been great. Good luck
For sure, you have to be lost to find a place that can't be found, otherwise everyone would know where it was
hudson6161 is offline   Reply With Quote
Old 10-14-2013, 07:34 PM   #10
MortimerSickle
Semi-Adventurer
Oddometer: 12,473
Originally Posted by renogeorge View Post
...and just raising the forks in the clamps. ...
Be cautious about this, and do some measuring. I don't think you will have a lot of room before hitting the bottom triple clamp on a G-out.
I would be interested to hear the opinion of someone who actually knows through experience- I am just guessing.
G.H.W.S. 1878-1962
MortimerSickle screwed with this post 10-14-2013 at 07:39 PM
Old 10-14-2013, 07:42 PM   #11
renogeorge
Oddometer: 1,424
You will only need to raise the forks 1/4-3/8" for a 1 inch lowering in the rear.
KTMs--300, 518, 990
Old 10-14-2013, 07:44 PM   #12
MortimerSickle
Semi-Adventurer
Oddometer: 12,473
I guess I have a lot to learn about suspension.
G.H.W.S. 1878-1962
Old 10-15-2013, 02:21 AM   #13
Dale950
Dale950's Avatar
Oddometer: 986
Yes , I got mine from this Co
http://www.eibach.com.au/
Or Talk to http://www.superplushsuspension.com/
Old 10-15-2013, 08:44 AM   #14
MortimerSickle
Semi-Adventurer
Oddometer: 12,473
Keep in mind that the earliest '04s have longer suspension-9"standard model and 10.4" S model.
G.H.W.S. 1878-1962
Old 10-15-2013, 05:41 PM   #15
welshracing_752
slidewaysjr
Oddometer: 18
I have a 06 that I put the oem tall suspension on( bought the kit) have all the parts to put in your bike to lower it for a deal.the suspension had about 3000 miles on it so still new but you'll want to go to heavier springs up front when two up alot
welshracing_752 is offline   Reply With Quote
Times are GMT -7.   It's 10:55 PM.
