Old 10-15-2013, 09:09 PM   #16
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,143
To make it shorter you have two options:
Your bike is one of the tallest, you can swap with any Adventure from 2005.5 and later to get about a 1 1/2" shorter bike. Easy swap, must include the center and side stands. Takes about 2 hours. Advertise on the forum and you should find someone.
Your bike probably needs the suspension rebuilt, fresh oil, new fork seals and all the debris cleaned out. You would like stiffer fork springs too, as the stockers are soft. To shorten the bike, it's only a little more labor to install spacers, get a shorter rear spring and cut the side stand. Most suspension shops have done this.
"Son, you can't do both"
Old 10-16-2013, 05:23 AM   #17
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,476
Does he have the tall suspension?
Mine does, but it is the earliest of the '04s, the silver one. I thought the later '04s had the lower suspension.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is online now   Reply With Quote
Old 10-16-2013, 08:27 AM   #18
RedRupert
Brit in the Soviet Union
RedRupert's Avatar
Location: Riga, Latvia / Bergerac, France / Colchester, UK
Oddometer: 582
All non-s 2003 and 2004s have 230mm suspension. In 2005 they shortened it to 210mm.
KTM 970 Adventure (2004 with carbed 2008 SD 990)
Yamaha WR 450 F
Honda 650 Dominator (1988)
Kawasaki KLR 650 (1988)
Yamaha RD 350 LC (1984)
RedRupert is offline   Reply With Quote
Old 10-16-2013, 08:34 AM   #19
RedRupert
RedRupert's Avatar
Oddometer: 582
Originally Posted by labdog1 View Post
Hey fellow 950 riders,
just picked up a 04' 950 adv with 33k, just a few questions,
first i'm 5'6" on a good day so the bike is to say the least tall, i bought a corbin low profile seat, (has anyone tried the OEM low seat?)i rermoved the bar risers, (anybody need a set?)
had a extra lugged sole installed on my Sidi's, no kidding, i'm determined to make this bike fit,,, right now i'm almost tipy toed when straddling the bike,
my next move is the suspension lowering kit for the forks and rear spring, my wife and i want to ride and camp,, any other safe mods for the little people,,,
oh by the way, mine stalls when stoping for a light or stop sign, idle seems ok?.bb.kn
help!!!!
thanks,
Joel
The first thing you should do is make sure the rear and front has minimum preload.
The difference between high and low at the rear is 30mm.
Preload only effects ride height, and not stiffness or hardness.
Yamaha WR 450 F
RedRupert screwed with this post 10-16-2013 at 08:53 AM
Old 10-16-2013, 09:00 AM   #20
James Siddall
suspension guy
James Siddall's Avatar
Oddometer: 176
Low Riding
As others have mentioned, your 2004 std is taller than later models standard height, at 230mm of stroke. The later bikes have 210.
We lower adventures on a regular basis without much difficulty. Combined with more appropriate springs and valving, the bike becomes a delight.
Check us out for advice or work.
Cheers
James
www.superplushsuspension.com
Never argue with stupid people, they will drag you down to their level and beat you with experience.
James Siddall is offline   Reply With Quote
Old 10-16-2013, 09:36 AM   #21
MortimerSickle
Semi-Adventurer
Oddometer: 12,476
Originally Posted by James Siddall View Post
As others have mentioned, your 2004 std is taller than later models standard height...
Furthering my education on ADV.
G.H.W.S. 1878-1962
Times are GMT -7.   It's 07:08 PM.
