Old 10-14-2013, 08:43 PM   #1
Dustodust OP
Dustodust's Avatar
Oddometer: 855
Electrical Charging Values Help
manual says I should have 14 to 15 volts at 5000 RPM with low beam on
measured at the battery terminals with a Fluke
is this realistic ?
I am only getting 12.75 volts at 5000 with the low beam on
charged battery 8 hours on the deltran before testing
do these regulators go bad ?
can a battery fail internally and exhibit this symptom ?
2004 950 adv approx 60,000 , 06 950 SM motor with about 20,000(picked out of a crash)
battery voltage died at the last 3 miles to home cold temps in the dark from a 850 mile adv weekend ride (some gravel road and on the beach at the ocean edge), worked flawless until the last 3 miles
cannot detect power drain in off, cannot find any shorts
wiggled the brown alternator/rectifier connector and no change
battery is one year old and charges
voltage dropped slowly, noticed RPM guage acting intermittent in the last 20 miles , so I turned off grip heaters, got another 20 miles, then bike started to sputter turned off the headlight, it quit sputtering, and made the last 3 miles holding a FenixE21 flashlight over the clutch perch, sure was glad to make it into the driveway
04 KTM 950 S
04 KTM 525 EXC street plated
Old 10-14-2013, 08:50 PM   #2
Warin
Retired
Oddometer: 2,066
Yes the rectifier regulators do go bad.
Have you recharged the battery? You should be able to measure the battery voltage when it is being charged - should get over 13.5 volts at least.
You should check the stator for continuity and insulation. There may be tests you can do on the rectifier regulator - see your manual for more information?
Warin is offline   Reply With Quote
Old 10-14-2013, 09:02 PM   #3
Dustodust OP
Dustodust's Avatar
Oddometer: 855
yes factory shop manual CD
battery is 13.7 after trickle charge at 8hrs
12.66v after starting and voltage drops slowly at idle to 3000 rpm or so with no headlight on
shows volt rise of .01 a second on the deltran charger
is the regulator tits up or am I missing something ?
I noticed the big brown connector was warm at the wires after rev test
battery terminals and main ground OK
04 KTM 950 S
Old 10-14-2013, 09:10 PM   #4
_cy_
Oddometer: 6,035
is this realistic ?
ALL charging systems that support PB will put out 13.8v to 14.2v at mid rpm. some system deviate but not by much.
after charging an AGM to full with a normal battery charger (not a tender) allow to sit overnight. measure resting voltage next morning... full charge is 12.6v to 12.8v range. then for load test, start your bike.
if say your AGM is 12.8v resting than starts your bike.. odds are your battery is good. if your bike is not putting out voltage within spec's given above... your R/R is bad and/or stator is bad too.
_cy_ screwed with this post 10-14-2013 at 09:17 PM
Old 10-14-2013, 09:33 PM   #5
Dustodust OP
Dustodust's Avatar
Oddometer: 855
Does anyone know for sure what Shindengen Mosfet replacement to get ?
or a good source ?
04 KTM 950 S
Old 10-14-2013, 10:27 PM   #6
Dustodust OP
Dustodust's Avatar
Oddometer: 855
evidently from what I can gather, this Thrisister Shunt on the ktm is prone to failure and underperforms
same system as the failure prone regulator on the pre-2007 Honda CBR, superceeded to the Shindengen Mosfet
I think I may as well upgrade to the " regulatorrectifier.com " version
$150
unless I can find a good used one cheep
04 KTM 950 S
Old 10-15-2013, 12:22 AM   #7
KTMSER
Big bike friendly
KTMSER's Avatar
Oddometer: 2,750
First one on the list if you can do a little wiring, pick the maxi fuse option instead of the circuit breaker...
http://roadstercycle.com/
Originally Posted by WaterWheel View Post
The things I would do with that old broad would make a seasoned porn producer puke.
KTMSER is offline   Reply With Quote
Old 10-15-2013, 12:37 AM   #8
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,160
I use this one
http://ricksmotorsportelectrics.com/...BBZHZlbnR1cmU=
It's plug and play. No wiring work.
I get 13.5v engine off lithium battery
14.5 engine running at 4000rpm
14.3 engine running HID head light on at 4000rpm
Happy with it fwiw
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 10-15-2013, 05:36 AM   #9
Motocrankin
Motocrankin's Avatar
Oddometer: 73
Regulator /Rectifier
Jack is the best guy in the business. I replaced my reg/recitfier with 1 of his custom made to fit your bike jobs. Excellent results. Sent all the way to Australia as well.
Motocrankin is offline   Reply With Quote
Old 10-15-2013, 08:13 PM   #10
Dustodust OP
Dustodust's Avatar
Oddometer: 855
thanks
just what I was looking for
owe you a beer
04 KTM 950 S
Old 10-19-2013, 03:10 PM   #11
Dustodust OP
Dustodust's Avatar
Oddometer: 855
AWESOME UPGRADE !
just finished install and testing
14.4 volts steady at 5000 rpm
easy wire up but took my time cleaning grit and soldering, routing etc.
nice fit , only drilled one hole in the bracket and added a 6mm speed nut used the other original
I highly recomend the Roadstercycle.com Shindengen Mosfet regulator rectifier kit , comes with everything needed for a foolproof upgrade, great service fast shipping.
04 KTM 950 S
Times are GMT -7.   It's 11:56 AM.
