Old 10-15-2013, 08:10 AM   #1
ADVill OP
Oddometer: 611
manually changing out a scorpion on 990
Any harder or easier than doing a regular dirt bike knobbie? Rear tire.
'08 990 Adventure Orange of course
'00 520 EXC
'14 500 XCW
ADVill is offline   Reply With Quote
Old 10-15-2013, 08:18 AM   #2
jclark83
jclark83's Avatar
Oddometer: 404
Breaking the bead is a bitch without a bead breaker....
1992 Bmw R100GS
2002 Bmw R1150GS
2008 Bmw K1200LT
jclark83 is offline   Reply With Quote
Old 10-15-2013, 08:30 AM   #3
ADVill OP
Oddometer: 611
After that, anything else bad?
'00 520 EXC
'14 500 XCW
Old 10-15-2013, 09:00 AM   #4
jclark83
jclark83's Avatar
Oddometer: 404
No, once you get past the bead breaking it's just like any other tire. I have not changed one along side the road. I use a Coats 220 for tire changes at home.
1992 Bmw R100GS
2002 Bmw R1150GS
2008 Bmw K1200LT
Old 10-15-2013, 09:06 AM   #5
ADVill OP
Oddometer: 611
'00 520 EXC
'14 500 XCW
Old 10-15-2013, 09:12 AM   #6
txbear55
Oddometer: 287
Really wasn't that bad....used Motion Pro's new bead breaker gadget and good tire irons and lotsa lube (soapy water). Probably only my third time to ever change a bike tire!
txbear55 is offline   Reply With Quote
Old 10-15-2013, 09:12 AM   #7
Just Paul
Pro Cat Herder
Just Paul's Avatar
Oddometer: 2,104
If you ride the bike around and get the tire hot it's a lot easier
Honda 450X (plated)
KTM Adventure S
Paul's SPOT TRACKER
“The world is a book and those who do not travel read only one page.” – St. Augustine
Just Paul is offline   Reply With Quote
Old 10-15-2013, 09:27 AM   #8
Katoom72
Katoom72's Avatar
Oddometer: 917
Indeed, make sure the tire is a bit warmer. Changing a tire when it's freezing is a PITA as the rubber becomes less flexible.
To break the bead i use my biggest tire iron and put it on the edge of the bead, then squad hold the iron with both hands and push on the iron while lifting myself up off the ground and putting all my 100kg's on the tire.
Might look a bit weird but it works.
Now:
'03 KTM 250sx -- '05 KTM Adventure 950
Before:
'00 KTM 250sx -- '03 KTM 450sx -- '03 Yamaha R6 -- '08 KTM SuperDuke R --- '13 KTM 690 enduro R
Katoom72 is offline   Reply With Quote
Old 10-15-2013, 09:28 AM   #9
Sporting Wood
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 896
If any tire is hard to mount or dismount, you're doing it wrong.
Sporting Wood is offline   Reply With Quote
Old 10-15-2013, 09:28 AM   #10
scorpion
Two arm bandit
scorpion's Avatar
Oddometer: 5,422
The 990 side stand is a built in bead breaker
07 KTM 990 11 Husaberg 390
scorpion is offline   Reply With Quote
Old 10-15-2013, 09:30 AM   #11
Katoom72
Katoom72's Avatar
Oddometer: 917
That statement has some truth in it. But breaking the bead or changing it when it's freezing cold is not always piss easy.
Now:
Before:
Old 10-15-2013, 10:00 AM   #12
Gustavo.Ramos
Gustavo.Ramos's Avatar
Oddometer: 962
Have to say that once with a 130/60/17 Shinko on my DR650 i must have done every possible thing wrong.
690R
Old 10-15-2013, 10:04 AM   #13
Sporting Wood
Oddometer: 896
Hey! Warming it up and deciding not to buy Chinese tires are parts of the, doing it right mantra!
Old 10-15-2013, 10:07 AM   #14
SixDays02
SixDays02's Avatar
Oddometer: 276
Actually, it is not so bad...
There was a video somewhere around here breaking the bead with three small tyre irons and yes, it works also w. Scorpions / 990 wheels.
SixDays | Croatia
SixDays02 is offline   Reply With Quote
Old 10-15-2013, 10:08 AM   #15
ADVill OP
Oddometer: 611
Changed many a tube on a trail on a dirt bike and quite a few tires in the garage. Actually, unfortunately I'm the person everyone comes to in this regard. I may just have the dealer do this one. They don't charge much... like $20.
'00 520 EXC
'14 500 XCW
Times are GMT -7.   It's 09:59 PM.
