Old 10-15-2013, 11:38 AM   #16
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,190
The K60 is horribly hard to take off cold.... Breaking the bead is.... Mind boggling hard. The scorpion is easy in comparison.
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 10-15-2013, 12:09 PM   #17
Boatman
Upward and onward!!
Boatman's Avatar
Oddometer: 10,397
Yup...
Got a flat this summer in NC on a 100deg day. Rode the flat K60 about 5 miles to get of the highway so it was plenty warm. I tried every trick in the book to get the bead broken,,, side stand, 3 tire irons, etc...... not even a hint of breaking the bead. Ended up going McGuyver on it....
08 KTM 950 SE, 09 KTM 950 SE, 04 KTM 950 ADV, 10 Husaberg FE390, 66 Kawasaki B8S Super 150
Hi/low beam conversions for: Trail Tech, Baja Designs
Boatman is offline   Reply With Quote
Old 10-15-2013, 02:19 PM   #18
SixDays02
SixDays02's Avatar
Oddometer: 274
Originally Posted by SixDays02 View Post
Actually, it is not so bad...
There was a video somewhere around here breaking the bead with three small tyre irons and yes, it works also w. Scorpions / 990 wheels.
Ah, here it is, i had no problems using this technique:
http://www.advrider.com/forums/showthread.php?t=458452
SixDays | Croatia
SixDays02 is offline   Reply With Quote
Old 10-15-2013, 02:27 PM   #19
Frog uk
Oddometer: 285
Originally Posted by Sporting Wood View Post
If any tire is hard to mount or dismount, you're doing it wrong.
Go off and try a Karoo, then let us now what you think then.
Frog uk is offline   Reply With Quote
Old 10-15-2013, 03:57 PM   #20
ciedema
мотоциклист
ciedema's Avatar
Oddometer: 1,970
There all easy including a Karoo. Side Stand or Motion Pro Bead Breaker. Even cold (and in cold weather).
Once the bead is broken these are actually easier to do than bikes with 2.5" rims. The new tire goes on so easily.
Stories from the Seat Facebook My Photos Cannonball Charity Ride
Personal Attacks - the last refuge of the intellectually impaired.
Originally Posted by XR650L_Dave View Post
The only guaranteed route to failure is the attempted solution of problems through the application of ideology.
ciedema is offline   Reply With Quote
Old 10-15-2013, 04:32 PM   #21
ADVill OP
Oddometer: 609
That's what i want to hear. After doing a dirt bike rear tire...
'08 990 Adventure Orange of course
'00 520 EXC
'14 500 XCW
ADVill is offline   Reply With Quote
Old 10-15-2013, 05:11 PM   #22
Sporting Wood
I <3 Energizer Bunny
Sporting Wood's Avatar
Oddometer: 896
+1. Are you guys leaving the valve stem in there or something??? Never had a problem with any motorcycle tire. ATV tires on the other hand can be a real PIA!
Sporting Wood is offline   Reply With Quote
Old 10-15-2013, 06:40 PM   #23
ride-for-life
Oddometer: 275
If you do your tires at home it will be easier when your out on a ride or carry AAA card.
Alright
ride-for-life is offline   Reply With Quote
Old 10-15-2013, 06:58 PM   #24
canadasax
canadasax's Avatar
Oddometer: 345
Originally Posted by Boatman View Post
Yup...
This is fantastic, Love it
canadasax is offline   Reply With Quote
Old 10-15-2013, 07:08 PM   #25
DELTATANGO
Motorcyclist and Dog Walk
DELTATANGO's Avatar
Oddometer: 13,882
Yup...
"Give me a long enough lever and a place to stand and I'll move the Earth."
Archawhatshisname.
DELTATANGO is offline   Reply With Quote
Old 10-15-2013, 09:24 PM   #26
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,074
On my first tire change, I ground off about 8" of the safety beads on each side. I can now pop the tire off with my hand, like a dirt bike. I did it opposite the valve stem (I think) so I could remember where to push. No chance this is ever going to come off by running it flat.
Popping it with the side stand works good too.
"Son, you can't do both"
Old 10-15-2013, 09:58 PM   #27
Yardstick
Hydrophobic
Yardstick's Avatar
Oddometer: 3,076
I wouldn't be so sure about that statement. This happened with full safety beads on the rear wheel of my 950 Adventure:
I think tires are easier to change on the big Adventure rims. Getting the bead of the tire past the safety bead is the trickiest part. I use a slightly different technique than some have mentioned. I lever 1/3 or more of the bead area toward the safety bead as far as I can and then lever the center of that section over the safety bead. Other than that, the drop center is HUGE on those rims and there is no bead lock to deal with, so the rest is cake! I have bicycle tires that are harder to change!
Yardstick is offline   Reply With Quote
Old 10-15-2013, 10:08 PM   #28
hattah79
hattah79's Avatar
Oddometer: 965
Try this
I have used this method
Works a treat
Using the bike to do the work
http://www.youtube.com/watch?v=uzgHVjXZwoM
hattah79 is offline   Reply With Quote
Old 10-15-2013, 10:39 PM   #29
Zuber
Zoob
Zuber's Avatar
Oddometer: 2,074
Ok, I'll change my statement to: cutting the bead won't increase the chance of a flat tire coming off.
I've noticed those MEFO's have a looser bead than the Scorps and pop on/off easier. Are they tube type only?
Old 10-16-2013, 01:32 AM   #30
Sumi
Sumi's Avatar
Oddometer: 1,799
Yup...
So did you manage to twist the tree out, instead of breaking the bead?!
Times are GMT -7.   It's 12:00 PM.
