Old 10-16-2013, 04:36 PM   #16
M-Cat
2 wheeled slacker
M-Cat's Avatar
Oddometer: 334
Thumb
Originally Posted by KustomizingKid View Post
Wow, fantastic work.
Nice.
Across town, across the country, around the world...every ride is an adventure.
M-Cat is offline   Reply With Quote
Old 10-16-2013, 05:20 PM   #17
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,378
Shot peening is a good idea since failures will generally be from fatigue stress cracks which grow: http://en.wikipedia.org/wiki/Shot_peening
Finding these small stress cracks is the purpose for many NDE techniques including dye penetrant and magnetic particle inspection, ultrasound and x-rays. I would have to shot peen the parts after going through all the work done so far. I really like the burette measurement setup to match volumes.
Stan_R80/7 is offline   Reply With Quote
Old 10-16-2013, 07:52 PM   #18
spafxer
spafxer's Avatar
Oddometer: 2,606
Thanks for documenting all your work.. Looks great and I enjoy seeing it.
In aircraft maintenance we've also called them stress risers ! Not to prolong a stupid pissing contest.
spafxer is offline   Reply With Quote
Old 10-16-2013, 10:33 PM   #19
4iedBandit
Road Warrior Commuter
4iedBandit's Avatar
Oddometer: 357
Originally Posted by Dewey V View Post
With due deference, I did not post these photos looking for constructive criticism vis a vis shot peening.
Please don't let the arm-chair quarterbacks get to you. I've heard of blueprinting an engine and had a general idea what it was all about, but this is fascinating! I'm looking forward to seeing the rest of the process.
Ride more, post less.
http://www.4ied.net
4iedBandit is offline   Reply With Quote
Old 10-17-2013, 01:44 AM   #20
Twin-shocker
Oddometer: 1,673
With due deference, I did not post these photos looking for constructive criticism vis a vis shot peening. I've done this long enough to know what works and what doesn't, and more importantly, why.
I thought the true gearheads among us would appreciate seeing the amount of work that goes into properly building one of these engines.
There is an old saying that goes, "those that can, do, and those that can't, teach". Maybe that should be amended to "those that can't, go on the internet and tell the doers how it's done".
Seems strange you feel that no proper checking needs doing on 40 year old engine parts, and without that not sure how you are doing a blueprint type job of building your motor?
For a top level job, I would have had the head crack tested, and checked for flat on top and bottom deck faces, if all ok have hardened seats fitted, and a proper 3 angle valve seat job done by someone with a Serdi.
Rods checked for straightness, and bearing bores for round, then NDT for any non visible defects. The rest of whats required depends on whether the bike is being used for race or road, but its always worth taking care over parts like rod bolts, as there are a lot of very poor pattern ones on the market.
Saying that though your build looks a lot better than most, and discounting the fact you have not bothered to get anything properly checked, should make the motor run a lot sweeter.
Old 10-17-2013, 06:42 AM   #21
Langanobob
Oddometer: 255
Thanks for taking the time to post your text and pictures. I rebuilt the engine in my '66 Bonneville about 1985 and you're bringing back a lot of memories; It's still going strong, although I don't ride it as much as I used to.
Bob
Langanobob is offline   Reply With Quote
Old 10-17-2013, 06:59 AM   #22
craig641
Oddometer: 5
Can you provide a little detail on what you use to polish the pistons?
Thanks,
Craig
craig641 is offline   Reply With Quote
Old 10-17-2013, 07:57 AM   #23
paulom
Oddometer: 29
As you are polishing engine parts, could you shed some light on this: I was always told by the so called "experts" that you should polish rods in the same direction, always. Is this true or it really doesn't matter as long as the end result is smooth and uniform?
Thanks for your trouble posting all this info.
paulom is offline   Reply With Quote
Old 10-17-2013, 08:45 AM   #24
stainlesscycle
stainlesscycle's Avatar
Oddometer: 2,263
beautiful work. ignore the retards, they'll always come in and criticize...it's a lot easier to pick apart someone elses work than to actually do the work yourself.... and your postings remind me how badly i need a better surface plate..
current bikes
stainlesscycle is offline   Reply With Quote
Old 10-17-2013, 08:49 AM   #25
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,973
Let me get this out of the way first, I am immensely enjoying your thread and the precision work you are doing. Thank you for taking the time to post.
Your comments are understood, but surely you anticipated some discussion and input from other " those that can do"'s.
With no intention of high jacking but to differentiate myself from the " those that can't " here's photos of a couple of swing arms for a Husky 400 XCE that I modified for the later model rear brake, had weld repaired, and then shot peened. This is NOT to say my humble efforts in any way compare with your talent.
New brake reaction lugs added to older swing arm to use newer brake
After shot peen. The arm rings like a tuning fork after shot peen.
Regards
Fritzcoinc
96 XR650L, 96 Guzzi Sport, 07 BMW K1200GT,
86 Husky 400 XCE, 00 Husky Te 610 e, 1999 Husky TC610 SM, 2000 Cagiva GC; Google: TX7
fritzcoinc screwed with this post 10-17-2013 at 09:04 AM
fritzcoinc is offline   Reply With Quote
Old 10-17-2013, 08:53 AM   #26
fritzcoinc
Enjoying my last V8
fritzcoinc's Avatar
Oddometer: 6,973
I always herd the same thing. Finish with longitudinal polish marks.
Regards
Fritzcoinc
Old 10-17-2013, 10:15 AM   #27
groundrules
groundrules's Avatar
Oddometer: 1,718
Originally Posted by Benesesso View Post
. But insecure I'm not. Why don't you look up the clever way that Chevy did their BBC heads? YOU might learn something.
Dewey, keep it up and ignore the noise. I'm interested in your project and your photos.
groundrules is offline   Reply With Quote
Old 10-17-2013, 11:48 AM   #28
Mercury264
Once you go Triple...
Mercury264's Avatar
Oddometer: 22,143
The "never built" comment wasn't directed at you, but at some of the other posters. It's obvious you've built quite a few engines. But insecure I'm not. Why don't you look up the clever way that Chevy did their BBC heads? YOU might learn something.
Please, go away.
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Old 10-17-2013, 01:26 PM   #29
MCMXCIVRS
MCMXCIVRS's Avatar
Oddometer: 1,223
It's refreshing to see that someone using the too often misapplied term of "blueprinting" an engine is actually doing just that.
I haven't built any engines in over 20 years, but spent several years of my former career as an automotive mechanic working in a machine shop building engines. We seldom did anything aside from the mundane daily runners, so it was always good when we could apply some higher level skills to a project. I fully understand your excitement at being given a long leash on this project.
Ed
2009 BMW F800GS, 2008 BMW K1200GT
MCMXCIVRS is offline   Reply With Quote
Old 10-17-2013, 02:51 PM   #30
Mercury264
Mercury264's Avatar
Oddometer: 22,143
And you are? Remember what SFR told you how envy corrodes from the inside.
Yup, he's a twat too. I couldn't be less envious of 2 people like you and him in the entire world.
If all you're going to do is come in here and criticize, why do you bother ?
'12 Tiger 800XC
'07 TE510
'02 Sprint ST
'99 XR650L
'99 Speed Triple
Times are GMT -7.   It's 09:07 PM.
