Old 10-18-2013, 03:19 AM   #1
Shenzhen OP
Oddometer: 31
DIY carbon tape heated modular vest
My main idea was to make a modular system that can be used with different clothes. I made two identical heating panels that can be combined into a single vest or attach to any outfit.
Each panel has 2 meters of carbonribbon. Chose the maximum width of the tape to provide a very even heating. Size panels 34 x 42 cm, since it is better suited for the size of my clothing.
In each panels tape connected in parallel 2x1m and has an independent power button.. It takes about 3A under 12V (36W) for each one or 72W together.
You can sew wire to carbon tape to make a good and flexible connection. The contact place shouldn't be hotter than the tape itself. If not you must increase the contact area. Sewed contact very flexible.
Contacts may be sewed by sewing machine or just wraped with a wire.
But as you can see sewed contact is colder than the tape itself (left contact).
Wraped contact (on the right) is more hotter than tape.
On each panel sewn 4 pieces of Velcro . Now I can combine them into a single heated vest . A bit like a bulletproof vest. It's very soft and thin.
Due to Velcro this vest will be comfortable to wear for a big man or a small woman.
Each panel can be used independently with any clothes.
On the inner surface of conventional jackets I sewed 4 pieces of Velcro.
Now I can at any time fix the heating panel on the jacket and make it a heated jacket.
It is fully warmed up to 40 degrees in less than one minute. By touch carbon is a little bit like a loose weave silk. It's very soft but strong enough. Because of big length it provides uniform heating of body.
Shenzhen screwed with this post 10-18-2013 at 11:40 AM
Shenzhen is offline   Reply With Quote
Old 10-18-2013, 03:58 AM   #2
TEZZA
ADV B4 DEM/TED
TEZZA's Avatar
Oddometer: 303
Thumb Market
When are you going to market these heating panels ?????
This is a great and cheap idea that could be a sailable item.
Tezza
Tezza.
KTM 990 ADVENTURE.
KTM 520 EXE.
Now the Perfect pair!!!!
TEZZA is offline   Reply With Quote
Old 10-18-2013, 04:03 AM   #3
C-Stain
C-Stain's Avatar
Oddometer: 6,685
Very neat idea. Couple of questions:
1.) Where do you find said "Carbon Tape"
2.) What is the cost?
3.) Do you use some sort of Heat Troller with it, or how do you power it?
4.) Could a old jacket be used instead of the panel, to basically make a heated jacket "liner"?
Thanks! Again, very interesting idea!
C.
Originally Posted by Mr_Gone View Post
C-Stain is wise.
C-Stain is online now   Reply With Quote
Old 10-18-2013, 06:05 AM   #4
TeneRay
2>4
TeneRay's Avatar
Oddometer: 2,213
Waterproof? Just for that "there was no rain forcasted" factor. Just hope there's nothing to short the system.
I know the other styles use hook-up wire which is still shielded in a silicone coating.
However, this setup definitely looks like it'll keep you warmer!
TeneRay is offline   Reply With Quote
Old 10-18-2013, 06:29 AM   #5
SgtDuster
SgtDuster's Avatar
Oddometer: 3,458
Click the underlined words
2010 Buell Ulysses
1984 Suzuki GR650 "Tempter"
SgtDuster is offline   Reply With Quote
Old 10-18-2013, 07:41 AM   #6
Shenzhen OP
Oddometer: 31
C.
1. "Carbon heated tape" on Ebay.
2. $ 5-15/m
3. "dc motor controller" on Ebay ($10-30)
4. Yes, I think so.
Old 10-18-2013, 08:12 AM   #7
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,624
Great Idea!
Old 10-18-2013, 04:10 PM   #8
rick505
Oddometer: 65
I wonder why it, the tape, appears to only be available (or at least all I found) from the Russian Federation??
rick505 is offline   Reply With Quote
Old 10-18-2013, 09:30 PM   #9
bensgone
bensgone's Avatar
Oddometer: 278
What is the final cost per unit?
bensgone is offline   Reply With Quote
Old 10-19-2013, 12:27 AM   #10
Shenzhen OP
Oddometer: 31
Well, in my first heated jacket was only 50 cm of tape, it's about $4,5
A longer tape provides more uniform heating. We can make a very inexpensive vest, but the area of ​​the heating element will be small, less comfort.
Old 10-19-2013, 06:10 PM   #11
tmotten
Lefthand ride Dutchy
tmotten's Avatar
Oddometer: 2,500
I'm not sure shorting is an electrical consequence with resistance wire which this basically is. It's spaced so much that I don't see it happen, but I guess it'll simply get hotter because the length if shorted due to the short.
Didn't know there was a fabric version to resistance wire. Might have to do something myself.
tmotten is offline   Reply With Quote
Old 10-21-2013, 11:30 PM   #12
Eveshka
Oddometer: 8
Just wondering as to if the carbon used in the "tape" is something special or is it just carbon fiber fabric?
Eveshka is offline   Reply With Quote
Old 10-22-2013, 11:26 AM   #13
Shenzhen OP
Oddometer: 31
Of cause it's just a kind of carbon fiber fabric.
All of them are conductive. Some of carbon fabric is more strong but less flexible, you can use it but its not so comfortable to wear and doesn't wear-resistant. This one designed especially for heaters, its more thin, soft, flexible, not so easy to wear-out.
Old 10-23-2013, 03:23 PM   #14
Eveshka
Oddometer: 8
Well I did find this on my search out there: https://www.inventables.com/technolo...n-fiber-fabric
Wonder if this would do the same. Cheaper per unit for more material...
Old 10-23-2013, 10:23 PM   #15
Shenzhen OP
Oddometer: 31
No, it doesn't. This material provides surface resistivity of 10 5 Ohms per square. "Provides excellent static discharge and grounding" only.
For heating we need about 5-100 Ohms.
Shenzhen screwed with this post 10-23-2013 at 10:54 PM
Times are GMT -7.   It's 01:06 AM.
