Old 10-20-2013, 05:16 PM   #1
eakins OP
Butler Maps
eakins's Avatar
Oddometer: 18,992
Trying to find this bolt - M8x1.25, 12.9 grd, 80mm, Socket Head (Allen), Zinc Coated
need 2 of them and for the life of me can't.
can find in black oil coated but they rust.
can find in stainless, but that is not 12.9 strength.
can find in chrome coated, but what grade is that?
12.9 and zinc coated is strong and rust-proof and that's what i want.
any ideas where?
boltdepot.com does not have.
mcmaster-carr does not have.
no go on the local hardware stores.
these guys have a box of 100 and I need 2 http://www.mutualscrew.com/Metric-St...rew-62287.html
in the end i'll use those black oil coated ones if i find nothing else, but i'd prefer the zinc coated one.
got any ideas of where online i can find?
thnx, bill
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 10-20-2013, 05:20 PM   #2
Wlfman
Wlfman's Avatar
Oddometer: 1,290
Have you tried Grainger?
I ride not to add days to my life, but to add life to my days.
Those who say it cannot be done should not interrupt the people who are doing it."
"Now and then it's good to pause in our pursuit of happiness and JUST BE HAPPY."
Wlfman is offline   Reply With Quote
Old 10-20-2013, 05:38 PM   #3
eakins OP
Butler Maps
eakins's Avatar
Oddometer: 18,992
i have but not finding it there either unless i'm searching wrong.
Alaska
Old 10-20-2013, 06:04 PM   #4
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
http://www.metricscrew-toolco.com/
Old 10-20-2013, 06:14 PM   #5
hpsVFR
Hoosier Daddy
hpsVFR's Avatar
Oddometer: 1,370
McMaster-Carr showed me:
Metric Zinc-Coated Class 12.9 Alloy Steel
Class 12.9 screws are high strength and coated with a layer of zinc for rust resistance. Size M3 screws are zinc plated; all other sizes have a coating of zinc flake, which provides 600 hours of salt spray resistance. All screws are fully threaded and have a Class 5g6g thread fit. They have a minimum Rockwell hardness of C37 and tensile strength of 174,000 psi. Dimensions meet DIN 912/ISO 4762. Screw length is measured from under the head.
Lg.,
mm Pkg.
Qty. Per
Pkg.
M8—Pitch: 1.25 mm
16 25 95263A605 $9.34
20 10 95263A619 4.73
25 10 95263A633 4.31
30 10 95263A647 4.50
35 10 95263A661 4.87
40 10 95263A675 9.47
I can't figure out how to link this selection/page, though. To get there, I started on their home page, clicked 'screws and bolts', 'socket cap screws', then narrowed down to metric, m8x1.25 using the filters on the LH side of the screen. zinc-plated class 12.9 was an option remaining.
HTH
I'll get back in the saddle again if it kills me...
hpsVFR is offline   Reply With Quote
Old 10-20-2013, 06:19 PM   #6
eakins OP
Butler Maps
eakins's Avatar
Oddometer: 18,992
HTH
that longest length they have is 40mm
Alaska
Old 10-20-2013, 06:20 PM   #7
eakins OP
Butler Maps
eakins's Avatar
Oddometer: 18,992
Originally Posted by concours View Post
thnx. i'll look into that.
Alaska
Old 10-20-2013, 06:38 PM   #8
Garp
Garp's Avatar
Oddometer: 2,447
These?
Fastenal
Garp is offline   Reply With Quote
Old 10-20-2013, 06:46 PM   #9
eakins OP
Butler Maps
eakins's Avatar
Oddometer: 18,992
too funny. i just found that and was about to post.
i might even find that at my local fastenal.
thanks!
Originally Posted by Garp View Post
These?
Fastenal
Alaska
Old 10-21-2013, 08:02 AM   #10
Wasser
Spilt my beer
Wasser's Avatar
Oddometer: 5,127
Since you live in Colorado, have you tried these guys AAA Metric
Wasser is online now   Reply With Quote
Old 10-21-2013, 10:22 AM   #11
eakins OP
Butler Maps
eakins's Avatar
Oddometer: 18,992
Thanks. That company is new to me.
If I have no luck with Fastenal, I will contact them.
...contacted them and there metric bolts are in black oiled only, which rusts.
Alaska
eakins screwed with this post 10-21-2013 at 10:30 AM
Old 10-21-2013, 10:33 AM   #12
eakins OP
Butler Maps
eakins's Avatar
Oddometer: 18,992
so Fastenal has them but not in stock in FC.
everything ordered into any store requires shipping so getting 2 bolts would cost me $6 in shipping. gonna check other local suppliers and if not i'll just pay that as I don't want rusting bolts on my bike.
These?
Fastenal
Alaska
Old 10-21-2013, 10:41 AM   #13
hpsVFR
Hoosier Daddy
hpsVFR's Avatar
Oddometer: 1,370
[in reply to my suggestion of McMaster-Carr]
Oops, I didn't see the 80mm part. Glad you've made progress on it, though!
Old 10-21-2013, 10:42 AM   #14
troidus
Oddometer: 15,083
Is the original bolt that hardness? I'd be worried about it fracturing if it's too brittle for the application.
troidus is online now   Reply With Quote
Old 10-21-2013, 11:01 AM   #15
eakins OP
Butler Maps
eakins's Avatar
Oddometer: 18,992
that is a good question and i went and verified with bolt bolts that i was not just seeing 12.9 when it was 10.9. both are indeed stamped 12.9, but i wonder if that is overkill. anyone know what other mfg use? maybe 10.9 is just fine for this application. all I know is i've dumped my bike many times on it's side and those guards/bolts have held up like a tank.
this is the guard set i use
https://www.maier-mfg.com/catalog/at...um-hand-guards
it matches very well with Protaper atv-mid bars and has plenty of lever clearance. In fact, I really like that extra bump out area of the ATV guards (vrs the straight bar in that area for dirt guards) as I grab that area all the time to control and move around the bike.
Alaska
Times are GMT -7.   It's 03:05 PM.
