Old 10-22-2013, 07:01 PM   #16
bikecat
bikecat's Avatar
Oddometer: 1,117
When my airhead failed to get pass 5K rpm, it was because of a broken ring in one of the cylinders.
I belong to the "no irregardless" camp. The "ir" is redundant.
bikecat is offline   Reply With Quote
Old 10-22-2013, 07:06 PM   #17
Plaka
Brevis illi vita est
Oddometer: 4,609
Originally Posted by batoutoflahonda View Post
Within the past week or so,...
Rather a large clue right there.
Do gas stations in your area change to winter formula gas right about now?
Old 10-22-2013, 07:16 PM   #18
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,552
I'd CAREfully check the diaphragms. Sometimes you need to gently stretch them a bit and hold them up to the light to see smaller tears in them. It doesn't take much of a hole to make a big drop in power.
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 10-22-2013, 07:21 PM   #19
Plaka
Oddometer: 4,609
it also takes little stretching and poking to turn a perfectly good diaphragm into junk. At which point you get to replace it, think you found the problem and find out you haven't.
If it is running lean at high RPM due to a diaphragm problem, it won't be on both sides. So a look at the plugs or quickly check head temps with a cheap IR thermometer to reveal the condition. Then you go looking for a cause. If you find no evidence of it running lean, go looking for something else.
OP stated plugs were normal. But he didn't state if he did a high speed chop when the power was down.
Old 10-22-2013, 07:22 PM   #20
supershaft
because I can
Oddometer: 9,116
No AW. I think it's winter mix gasoline. Slightly lowering gasoline's boil point always slows my bike down at least 20mph.
Old 10-23-2013, 12:51 AM   #21
batoutoflahonda OP
Oddometer: 1,386
A friend suggested winter gas. I dismissed it as witchcraft. Then I pondered some octane boost. Then I thought about getting a shaman and some herbs. So I settled on Seafoam as I thought maybe there was water in the gas. Seemed to cover all my bases, according to the lable. I needed spark plugs any way.
So checked the timing and all is good. It does hit the throttle stops and I have tried shifting into lower gears, but still can't get it to red line on the pass. Climbing the Snoqualmie pass, if I down shift it struggles to get back up to the speed it lost on the down shift. In a flat run I can get 7k rpm in the first three gears. 4th and 5th it won't get much over 6k @ 94 mph, fastest I could get it today. The point gap is good. I wondered about the dyna and the condenser, left it hooked up so I could switch on the road if need be.
I stuck new diaphragms in the other night, before this post. Didn't see any holes in the old ones, but wondered if they might be weak. It actually helped with the response a bit. I do notice just a very slight hesitation rolling on at part throttle. The new diaphragms actually helped with that, as it was noticeable before. Now I can feel it, but ever so slightly.
Thinking I'm going to get a new set of points and condenser on order. Check the coil. One thing I have also been pondering, is the Y collector for the exhaust rattles when I start it. This started a while ago. If I kick it, it stops rattling. Thought it was kinda amusing, but wondering if a baffle hasn't come loose and is plugging it a bit. Sucks, because all the new ones are shiny. It will just totally clash with the patina of the bike. Suppose I should bite the bullet and check compression. Would be a total bummer if it went south after two years and maybe 20k miles.
Thanks for the replies so far. And the English lesson. This bike is so cool in that runs no matter what, and through this whole thing the past few days, every thing I tweak here and there helps it run better. Probably the best I've ever tuned it. That's what has me so perplexed. Even when it's acting up, it's fun to try diagnose. It's an amazing piece of machinery.
It's eight and a half gallons of gas; and an engine. What more do you need?-- BMW R80G/S
Save lives. Legalize lane sharing.
Cow eyes don't glow.
batoutoflahonda screwed with this post 10-23-2013 at 01:17 AM
batoutoflahonda is offline   Reply With Quote
Old 10-23-2013, 01:24 AM   #22
SprintSix
Oddometer: 151
Main jet too rich? The weather is gettin colder. The term pass makes me think high elevation. Winter gas.
Add to the above your bike should have no problem breaking 100mph.
Kinda surprised supershaft didnt offer this first.
SprintSix is offline   Reply With Quote
Old 10-23-2013, 04:31 AM   #23
Stan_R80/7
Beastly Gnarly
Stan_R80/7's Avatar
Oddometer: 1,494
Sounds like it's time to check the engine compression. My low compression R80/7 shows 150 psi on each cylinder. Good luck!
Stan_R80/7 is offline   Reply With Quote
Old 10-23-2013, 06:40 AM   #24
JonnyCash
turd polisher
Oddometer: 1,613
Cold weather would ask that you richen the mixture actually. Air is denser at lower temps, more oxygen in the intake means you want more fuel.
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is offline   Reply With Quote
Old 10-23-2013, 06:41 AM   #25
Uncle Pollo
happy cachiporra
Uncle Pollo's Avatar
Oddometer: 48,236
Originally Posted by ME 109 View Post
Well I did start typing 'reach down with your left hand and'...................but then I also thought about batoutoflahonda not leaving enough parts for us.
As it is pulling redline in third, I would first suspect yo butterflies not fully opening.
this
Uncle Pollo is offline   Reply With Quote
Times are GMT -7.   It's 01:51 AM.
