Old 12-23-2013, 06:28 PM   #46
Homerb OP
Oddometer: 471
I took the Versys for a good ride last Sunday, including 30-40kms of dirt roads. Im finding with the front forks, while well sprung, the compression damping is too hard. Small bumps are transferred through the forks, to the rider.
When l modified the forks, l fitted both the Honda XLR valves to the bottom of the Versys cartridges. Think this may be my problem, as originally the Versys forks only had a compression valve in the left fork.
I pulled the forks out last night and tooks Barts advice and refitted the dampening adjuster to the right fork. I also removed the Honda compression damping valve from the right fork, and replaced the Honda valve with the original Versys valve in the left fork.
I might get out for a Xmas eve ride to see if its any better later. Otherwise l might look at reducing the preload on the front springs by shortening them a bit.
Homerb is offline   Reply With Quote
Old 12-26-2013, 12:55 PM   #47
Bart1
Oddometer: 47
It sounds like you need to set the sag first and then start on the damping.
I reduced the shim size in my compression valves here
http://www.versys.co.uk/index.php/to...html#msg131438
Also thiner oil may work as well as the above.
Good luck.
Bart1 is offline   Reply With Quote
Old 12-26-2013, 09:16 PM   #48
Homerb OP
Oddometer: 471
Good luck.
Thanks Bart. I'm wondering if some of my front suspension woes are compounded by the heavy, steel rimmed, sportster front wheel?
Before I spend too much more time on the front end, I'll replace the front wheel with something lighter. Missed out on an alloy BMW wheel the other day on ebay. Got sniped with one second to go!
Old 01-09-2014, 10:56 PM   #49
Homerb OP
Oddometer: 471
Well I finally got around to updating the headlights, wasn't happy with the look of the last lights. I picked these up at the wreckers for 90 bucks.
I'm still having dramas with he front suspension. I read somewhere that the rebound damping should be 4 times stronger than the compression damping. My compression damping is about the same as the rebound damping so I need to do something about reducing it.
Had a nice ride yesterday in the mountains near my home.
Old 01-10-2014, 08:27 AM   #50
DustyRags
Idiot
DustyRags's Avatar
Oddometer: 891
Looks fantastic!
DustyRags is online now   Reply With Quote
Old 01-10-2014, 08:45 AM   #51
Bart1
Oddometer: 47
Coming along nicely
You have mail.....
Old 01-11-2014, 12:51 AM   #52
Homerb OP
Oddometer: 471
Thanks Bart, you've cleared that up for me. I'll give it a go next week and report back.
Old 01-11-2014, 07:35 AM   #53
mousitsas
mousitsas's Avatar
Oddometer: 2,993
While this is true for the rear shock, I am not sure it is for the forks of an offroad bike. Have you tried a lighter oil?
I pressume it is the high speed compression you complain about, right?
Old 03-26-2014, 10:41 PM   #54
Homerb OP
Oddometer: 471
Well I've been riding the Versys for a few months now and while I'm pretty happy with it overall, I'm still not happy with the forks. I was going to take the bike to a suspension guru, but couldn't find one close to me, so when I found a complete YZ250 front end on Gumtree near me for just $150.....I got thinking how hard could it be to fit these
to this
Due to the diameter of the YZ fork uppers, I used the YZ triple clamps and to my surprise its almost a simple swap. The lower bearing I used is a 55mm X 30mm tapered roller bearing and it fits fine. The upper bearing is a bit trickier. I needed a 55 x 28mm bearing but no-one makes them so I used a 52 x 28 tapered roller bearing and used strips of steel to shim the upper bearing cup into the steering head. Worked OK I think. Time will tell if its tight enough.
I had to alter the spacers I made for the front wheel to centre it, but to my absolute amazement, the Versys front axle is a perfect fit in the YZ forks.
I just have to find a nut to put on the threaded end and its sweet!
Hoe it looks all bolted up
Tomorrow I'll look at fitting the brake disc and caliper.
Old 03-29-2014, 01:45 AM   #55
duxrneet
duxrneet's Avatar
Oddometer: 671
Good work. Might be worthwhile to drop it off at a suspension shop. They could revalve/respring with a bit of expertise.
Current: 2004 CBR600F4i, 2001 KTM 520EXC - Past: 1995 XR600R, 1993 DR350 (Dirt Model), 1987 CBR600F
duxrneet is offline   Reply With Quote
Old 04-20-2014, 11:09 PM   #56
Homerb OP
Oddometer: 471
Well got the YZ250 forks mounted, and the Goldwing wheel fitted after removing the right hand disc. I'm waiting on a braided brakeline to replace the Versys twin caliper lines.
Old 04-21-2014, 12:14 AM   #57
Homerb OP
Oddometer: 471
I used some 8mm ally plate to adapt the Versys disc to the Goldwing hub.
It all fits quite neatly to the YZ forks.
Old 04-21-2014, 08:16 AM   #58
DustyRags
Idiot
DustyRags's Avatar
Oddometer: 891
Bad ass! Can't wait to hear how it rides!
Old 04-22-2014, 12:17 AM   #59
Homerb OP
Oddometer: 471
I'm now waiting on the rebuilt, resprung and revalved R6 shock to arrive and I can get on with getting it set up properly.
Old 05-06-2014, 12:46 AM   #60
Homerb OP
Oddometer: 471
So my rebuilt R6 shock is fitted, the Goldwing front wheel is on and the YZ forks are sorted. Went on a 400+ km ride on the weekend and I'm really happy with the handling on road. Did some fast dirt road on the way home, and I've noticed a problem with the handling.
Due to the length of the forks, the rake and trail are more than is ideal, and this becomes apparent when trying to negotiate fastish corners on the dirt. It goes round corners like a bus!
I think I need to reduce the rake/trail somehow to something more inline with modern dirtbike figures, around 25-27 degrees.
I really don't want to alter the frame, and am thinking about some sort of adjustable triple clamp to pull in the rake a couple of degrees.
Does anyone know how I can achieve this without cutting and welding the frame?
Times are GMT -7.   It's 04:23 PM.
