Old 10-29-2013, 08:27 AM   #16
Sugar Pig OP
almost certain...
Sugar Pig's Avatar
Oddometer: 664
Originally Posted by rtwdoug View Post
Thats a handy little tidbit. I'm gonna mix some up & give it a try.
Sugar, get steves VL book at vlheaven.com
I promise it will save you time & money. he has alot of info in it.
+1 On the tip from GWW. We actually were using Kroil at one of the other guys shops. It has a much nicer burning smell than PB
I'm going to find a little metal can and mix myself up a batch of the ATF/acetone.
Doug, I have that book from Slocumb it is an excellent help on these. As you know once you get below '37 information is harder to come by.
I'm glad to see your JD coming along. We were all standing around your truck after you picked it up this spring. I was with with Sid from Tenn and Jim at the kickstart rally in some dealership (Charleston/Savannah) and we all headed up to Denton after it finished.
Current - '47 UL, '34 VLD
Sugar Pig is offline   Reply With Quote
Old 10-29-2013, 08:36 AM   #17
rtwdoug
prominent underachiever
rtwdoug's Avatar
Oddometer: 3,698
finding JD info is harder than finding VL info, theres no JDHeaven out there!
Luckily I have been meeting guys that know alot about JD's, Im sure they will get tired of my stupid questions!
dont miss Denton next year, they talked me into being the speaker at the banquet
www.motosapiens.org
My bike hotel in Bulgaria. ADVriders get 1st beer free!
rtwdoug is offline   Reply With Quote
Old 10-29-2013, 09:01 AM   #18
Sugar Pig OP
almost certain...
Sugar Pig's Avatar
Oddometer: 664
Lots of JD bits:
http://www.competitiondist.com/
I ordered some clutch parts and stuff from them this morning. LOTS of JD and a little VL and other stuff.
I can't wait for Denton, we won't heckle you I swear
Old 10-29-2013, 09:24 AM   #19
rtwdoug
rtwdoug's Avatar
Oddometer: 3,698
this is a good place for parts
http://easternmotorcycleparts.com/
but I think they only sell to dealers. I'm working on getting set up as a dealer, so if you need anything, let me know
www.motosapiens.org
Old 10-29-2013, 10:07 AM   #20
cyclefreak13
cyclefreak13's Avatar
Oddometer: 125
These guys sell some go fast goodies for the JD, and other early bikes.
http://earlyharley.com/index.php
81 R80G/S
06 F650GS
09 R1200GS
And many more bikes.
cyclefreak13 is offline   Reply With Quote
Old 10-29-2013, 10:41 AM   #21
gww
Oddometer: 45
Doug, what info are you needing? sure no expert but know a little. we met on last yrs. cannonball. #57
777s on all that have and all that do protect our freedoms
http://wrightwelding.wordpress.com/
gww is offline   Reply With Quote
Old 10-29-2013, 11:43 AM   #22
rtwdoug
rtwdoug's Avatar
Oddometer: 3,698
nothin specific yet, just wish there was a good book on JD's
I dont wish it enough to be the guy to write one, but would be nice if someone else did :)
www.motosapiens.org
Old 10-30-2013, 05:25 AM   #23
Sugar Pig OP
almost certain...
Sugar Pig's Avatar
Oddometer: 664
A quick look in the transmission. This is a sliding three speed, so that shuttle to the far right slides back and forth to lock the different gears. Despite the poor appearance of its shaft it slides very easily. I may still replace the shaft as there is not much to it and it probably is inexpensive. The fan shaped piece has a claw underneath that grabs the circular object in the middle and moves it side to side.
Luckily everything look decent. I will replace what ever parts are available and run with it.
Next up is the oil pump. The motor appears in good shape and may have been rebuilt and then sat. We won't be able to gauge its condition until I can run it. It seemed prudent to clean out the oil pump as the bike has been sitting.
It works like a two stroke jetski. You can see the baseline setting to the left with 'more-less' and then the arm on top is attached to the throttle. The more throttle, the more oil.
Don't forget kids this is a total loss motor and has no recirculating oil. This pump feeds the crankpin and then it just bangs around in there and goes to the chains and provides fragrance for those who follow.
The worm gear that drives it, this hidden grunge makes me question whether the motor is rebuilt or not.
The wedge on the piece to the left is attached to the 'more-less' adjuster and slides depending on where you set it. The crazy wheel on the right spins and presses the pumper on each rotation.
All done, I'm out of solvents so cleaning will have to wait for a trip to the store. Lots of little parts, but everything was in great shape. I will replace the gasket and a check ball but that's it. Was a little grungy and I feel better having taking it down.
Sugar Pig screwed with this post 10-30-2013 at 07:26 AM
Old 10-30-2013, 07:21 PM   #24
argentcorvid
Some Guy
Oddometer: 492
Oh, OK, not sure what I was thinking, but whatever it was it was way more complicated than that.
Very much similar to the transmission in my buddies dirt track race car!
argentcorvid is offline   Reply With Quote
Old 10-31-2013, 02:51 PM   #25
ttpete
Rectum Non Bustibus
Oddometer: 5,940
What strikes me is the pristine appearance of the nuts and screw slots. This is the first thing I look for. It makes me wonder if it's ever been apart. Everything seems so crisp and nice.
I'm going to make a suggestion. Roller and ball bearings can etch from acids in used motor oil over time. You might want to split the cases and have a look, it may save you from having to do the job over if the bearings need to be changed.
15 BMW RnineT
09 Kaw Versys
Old 11-01-2013, 04:11 AM   #26
Sugar Pig OP
almost certain...
Sugar Pig's Avatar
Oddometer: 664
The bike really is exceptional in that regard. Everything on it looks like it hasn't been apart. It's hard for me to wrap my head around that no one has screwed with it for 80 years.
Where did it sit that it was protected for all that time? It has original sheet metal and appears to have been a complete bike based on a few little things. All I know was that it was in New Jersey before Wisconsin.
The mystery of it all is one of the most fun parts for me.
You are right about splitting the cases but I think I will fire it up and see what I have first. Just to play devils advocate a little the rods in the VL run in bushings not roller bearing like EL and UL and I think the only roller bearings are in the cases them selves. Also since it is total loss presumabley the oil was cleaner inside of it than a recirculating motor. Since the rods would be fed only from fresh oil from the tank no acid should be present. We'll see what I decide in the end, but that would be the most prudent route.
Old 11-01-2013, 04:20 AM   #27
HOT DAMN!
HOT DAMN!'s Avatar
Oddometer: 7,633
Once in a while you get shown the light in the strangest of places if you look at it right
HOT DAMN! is offline   Reply With Quote
Old 11-01-2013, 04:34 AM   #28
verdelac
Rust never sleeps
verdelac's Avatar
Oddometer: 286
Good thread, thanks!
I'm hooked.
Sure.
verdelac is offline   Reply With Quote
Old 11-01-2013, 07:41 AM   #29
DireWolf
Knees in the Breeze
DireWolf's Avatar
Oddometer: 13,264
Yow!
DireWolf is offline   Reply With Quote
Old 11-01-2013, 08:33 AM   #30
ttpete
Rectum Non Bustibus
Oddometer: 5,940
Another reason to split them would be to use a modern sealant to avoid leaks. I know they all drip from the primary case by design, but the less the better.
15 BMW RnineT
09 Kaw Versys
Times are GMT -7.   It's 04:17 AM.
