Old 10-24-2013, 11:46 AM   #1
skidxr OP
Excuses
skidxr's Avatar
Oddometer: 397
4 Barrel Carb or not?
I have an old (1978) Minnie Winnie class C motorhome on a Dodge 1 ton van chassis with a 360 motor. It currently has a 2 barrel carb on it and I'm wondering if it would be worth it to install a 4 barrel carb and manifold. I'm looking for more pulling power. It already sucks down the gas so mileage really isn't a concern.
Thank you...
skidxr is offline   Reply With Quote
Old 10-24-2013, 11:52 AM   #2
uraberg
whosaberg?
uraberg's Avatar
Oddometer: 700
The question is, do you want pulling power at low rpms or at higher rpms. In a simplistic view, this is the difference between a 2 and a 4 barrel carb.
You might be able to better tune your carb, or look into a 4 barrel progressive.
uraberg is offline   Reply With Quote
Old 10-24-2013, 12:40 PM   #3
ttpete
Rectum Non Bustibus
Oddometer: 6,159
What you have is a 35 year old vehicle that is probably overloaded when packed to travel. Weigh it ready to go on a trip and compare that with the GVW plate on the door jamb. It eats gas because you've got your foot in the carburetor most of the time. I'll bet you get around 6 or 7 MPG, and that's not unusual for pushing a square box that probably weighs 5 tons or more down the road.
I don't see where a 4 barrel carb will be worthwhile. Holley makes a 500 cfm 2 barrel carb, and you might keep that in mind. But you'll need someone to set it up and jet it properly. That 360 is just too small for the application. It should have had a big block 440 in it with enough torque to cruise easily.
2015 BMW R9T, 2010 Ducati 1098 Streetfighter S
2009 Kaw 650 Versys, 1967 Triumph 650 TT Special
Old 10-24-2013, 12:46 PM   #4
gravityisnotmyfriend
gravityisnotmyfriend's Avatar
Oddometer: 1,651
I"ve got a 1978 Ford Econoline Camper. It's got a 351 with a 2 barrel. My mechanic told me that I'd actually get better gas mileage if I put a 4 barrel on it. He says that the 2bl restricts too much airflow. If I had a 4 bl I wouldn't be sticking my foot all the way in the carb so much.
The guy is pushing 80 and has been turning wrenches all his life. He's never been wrong when it's come to any car problems I've taken to him, so I take his advice pretty seriously.
I rarely ever drive that rig, so I'm not too terribly bothered by the 2 bl carb, but that's one seasoned mechanic's advice.
gravityisnotmyfriend is offline   Reply With Quote
Old 10-24-2013, 01:40 PM   #5
JonnyCash
turd polisher
Oddometer: 1,654
I think you'd do better with a progressive 4bbl carb, as your mechanic says. In most of your driving, you'd be running on 2 small venturis, which works better for a light load, and then for acceleration or hill climbing, you'd have the big secondaries in reserve. Would it be worth the cost, I have no idea, because I don't know what it would cost.
I wouldn't bring her home to Mama, but Mama ain't home tonight.
JonnyCash is offline   Reply With Quote
Old 10-24-2013, 02:04 PM   #6
skidxr OP
Excuses
skidxr's Avatar
Oddometer: 397
Thanks all.. I figured I would do it if it was a no brainer. I was just thinking about turd polishing when I noticed your status Johny.. To funny.
Old 10-24-2013, 02:05 PM   #7
kubiak
Oddometer: 4,845
if i remember correctly get a 4 barrel spreadbore carb. smaller primaries and big secondary bores. it will run on the primary bores cruising around getting better mpg then if you need more power floor it and the big secondary bores open up. i would look for a small cfm 4 barrel like a 450 to 600 though.
Old 10-24-2013, 05:32 PM   #8
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,433
Changing to a four barrel would be a lateral move. That 2 bbl flows all the air/fuel that engine needs at the speeds it's being used at.
Many, many myths stated above. Spend the money on beer/fuel.
Old 10-24-2013, 06:08 PM   #9
Motornoggin
Two-Bit Throttle Bum
Motornoggin's Avatar
Oddometer: 21,282
A 4bbl conversion would help. Might not notice a huge difference, but if the 2bbl is old and out of tune, it might make a pretty big difference.
A cam change to a modern dual pattern cam would help even more, but that entails a LOT of work, especially in a van cab...
I say go for it, you can buy an intake and carb for between $500-$600. If you're equipped to do the work yourself, it won't cost a lot more than that. Also, make sure everything else is up to snuff, ignition, plugs, wires, etc... Not going to do you any good if it's not tuned up. A '78 will have a low compression engine too, might bump the initial timing by 2-4 degrees and maybe even play with the curve. Would improve response and maybe even help fuel economy.
Exhaust; what kind of shape is it in? Coated headers would help. Doesn't have to be loud with good mufflers.
O.K. Joke's over. You can bring back the constitution now. Please.
My Wyoming has an East infection.
http://motornoggin.smugmug.com
Motornoggin is offline   Reply With Quote
Old 10-24-2013, 06:33 PM   #10
RVDan
RVDan's Avatar
Oddometer: 2,715
Often switching to a 4 bbl will provide more even fuel distribution resulting in better fuel economy and mid range power
Sometimes wheelies happen
Originally Posted by RedRocker
You can never have too much hook.
RVDan is offline   Reply With Quote
Old 10-24-2013, 07:23 PM   #11
ragtoplvr
Oddometer: 6,635
if it does not have it you need a dual exhaust with at least 2 inch pipe or a super single with 2.5 inch diameter pipe, good big tube muffler. Glass packs are too loud for that hard working a motor. Big muffler, silence without backpressure.
I like the AFB carb, easy to jet, good fuel atomization. 360 jetting and correct aluminum manifold and air cleaner are easy to find. You should be able to find a stock type closed filter housing with snorkel that will make things a lot quieter.
As stated changing to a good cam will help a lot too. Pretty big PIA in most motor homes.
And you will never ever save enough gas to begin to pay for this.
Rod
ragtoplvr is offline   Reply With Quote
Old 10-24-2013, 07:42 PM   #12
troidus
Oddometer: 16,289
Put a 5.9 Cummins in it. More work, but more satisfying when you're done.
If you do the 4bbl, use a spreadbore. The smaller primaries will help off-idle response and part-throttle fuel economy as long as you can keep the secondaries closed. Make sure it's a vacuum secondary carb, not a mechanical one.
I wouldn't put dual exhaust on it. You want exhaust velocity to keep your low rpm torque up. If you still have a cat, you may want to make sure it's not clogged.
troidus is offline   Reply With Quote
Old 10-24-2013, 07:46 PM   #13
broncobowsher
broncobowsher's Avatar
Oddometer: 1,888
Rod
So true! But as originally stated, doesn't care.
Getting the right mix and good atomization are needed for best power, best economy, and actually do a pretty good job at running clean emissions as well. The 2-barrel can be good. A 4-barrel generally can be better. The trick is actually getting it tuned right. I know a lot of people who can tune so it runs good, but when checked with a good wide band exhaust sensor they are always off. Tune with a wide band and it gets better. More safe power on less gas.
You may want to try that with the stock 2-barrel carb first. Many heavy duty applications were set to stupid rich for "engine cooling" under heavy loads. That is if the stock 2-barrel isn't wore out already. Sloppy throttle shafts, melted boosters, delt with lots of this crap. Time for new carb, might as well make it a 4-barrel.
Good RV cam and sufficient exhaust are also good upgrades.
broncobowsher is offline   Reply With Quote
Old 10-24-2013, 08:47 PM   #14
RidingAgin
RidingAgin's Avatar
Oddometer: 408
I second this advise, although not 80 yet....
Having a clean new rebuild will make a difference IMO. Good luck to you.
08 R1200GS, 11 F650GS twin
RidingAgin is offline   Reply With Quote
Old 10-25-2013, 06:13 AM   #15
red83gt
Oddometer: 53
If u want all the benefit from a 4bbl carb on your motorhome you will need to swap out the camshaft..The 360 came in both 2 and 4bbl versions.The 4bbl has a different cam to allow for more flow in and out of the heads..My suggestion would be to get an edelbrock performer intake,cam and carb.These pieces work real good together and provide good low rpm torque between 1,100 to about 4,000 rpm,,about where your real world driving range in a motorhome is..Your mileage might increase a smidge,but you will pull hills much easier and accelerate better in traffic and such..and 600 cfm carb is as big as you need to go.I wouldn't rule out a holley carb with this set up either,its a little cheaper..I prefer the holley,,(easier to work on)the edelbrock carb looks like the old Rochester quadrajet but its better than a quadrajet.Now lets talk headers,,LOL,actually a duel exhaust with 2 inch pipe from your stock maifolds will be sufficient,exit out the sides in front of your rear wheels,,sound will bad ass!!just my .02.
red83gt is offline   Reply With Quote
Times are GMT -7.   It's 02:46 AM.
