Old 10-25-2013, 05:39 AM   #1
trailer Rails OP
trailer Rails's Avatar
Oddometer: 3,378
Transmission cooler lines
My 1993 ford ranger tranny lines finally rusted out. Can I just replace the metal lines with rubber fuel line? What kind of pressure is in those lines?
trailer Rails is offline   Reply With Quote
Old 10-25-2013, 10:55 AM   #2
trailer Rails OP
Oddometer: 3,378
Originally Posted by Benesesso View Post
No. Pressure is too high for the usual fuel tubing.
Where can I get some of the rubber tubing that they use to make the bend up to the cooler? It would be much easier to run rubber tubing than try to replace all the metal tubing.
Old 10-25-2013, 11:23 AM   #3
bisbonian
bisbonian's Avatar
Oddometer: 1,026
You can get transmission cooler hose at any good auto parts store.
Fuel hose is not normally oil resistant and will swell.
My 2009 Alaska Adventure
bisbonian is offline   Reply With Quote
Old 10-25-2013, 11:32 AM   #4
trailer Rails OP
Oddometer: 3,378
Makes sense.
I did a little googling and it looks like it is recommended to put a flair of some type on the line because a regular hose clamp will not hold.
Old 10-25-2013, 01:16 PM   #5
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,190
Fuel hose and ATF transmission hose are different compounds. Fuel hose on a trans cooler will melt in about a day, maybe less. Use trans line for transmission and fuel line for fuel. That's all. Oh. The correct hose can take that pressure.
---Albert Einstein
disston is online now   Reply With Quote
Old 10-25-2013, 02:00 PM   #6
ttpete
Rectum Non Bustibus
Oddometer: 5,758
Originally Posted by trailer Rails View Post
Makes sense.
You need to bead the end of the tube. I do it with my flaring tool. I start by setting the tube height in the block for a double flare and put the double flare button in the tube end. I then tighten it down just until there's a usable bead, not all the way. Use a small worm gear clamp, or two if you feel so inclined.
15 BMW RnineT
09 Kaw Versys
Old 10-25-2013, 07:12 PM   #7
gsweave
Yinz, blinkers are on.
Oddometer: 11,440
Makes sense.
Just did it to my POS 01 F150 this summer....
Transmission hose from CARQUEST. Cut the rotted tubing cleaned up with 220 grit paper used fuel line clamps. So far so good. not much pressure in cooler lines.
P.S. Carquest couldn't source replacement steel lines for system... Had to rig up something
1Paul 2:15
For it is God's will that by doing good you should silence the ignorant talk of foolish men. 16 Live as free men, but do not use your freedom as a cover-up for evil;... .
gsweave screwed with this post 10-25-2013 at 07:20 PM
gsweave is offline   Reply With Quote
Old 10-27-2013, 04:50 AM   #8
tvpierce
tvpierce's Avatar
Oddometer: 369
Originally Posted by gsweave View Post
Not much pressure in cooler lines.
+1
When you flush a tranny via the cooler line, it takes several seconds to pump a quart, and it doesn't come out with much force.
My guess (and it's a total guess) would be that the pressure is less than 10psi.
The laws of the road are superseded by the laws of physics.
"But I had the right of way!" makes a pretty crappy epitaph.
tvpierce is offline   Reply With Quote
Old 10-27-2013, 08:37 AM   #9
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,544
Back in the days in the rust belt the fitting at the radiator was often so seized that we just cut the metal line with a pipe cutter. 2 compression fittings and a new piece of steel line, that's what? 15 minutes work???
Have tools, will travel!
H96669 is online now   Reply With Quote
Old 10-27-2013, 02:46 PM   #10
troidus
Oddometer: 13,779
Why not get a tubing bender and a flaring kit and make new steel lines? If your transmission lines rusted out, your brake and fuel lines probably aren't far behind.
troidus is online now   Reply With Quote
Old 10-27-2013, 06:08 PM   #11
trailer Rails OP
Oddometer: 3,378
Those are all done in the last couple years. Tranny is the last one.
Old 10-27-2013, 07:54 PM   #12
facetjoint
TONKA
Oddometer: 5,607
You can NOT use rubber fuel line! The ATF will come apart inside in small pieces and trash the tranny. Go to a NAPA or Carquest type store and get 5/16 or 3/8 inch id. tranny hose and some #6 hose clamps. put two clamps at the end. Then you get no leaky!
facetjoint is offline   Reply With Quote
Old 11-04-2013, 05:34 AM   #13
trailer Rails OP
Oddometer: 3,378
I decided to take on this project this weekend. The first big step was to clean the garage out so I could get the truck in.
As I pulled the truck in the garage, the transmission lost enough fluid that it would not move anymore, I had to use a come along for the last 10'.
Once I got the truck up in the air, I discovered the side tank on the radiator was leaking.
Next struggle was the lines at the transmission, there was no clearance to remove them. After a trip to NAPA, I picked up a crows foot wrench and I cut up one of my open end wrenches into something smaller. I was able to remove the transmission side of the lines.
While at the store I loaded up on some pre-made hard line.
On the transmission side I used a 2" section of hard line as a nipple to connect rubber hose to. I put a small flair on the line and double hose clamped the rubber line.
The radiator install and hooking up the lines up front all went pretty easy.
Took it for a drive and it shifts great. Might even be smoother than before.
Old 11-04-2013, 06:18 AM   #14
Slvrtundevl
Slvrtundevl's Avatar
Oddometer: 500
Did it many times... Fuel line and hose clamps.... Depends on how long you plan on keeping the truck...
Come to the darkside....We have Cookies!!!
2010 KTM 990
Slvrtundevl is offline   Reply With Quote
Old 11-04-2013, 09:28 AM   #15
troidus
Oddometer: 13,779
I wouldn't want to screw over the next owner like that just to save a couple of bucks. Besides, I wouldn't want it to fail again on me, either.
Times are GMT -7.   It's 09:26 AM.
