Thread Tools Rating: Thread Rating: 33 votes, 4.88 average. Display Modes
Old 12-13-2013, 10:06 PM   #151
Parepin OP
The Filthy Nomad
Parepin's Avatar
Oddometer: 1,127
The silence around here is deafening.
For what it's worth, I DID have the forsight to pop the neutral terminal when I got to disconnecting the starter. I never once arced across to anything during this whole surgical procedure. When I went to throw the terminal back on after pulling the starter, I noted the lack of power to the tunes. I knew the risk, took the chance anyway.
Parepin is offline   Reply With Quote
Old 12-14-2013, 12:37 AM   #152
discochris
discochris's Avatar
Location: Sometimes the Twin Cities, Sometimes NW Wisconsin
Oddometer: 1,329
Originally Posted by Parepin View Post
While the engine is out, any suggestions as to how I should take on the engine bay? I'm looking at cleaning it and hitting it with some sort of truck bed liner. Herculiner is a bit rough for my taste, I was hoping to find something with a smoother, hammered like finish. I think Duplicolor has that covered. What about noise isolation?
Also, if there are any pics that you guys would like me to grab while I can, I'm all over it like a fat kid on a cupcake.
First of all, this thread is all kinds of awesome. Thanks for sharing!
For the engine bay, I'd look at something like POR-15 or Zero Rust. I have an old trailer that sits outside in Minnesota 365 days a year, and POR has held up well on it. I used Zero-Rust (similar product) on the frame and floorpans on my 66 F-100, and it's really held up great as well. A lot of the things I've used store-bought bedliner on have been hit or miss.
discochris is offline   Reply With Quote
Old 12-14-2013, 05:38 PM   #153
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,542
Good on ya for jumping right in on it.
I will enjoy following your progress.
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is offline   Reply With Quote
Old 12-14-2013, 07:21 PM   #154
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,718
Good job with the tie down straps. But you'll probably need the lifting hooks that GM always leaves on their engines to install the new one. I'd give you a couple but I am too far.
Got that radio hotwired yet????....may just be a matter of finding the fuse and powering it with a jumper in a shade tree kind of way, should work. But yes clean up the wiring, lots of smoke came out from under the plywood floor in one of my vans. Darn POs running unfused powered "stereo" wires under the plywood floor.....was fine until one morning when I put some weight over it.
Another one I bought, the PO told me...."When I need a wire I just run another one!" Holy crap the fire hazards I found in that one and all Yellow wires he must have bought a big roll, I sure haven't bought yellow ever since.
Have tools, will travel!
H96669 is online now   Reply With Quote
Old 12-14-2013, 11:06 PM   #155
troidus
Oddometer: 15,452
I've bolted the lift chain straight to the accessory bosses in the heads if the lifting eyes were gone. The PO probably ditched the lifting eyes when he installed the aftermarket manifold. Maybe they didn't fit, but most likely he didn't think they were necessary. (Ha!)
troidus is online now   Reply With Quote
Old 12-15-2013, 02:31 AM   #156
xymotic
xymotic's Avatar
Oddometer: 8,367
See, it's one thing to be an idiot and not know better.
But it's a whole nuther thing Fully knowing 'wassup' and just deciding to rock on anyway! As I was reading the starter-for-music part I was laghing thinking that's something I would do.
This has potential to be best thred evah!
Originally Posted by Just_Sean
Oh for ***k's sake Aaron. Please link us to my fascist, racist or homophobic posts.
"Anyone who doesn't take truth seriously in small matters cannot be trusted in large ones either."
Albert Einstein
Baja trip to the tip
6:10 to Yuma
trials and tribulations in the Mojave
Baja Blitz Yard sale
View Current Location via Spot Tracker
xymotic is offline   Reply With Quote
Old 12-15-2013, 01:44 PM   #157
HapHazard
Waiting for Gudenov
HapHazard's Avatar
Oddometer: 2,314
I'm lucky to have 2 friends with these lifting plates, they work well. Not necessary, but nice to use.
http://www.jegs.com/i/JEGS-Performan...oductId=752798
HapHazard is offline   Reply With Quote
Old 12-15-2013, 03:33 PM   #158
KSJEEPER
KSJEEPER's Avatar
Oddometer: 4,399
Just to cheer you up, when I first pulled a motor out of a new to me 67 Firebird, I had never done such a thing and went about it using common sense.
And it all turned out great, I learned alot, and its a burn-out machine
Good luck!
2002 KLR650 - 2007 HD Electra Glide
'It doesn't matter how big a ranch ya' own, or how many cows ya' brand,the size of your funeral is still gonna depend on the weather.' Harry Truman
"Death smiles upon us all, a U.S. Marine smiles back"
KSJEEPER is offline   Reply With Quote
Old 12-15-2013, 05:09 PM   #159
TEXASYETI
Call me "thread killer!"
TEXASYETI's Avatar
Oddometer: 1,920
I overhauled an 85 FJ60 land cruiser in my carport a few years ago. Pulled the engine on a pea gravel/dirt driveway. Granted, it wasn't winter but it was the summer we had over 100 days straight of 100 degree temps.
You are doing a great job!
This will end well.
BobFV1 to Putts: "Congrats on the bike. Also, congrats on having a dog with a perfectly heart-shaped asshole."
1981 R80G/S
1991 R100 GSPD
FIRST TIME RIFF RAFF - Go Jonah!
TEXASYETI is offline   Reply With Quote
Old 12-15-2013, 05:22 PM   #160
Parepin OP
The Filthy Nomad
Parepin's Avatar
Oddometer: 1,127
I spent a massive amount of time doing some research as far as a coating goes. In fact, I've still got the window open with something like twenty or thirty tabs. I even found this bad ass experiment that someone did:
http://www.thesamba.com/vw/forum/vie...er=asc&start=0
I'm torn between one of two options, both with plenty of pros and cons. I figure I could hit it all with a good truck bed liner, like I had mentioned. I found a few that really appealed to me, including:
U-Pol: http://www.tptools.com/U-Pol-Raptor-...-Kit,2600.html
Al's Liner: http://www.realtruck.com/al-s-liner-...-on-bed-liner/
Moonstaliner: http://www.monstaliner.com/
All of these are two part liners, which seem to make a huge difference as far as durability, chemical resistance, and UV resistance goes. I like the idea of having a thick, rubberized coating to not only add protection but to help deaden the metal and add a bit of soundproofing to the whole rig. They're all pretty comparable in pricing, at roughly $100-$150 per 50 square foot. The downside is that they don't stick to anything that's even the slightest bit rusty, and all insist that if there is a rusty surface to be coated, it should be hit with a rust encapsulator first, like Por-15, RustBullet, or Chassis-Saver. That brings us back to the paint.
The paint that I've seen that seems ideal, listed above, which are also all comparable in pricing. Somewhere around $30-$50 for a quart, which covers something like 100 square feet. From what I've heard, they all have a tenacious bond when the surface is treated right, and are fairly flexible. Application differs, anywhere from being sprayed on to rolled on to brushed on, and all seem fairly durable. But, then again, they go on thin, probably wouldn't take to a beating all that well, and will offer nothing to help soundproof any of the body panels. And POR-15 is shit when it comes to UV resistance, though that may not be an issue so long as I can keep the van on it's wheels for days at a time.
Then again, I've also seen a couple of forums where people insists that the best way is to buy a case of Rustoleum Rattle Cans and go to town, then forget about it. I know from experience that, while it holds up okay, it'll melt if it even smells any sort of chemical. These are the kind of posts that make me thing that maybe I'm over thinking all of this. I'm trying to walk a fine line between a budget build, and "Doing it right". I could easily dump several grand in a coating that just scrapes of with a finger nail, but I'm trying to find the one that won't break the bank and will get done what I need it to do, once I figure out exactly WHAT that is.
The radio fiasco... Okay, here's the deal. I found some speakers kicking around here and hooked them up to this surround sound unit that I fished out of a dumpster at work, back in Cali. They're blown. I found a CD/Tape deck stereo in the loft, but the CD player doesn't spin (DaFoole left a wicked stash of CDs here). The radio works, but the only stations I'm getting in the valley here is Gospel. And, of course, the speakers are toast. So I had my MP3 player hooked to the stereo in the van. I, for whatever reason, cannot STAND silence. I need to have something going at all times, even if it's just a fan.
I eventually went way into CoosBay and picked up a tape deck adapter, which now seem to be worth their weight in gold, and am listening through the piece of shit stereo.
And as far as the wiring goes, yeah, it's probably 50 percent add on at this point. A mix of glass, blade, and mini blade fuses. Plenty of two strand stereo wire, twisted together at both ends, and crimped together. One wire that I traced from the fuel selenoid was comprised of four different length of wire all crimped together, run through the frame, wrapped around the dipstick tube like a candy cane, and stuck through a hole in the firewall that was then sealed with orange RTV. Fun stuff.
I found a short length of chain in the trash. I may throw some big washers behind a couple bolts and see if I can get them mounted right to the block. If not, I'll fall back on the ratchet straps.
Didja like how I used that as an excuse? As if it made it all okay. "Pff, yeah, I knew it was going to do that."
Old 12-15-2013, 06:05 PM   #161
troidus
Oddometer: 15,452
POR-15 first to convert/encapsulate the rust, then your preference of rubberized coating. That'll protect the POR-15.
Sounds like the harness is a disaster. I poked around a bit and couldn't find any repro units, but I'd be surprised if they don't exist. If no one makes a repro harness, there are "universal" units. Electrical is my least favorite iffyness in a vehicle.
Old 12-15-2013, 06:19 PM   #162
Parepin OP
The Filthy Nomad
Parepin's Avatar
Oddometer: 1,127
This will end well.
I dropped the transmission out of my ranger back home in a crushed gravel driveway in November. I was a month out of surgery for a shattered femur/hip. My neighbors would watch me hobble out of the shed with my cane, drop down next to the truck and roll beneath it. Whenever my parents doubt my ability to get something done, I default back to that.
PICTURE TIME!!
After the hours of coating research, I realized that a lot of which way I go depends on the condition of the body, frame, and components to be coated. This, of course, I wasn't really sure of. So I spent a day with a herbicide sprayer filled with dish soap, pine sol, 409, some purple stuff, and boiling water, followed with a power sprayer jimmy rigged to a gravity fed water tank, and this is what I found.
Passenger side of the engine bay.
Driver side, with steering stem... wheel.... knuckle.... thing
Driver side
Strut Mount. Looks good. No rust. That seems to be the original rust-colored paint. There was a rubberized coating on there that the power washer did a good job of knocking down.
Steering linkages
MONSTER brake rotors.
Awesome Cherry Bombs that dump out just behind the drivers door. These will eventually be replaced, and possibly, rerouted. If I'm smarter about how the pipes are run, this will leave a nice void that mirrors where the auxilliary tank is. I figure I could either mount a third fuel tank, for fueling up motos, or a water tank for showers, drinking water, etc.
Turbo 350, complete with mysterious pan leak.
This is really the only cancer I've been able to find other than minor surface rust. I'm not really a body guy, but I'm willing to learn. I'll strip this down at some point to get a better grasp on how bad it is, then either fiberglass and bondo it, or seal over it with a piece of sheet metal.
I still can't wrap my head around this. At one time, this van was sparkly. For real. That's purple glitter. It's all over the body where the black has chipped.
Passenger side
This is the flange that bolts up to the right side header. It's got a pretty wicked crack 3/4 of the way around. I'd like to think I can just get it welded, but I'm not sure what it's made of. If it's cast, it could be an issue. On the other hand, this is more or less a straight pipe of 18" that might just as easily be replaceable.
Auxilliary tank filler neck. I don't know what jackhole thought this up. Not only is it in the wheel well, where California Vapor sucking nozzles won't fit, but it's on the opposite side of the stock filler location. This will be changed up. I figure I'll either connect it, somehow, to the stock tank so that the one filler neck fills both tanks, or I'll just cut a hole in the body next to the stock filler location and install a second filler. I'd hate to have to cut into the body, though...
Stock fuel tank. Relatively good condition except for one good dent, center of the image. The auxilliary tank is also in fairly good shape, though it has a bit more rust to it than any other part of the van.
I popped the moon roof and removed some of the inside paneling to do some investigation. I noted some bondo here where the previous owner had chipped away a bit. It's just next to the moon roof opening itself.
Obligatory Carl. This isn't one of those "Quick, Honey! Grab the camera!" moments. He does this all the time. Sometimes I have to push it back into his mouth for him lest he look a fool.
The rest of the roof looks pretty straight and solid.
Directly beneath the bondo.
It looks like a chunk of the roof may have been replaced at some point.
I also noticed that the roof panels are in no way connected to the supporting ribs. I can push down on the roof a bit until it contacts the rib. I assume this is normal as I see no factory weld marks or holes for hardware.
Wheel well. Rust free.
I apologize for the image heavy post. I like to be thorough. Questions? Comments? Plans? Feedback?
Old 12-15-2013, 06:57 PM   #163
madeouttaglass
The AntiHarley
madeouttaglass's Avatar
Oddometer: 3,599
That lack of serious rust must be a treat for a guy from Lyons. Back home those turned into piles of dust decades ago.
Our ride across the USA on a Ural Gear Up- http://www.advrider.com/forums/showthread.php?t=781149
Escape from NY- http://advrider.com/forums/showthread.php?t=955520
madeouttaglass is offline   Reply With Quote
Old 12-15-2013, 07:00 PM   #164
boardrider247
Weekend Anarchist
boardrider247's Avatar
Oddometer: 768
I've used POR 15 a few times.
When properly applied it is actually very tough despite how thin it is. You can hit the shit with a hammer and it won't chip. Also it was originally designed for vehicle frames and underbody so it isn't that uv sensitive.
All that being said if you aren't able to properly prep the area it falls off. Been there done that. In your case I wouldn't bother. I would just spray everything with the rattle can underbody liner and be done with it. The good news is vehicles in Oregon don't rust out all that quickly.
Keep it up you have a good thing going
Life is a waste of time, Surfing is a great way to waste it
boardrider247 is online now   Reply With Quote
Old 12-15-2013, 07:03 PM   #165
WeazyBuddha
Carbon-Based Humanoid
WeazyBuddha's Avatar
Oddometer: 4,959
No apologies needed for the pics, we like pics
You certainly seem to be one of the most tenacious inmates
A drunk driver killed someone I love
WeazyBuddha is offline   Reply With Quote
Thread Tools
Times are GMT -7.   It's 07:37 AM.
