Old 10-26-2013, 03:47 AM   #1
Hiho OP
Oddometer: 49
Two new hacks
G'day,
So we have about recovered from our misadventure in Tassie last January and now are on a bit of a mission.
I have been asked to build a side car for the Black Dog Ride in Oz next year. It will be a bit different to normal and all will be revealed as the build advances.
While we are doing this I will also be doing my new modified hack for the Roadliner. So this will be a Dual build thread.
Some brackets have been cut and a few parts have arrived from USA. Progressive shocks on both hacks, linear actuator on mine to allow variation of ride height. Radiantz rear tail lights.
The design of the body is finalised for both of them and will be lazer cut ready for me to start wheeling.
Next week end will see the start of the subframe for the Moto Guzzi Bellagio.
See you soon.
Hiho is offline   Reply With Quote
Old 10-26-2013, 07:20 AM   #2
Dan Alexander
Ride Far - Ride Fast
Dan Alexander's Avatar
Oddometer: 7,527
Beemers Past and Present: 74 R90S, 77 R100RS, 85 K100RS, 2x 87 K100RS, 96 R1100GS (getting hacked), 99 R1100S, 2002 R1150GS, 2005 F650 Dakar, 81 GL500/Velorex
Plus the occasional Triumph, BSA, Yamaha, Honda, Suzuki and KTM but who's counting
Dan Alexander is offline   Reply With Quote
Old 10-27-2013, 04:41 AM   #3
kshansen
kshansen
Oddometer: 190
kshansen is offline   Reply With Quote
Old 10-27-2013, 04:59 AM   #4
Wolfgang55
Wolfgang55's Avatar
Oddometer: 3,460
Cool Beans
Wolfgang55 is offline   Reply With Quote
Old 10-27-2013, 08:25 PM   #5
TouringDave
Tri Moto Veritas
TouringDave's Avatar
Oddometer: 7,050
This will be good.
K7 Strom with Chair
84 Kwaka GT750 Cafe Project
84 Kawaka GT750 Outfit Project
TouringDave is offline   Reply With Quote
Old 11-03-2013, 01:27 AM   #6
Hiho OP
Oddometer: 49
So we are a week on and there is some progress. The mounts for the Guzzi are cut and mounted with tacks. Waiting to turn up the plugs and rear spindle for the rose joints.
[IMG[/IMG]
[IMG][/IMG]
The front mount looks ok and will work very well.
[IMG][/IMG]
Next week will see the rose joints mounted and the start of the chassis.
Cheers
Old 11-03-2013, 06:04 AM   #7
Dan Alexander
Oddometer: 7,527
Carefull!!
There's a scary looking guy lying on your floor messing with your bike!!
Old 11-03-2013, 06:34 AM   #8
bk brkr baker
bk brkr baker's Avatar
Oddometer: 5,709
That's a cool goose , one that is denied to the USA.
Old 11-03-2013, 09:47 AM   #9
DRONE
Dog Chauffeur
DRONE's Avatar
Oddometer: 3,783
Yeah, not familiar with the Bellagio. Pic--
WUMPA
Sidecardogs.com
DRONE is offline   Reply With Quote
Old 12-08-2013, 05:27 PM   #10
Hiho OP
Oddometer: 49
Well its been a while and there is some progress.
And on it goes.
Fitting up the swingarm.
Ready to load up and fit the shock mount so we have clearance.
This will be an integral part of the sidecar?
As will this.
Had an absolute crap day in the shed yesterday and no progress was made on this one or my new one.
Reconstructing my first sidecar and had some issues with the wiring.
Cheers
Old 02-02-2014, 06:03 AM   #11
Willi-Jens
Oddometer: 284
Hi Brian,
Good to see that that you are still enjoying the leaners.
I hope both of you fully recovered from that mishap in Tassie.
I'm guessing the reason for choosing flat steel for the subframe is ground clearance as well as keeping clear of the oil sump (maintenance) and the rear suspension, is it?
regards
Jens
Willi-Jens is offline   Reply With Quote
Old 02-04-2014, 07:01 PM   #12
Hiho OP
Oddometer: 49
Gday Willi,
Yeah flat plate was easier to set up with the need to remove the case for oil filter changes. Ground clearance was not really an issue.
The wife has lost about 30% of movement in her wrist and about 80% of the strength. Probably as good as it will get.
I will try to update the build tonight.
Cheers
Old 02-05-2014, 03:52 AM   #13
Hiho OP
Oddometer: 49
Okay its been a while and stuff is happening slowly.
[IMG][/IMG]
Suspension is set up with a loaded height of 200mm from the ground. No more railway line issues.
The body was started. Not yet finalised on design due to the requirements.
We started to get some shape into the front after making some measurments.
This is the start of the bonnet. Got a few hours to go to finish it.
And this is another mystery part to be fitted.
Old 03-23-2014, 04:11 AM   #14
Hiho OP
Oddometer: 49
Wink
So even further down the track, but still on schedule for the ride coming up.
The bonnet has been a long hard slog but is almost at completion. Weld a strap up through the middle and sort the hinges out.
[IMG][/IMG]
Some of the other parts for this side car are sorted and the placement is basically sorted.
[IMG][/IMG]
Another weekend should see the bonnet finished and all parts fitted. The final piece of this project is sitting in a box in the corner of the shed. About $7000.00 Ozzy. It will be so much fun to ride this rig.
Talk soon.
Old 06-18-2014, 06:59 PM   #15
Hiho OP
Oddometer: 49
Its been a while and progress has been made. Building this has been both frustrating and fullfilling. Health Department, Department of Energy and Transport regs to comply with.
And sitting on top of this is this!
Times are GMT -7.   It's 03:26 AM.
