Old 10-27-2013, 07:35 AM   #1
Bongolia OP
stop acting
Bongolia's Avatar
Oddometer: 17,138
Mikuni carb service/repair kit?
Guys, hoping somebody here can help out.
I have a 2005 Suzuki TU250G 'Grasstracker'. It is a carb model not FI. Mikuni BSR 32 CV type
Tonight I noticed gas under the bike. The fuel tap was in the off position.
Looks like I have both a leaking fuel tap and a carb issue with either the float or the needle valve
I'll pull the carb and tap next weekend and check and clean. Also looking for a service kit and I've drawn a blank for this carb. Any ideas?
This isn't a US or Euro bike (Jap home market) but the carb was used on a few Suzuki models
Former Farmer.
G 850 LM Mk II
http://advrider.com/forums/showpost....ostcount=53377
Bongolia is offline   Reply With Quote
Old 10-27-2013, 08:37 AM   #2
anotherguy
anotherguy's Avatar
Oddometer: 6,207
I'd repair the fuel tap before tearing into the carb. Gravity feed carb float needles are only designed to handle 2 PSI max and if the tank is full enough it can overwhelm the needle. I might remove the needle/seat and clean/inspect before spending money.
Old 10-28-2013, 12:01 AM   #3
Bongolia OP
stop acting
Bongolia's Avatar
Oddometer: 17,138
Thanks, will do.
I'll be pulling the carb anyway as it isn't set up right. Starts no choke, idles a bit too high, and a bit of a lag when rolled off on the throttle for it to settle to an idle.
Former Farmer.
G 850 LM Mk II
Old 10-29-2013, 05:47 AM   #4
rjsurfer
Oddometer: 207
Here is a link for the rebuilding kit for a Mikuni, just check if it's the right one for your needs.
http://www.jetsrus.com/individual_parts/sh_03_841.html
Ron W.
DRZ 400SM
DL-650 Gone but not forgotten
rjsurfer is offline   Reply With Quote
Old 10-31-2013, 06:59 AM   #5
Bongolia OP
stop acting
Bongolia's Avatar
Oddometer: 17,138
Ron W.
Thanks Ron. Appreciated. Any advice on a rebuild kit for the petcock?
Former Farmer.
G 850 LM Mk II
Bongolia screwed with this post 10-31-2013 at 07:34 AM
Old 10-31-2013, 05:56 PM   #6
rjsurfer
Oddometer: 207
These two Yamaha parts take care of the the front side of the petcock,
3aj-24534-01 O ring
3ac-24523-00 Smily face
The backside is a diaphragm, I believe that it can usually just be cleaned up......
Ron W.
DRZ 400SM
Old 11-02-2013, 08:46 AM   #7
Bongolia OP
stop acting
Bongolia's Avatar
Oddometer: 17,138
Stripped the petcock and carb. Petcock smiley has a nick in the surface which is allowing gas to trickle through to the carb.
Stripped the carb too, needs a good clean inside. This diaphragm looks a bit odd, is this normal or do I need to replace it? There are no holes or tears in it.
R
Former Farmer.
G 850 LM Mk II
Old 11-03-2013, 03:56 AM   #8
rjsurfer
Oddometer: 207
R
They all look like that, to be on the safe side put some 303 protectent on it to keep it from cracking. You can get the diaphragm from any Suzuki dealer and keep it as a spare. You can change them out just by rotating the carb sideways, no need to remove carb.
Ron W.
DRZ 400SM
Old 11-03-2013, 04:16 AM   #9
Bongolia OP
stop acting
Bongolia's Avatar
Oddometer: 17,138
Ron W.
Cheers Ron, you're the man.
Any ideas on how to get the pilot screw out? No cap on this model, but looks like it is jammed in place with a chewed up head
Local heat on the surround and an impact driver?
Also in the longer term I'm likely to change the carb, is there a standard mikuni swap for this?
Former Farmer.
G 850 LM Mk II
Old 11-03-2013, 09:50 AM   #10
rjsurfer
Oddometer: 207
Well, I'm finally out of answers
Usually the impact approach is the best, as far as a carb swap I don't know of any.
Best of luck........
Ron W.
DRZ 400SM
Old 11-03-2013, 12:05 PM   #11
Crisis management
Latte riders FTW!
Crisis management's Avatar
Oddometer: 1,453
Re; pilot screw, be careful with the impact driver as they are very soft metal (in case you hadn't noticed), I have had some success with a small drill then tapping a torx bit into the hole and backing it out with a rachet. Torx bit as they have small, multiple deformations that provide good grip without deforming the screw you are trying to extract.
Carb change,why? The CV is a great carb for most purposes, a flat slide or pumper carb has some advantages in race conditions where it runs at full throttle mostly otherwise the CV performs better.
Orange...cause it makes me look like I know what I'm doing!
Crisis management is offline   Reply With Quote
Old 11-03-2013, 12:13 PM   #12
Beezer
Oddometer: 5,651
left handed drill bit for the stuck screw.
you will be appalled by the price of a new diaphragm
Beezer is offline   Reply With Quote
Times are GMT -7.   It's 03:05 AM.
