Old 10-27-2013, 04:29 PM   #1
Ricardo Kuhn OP
a.k.a. Mr Rico Suave
Ricardo Kuhn's Avatar
Oddometer: 12,367
Question Can I use pre cast concrete blocks footings, to build..??
A wood platform for a 15' x 8' plastic shed or do I need to cast them my self for stronger results..
Something like this, I'm guessing I will need six of them, but maybe I'm also wrong..
Wanted: worn, ugly, cheap motorcycle cover for a big GS 1200
Ricardo Kuhn is offline   Reply With Quote
Old 10-27-2013, 04:46 PM   #2
ktm360mx
ktm360mx's Avatar
Oddometer: 224
Sure
That's very similar to what our shed rests on. We have a 10X20 shed with a side door. Blocks like that about every 3-4 feet. It's been on them for the past 10 years or so.
We received A LOT of rain this spring and the blocks sank into the ground an inch or two in various places. Now the floor is a bit wavy, but the entrance door is still square.
You may consider digging down a 6 inches below each footing and placing gravel or road base, then the block on top of that.
Good luck- it's worked well for us for a long time.
ktm360mx is offline   Reply With Quote
Old 10-27-2013, 05:08 PM   #3
Ricardo Kuhn OP
Oddometer: 12,367
Yes also get a ton of rain and snow around here, so that was my biggest concern..
Yeah I was thinking of installing flat concrete stone squares under the pyramids to increase the load capabilities but the stone is also a great idea..
Old 10-27-2013, 05:33 PM   #4
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,522
I would opt to go with something that has a larger "foorprint". Maybe a 4" thick solid cap block. How much weight are you planning to put in the shed ?
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is offline   Reply With Quote
Old 10-27-2013, 05:44 PM   #5
Ricardo Kuhn OP
Oddometer: 12,367
Yes that is the idea...
Mike
1200 pounds at the most on really hard dirt..
Old 10-27-2013, 06:42 PM   #6
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,522
Use as many support points as you can, or just do a full perimeter support to help spread out the load. You could make a rectangle out of the cap blocks and lay a 4x4 or 6x6 lengthwise below the front, rear, and side walls.
Mike
Old 10-27-2013, 06:57 PM   #7
Dustodust
Dustodust's Avatar
Oddometer: 983
overkill for a plastic shed :
underkill for a high rise :
if its not in threat of standing water I would think 2" of sand and 6mil plastic sheeting would be more than sufficient
from a cloud of dust we race, then into the dust we return, across the finish line
04 KTM 950 S
04 KTM 525 EXC street plated
Old 10-27-2013, 07:00 PM   #8
Ricardo Kuhn OP
Oddometer: 12,367
I was thinking 6 blocks holding 4x4 vertically and beams every 16" on center, just to make things easier..
Mike
Sorry Mike I did not get that Lengthwise you mean another "ring" on the inside of the main structure to help hold the plywood in place or what...??
Old 10-27-2013, 07:19 PM   #9
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 4,522
Yes this would work, what size beams ?
You could do it directly below the perimeter framing and one down the center. Again depends on the dimension of lumber being used.
Mike
Old 10-27-2013, 07:42 PM   #10
Ricardo Kuhn OP
Oddometer: 12,367
Mike
I was 2x8 for the perimeter and 2x6 for the internal beams, cover on 3/8 OSB, but then again I'm here to learn and follow sound advice..
Old 10-27-2013, 07:45 PM   #11
Ricardo Kuhn OP
Oddometer: 12,367
Very clear concept, I hope nobody die when that building collapse
Since I'm doing all the work my self and by my self, I think a little overkill is necessary just in case I miscalculate something..
Old 10-27-2013, 08:31 PM   #12
troidus
Oddometer: 15,264
Home Depot has a worksheet for calculating deck materials for supporting a shed. If I used it correctly, they said to use 36 pier blocks for a 10x12 footprint. That seems excessive, but I bet it wouldn't sink.
troidus is offline   Reply With Quote
Old 10-27-2013, 08:38 PM   #13
Ricardo Kuhn OP
Oddometer: 12,367
Oh man 36 is a little much don't you think..
I go and check the store tomorrow to get a better idea of what I need..
Old 10-27-2013, 08:40 PM   #14
walkingbear
walkingbear's Avatar
Oddometer: 3,584
blocks
how are you going to deal with the water under the shed?
Myself, I would build a drainage system to get the water away
from the piers.
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is online now   Reply With Quote
Old 10-27-2013, 08:57 PM   #15
slackmeyer
Don't mean sheeit. .
slackmeyer's Avatar
Oddometer: 3,125
Do you have a truck you can use to get some gravel or crushed rock? Actually you could just load up some cheap rubbermaid tubs or buckets in a car. anyway, what I would do:
clear your spot down to flat bare ground, try not to overdig- you ideally want to go onto undisturbed soil.
Spread out a few inches of gravel
Build your shed on skids: 6x6 or 6x8 or 8x8 pressure treated fir. You'll want them running the 15' direction. If you bevel the bottoms of the ends, it would make your shed easier to relocate later by pulling it with tractor or truck or come along.
Then run your 2x6 in the 8' direction, with 2x6 rimjoists sitting on the outside of the skids, then ply that over with a 3/4 ply (osb is ok for the sidewalls, but either use cdx ply or something like advantech osb for the floor, where water might sit).
Around here, if I made something like that I would use pressure treated 2x6 for the floor framing. SLC is probably a cold/dry climate where you could get quite a long life out of standard framing lumber, especially with the gravel to keep things drained.
I think the big pressure treated timbers might cost a little more than the precast blocks, but it eliminates having to use any of the posts and beams, and the building will go much, much faster.
Zak
ktm
old bmw
others
slackmeyer is offline   Reply With Quote
Times are GMT -7.   It's 07:05 AM.
