Old 11-02-2013, 01:50 PM   #1
GAwoody83 OP
GAwoody83's Avatar
Oddometer: 183
Beta TR33 engine/clutch noise
hey guys, out last weekend and after a good ride, the bike started making a scrubbing sound from the lower end. was not able to tell which side it was coming from but it was consistent with engine speed. I have drained the oil from it and there are no signs of destruction yet, getting ready to take off the outer case and see whats going on inside. Any thoughts or ideas? Also, anyone know of a good carb tuning guy near Athens GA?
GAwoody83 is offline   Reply With Quote
Old 11-03-2013, 03:42 AM   #2
PSchrauber
PSchrauber's Avatar
Location: Summer: Kemiö, Finland; Winter: North Germany
Oddometer: 872
Difficult to tell with this little information, could be everything, from a broken spring up to a broken reed.
I would take a look inside taking off the clutch case and check the internal components. Then too check the reeds. They can fail too especially when made out of plastic.
PSchrauber is offline   Reply With Quote
Old 11-03-2013, 05:32 AM   #3
GAwoody83 OP
GAwoody83's Avatar
Oddometer: 183
I got the clutch cover off and haven't seen anything that looks out of place or broken. Going to go ahead and either do the clutch fix or replace the clutches and go back together. Is there anything with the stator that can rattle/scrub?
Old 11-03-2013, 06:42 AM   #4
JRP
Old guy
JRP's Avatar
Oddometer: 1,537
Is the flywheel tight as in no play? Crank bearings? If you have a puller you can check behind it for a loose stator. I've had several Betas with no problems at all, but anything is possible. Good luck!
"What could possibly go wrong? " The Jerk
2014 Royal Enfield Continental GT
2012 TE 250
2010 F 650 GS
1983 R 80 G/S
JRP is offline   Reply With Quote
Old 11-03-2013, 05:53 PM   #5
lineaway
Oddometer: 3,222
Scubbing noise is usually just the plastic flywheel cover.
lineaway is online now   Reply With Quote
Old 01-04-2014, 02:35 PM   #6
GAwoody83 OP
GAwoody83's Avatar
Oddometer: 183
so scrubbing noise was from the flywheel touching the cover, guess it wasnt tight and had shifted back to touch the flywheel.
Times are GMT -7.   It's 08:34 AM.
