Old 12-03-2013, 06:58 PM   #196
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,531
Originally Posted by Dominic49 View Post
The stutter is from the image stabilization not recognizing the movement of closer in objects off to the side of the road/trail as natural progression through the scene. It erroneously assumes that's that the camera is shaking.
If you're describing my videos, I have not used stabilization on any of them.
Sent from my Monterra using Tapatalk
Old 12-03-2013, 07:04 PM   #197
Dominic49
Oddometer: 27
I was speaking of my video in particular as I know I am using a faster then standard class 10 sandisk extreme.
In other news my device is falling into locking up when taking videos that roll over to the 2nd file (FAT limitation)
Dominic49 is offline   Reply With Quote
Old 12-03-2013, 07:17 PM   #198
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,531
Oh, ok.
Are you saying you can only have one big file recorded on the card?
Old 12-03-2013, 07:31 PM   #199
Dominic49
Oddometer: 27
Oh, ok.
I am using the camera day to day for dash cam footage (multiple hour drives) the Fat file size limit is 4 GiB. The VIRB (and go pro) will continue to record when it fills this file up it will just roll over to a new file. my error appears to be happening at some point in recording of the 2nd file.
Old 12-03-2013, 09:23 PM   #200
THRASHED
Moving on Up
THRASHED's Avatar
Oddometer: 341
Snow day today...
What's with the green flash on the video? I know it can be edited out but is it something that you can narrow down?
THRASHED is offline   Reply With Quote
Old 12-04-2013, 03:55 AM   #201
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,531
Probably some kind of sync issue. Garmin's aware and working on fixing it.
Old 12-04-2013, 08:11 AM   #202
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,525
Originally Posted by DRONE View Post
I'm new to this thread and admit I have not read every post. But I see more stutter in the posted vids than I would expect. Just want to make sure that you guys (Emmbeedee and others) are using Class 10 cards with your VIRB? Is the stutter only showing up when the vid gets posted online, or are you seeing the stutter on your home computers when viewing the video directly from your hard drive?
I see no shutter in my videos on my computer.
And they look very nice at full screen.
Every day I went out was a very gloomy day Can't wait to see the videos in the sun....got to be better.
On the other hand viewing from SmugMug has been almost impossible.
Viewing from You Tube much better...but I do see some shutter from time to time.
I just figured it was my slow internet connection of web traffic.
I use a SanDisk sold from GPS City
Specs from GPS City site
64GB microSD Data Card with SD Adapter features
  • Reformat into file system other than exFAT may cause instability
  • Only compatible with SDXC enabled device in exFAT format per SD Standard
  • Highest Full HD video recording performance available with class 10 rating
  • Ideal for Android, other smartphones and tablets
  • UHS-1 enabled
  • Faster app performance with transfer speeds up to 30MB/s
  • Ships in Certified Frustration-Free Packaging
  • Water-proof, temperature proof, X-ray proof, shock proof
Fred
2013 WR250R 2007 Wee
www.riverbendphotos.com
YouTube feed
Wallpaper for Montana GPSr
Beware of the Wallnut
USAIR is offline   Reply With Quote
Old 12-04-2013, 08:13 AM   #203
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,531
It just occurred to me that if we're swapping batteries around daily between the VIRB and Montana/Monterra, that might make it easy to make a mistake and try to put the battery into, or remove it from a device the wrong way, meaning instant death to the battery terminals.
Yes, there is an indentation in the battery which is supposed to prevent this happening but people still do it anyway.
So I put a label on the battery which I hope will help. It's just a reminder to pull up and push down from that side of the battery. (I have 6 batteries but one's in the Monterra on the charger right now.)
Old 12-04-2013, 08:17 AM   #204
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,525
Virb Edit : Windows version
Question for the group.
Anyone using Windows PC with Virb Edit and get it to work?
According to the Garmin forums there will be a fix by the end of the year.
Fred
YouTube feed
Old 12-04-2013, 08:22 AM   #205
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,531
How bizarre is this? Garmin's warning label about which end of the battery to put in first is on the side away from where you'd normally be looking - ie if the label was up for you to read it as you put the battery in, you'd be putting it in upside down!
This calls for an email to Garmin.
Old 12-04-2013, 08:27 AM   #206
USAIR
picking and riding
USAIR's Avatar
Oddometer: 1,525
It's upside down in the Montana too
Fred
YouTube feed
Old 12-04-2013, 08:32 AM   #207
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,531
Yes, Montana/Monterra/VIRB all have the same problem. I said so in my email to my contact there.
They could put labels on at the factory. This was not a big issue when you put the battery into the gps once when you first got it, then maybe took it out occasionally to change cards, but if you're switching batteries every day, it becomes a potential big problem.
IMHO, of course.
Better get back to work now. SWMBO is likely wondering why I'm so active here. ;)
Old 12-04-2013, 10:46 AM   #208
Jon_PDX
Oddometer: 1,114
My Montana battery does not have the [Insert This End First] label on it. Are the ones you guys have posted extras that you got form Garmin?
Jon…
Bikeless at this time
Past Bikes.....Check with my Wife.....I've lost count :-)
Jon_PDX is offline   Reply With Quote
Old 12-04-2013, 10:46 AM   #209
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,531
Jon…
Newer batteries have the label.
Old 12-04-2013, 11:01 AM   #210
Jon_PDX
Oddometer: 1,114
Hey Fred,
I gotta say the music you used in your video sure brought back memories of good times. You know like before the wife, kids, and a mortgage
Off Topic but for those that remember those years (or are curious) here's a flashback from the past.
Traffic at the Santa Monica, CA Civic Center 2/21/72
http://www.youtube.com/watch?v=pSQ1akE2CcM
Back on topic…
Keep the videos coming. The more I see the better I'm liking the VIRB.
Jon…
Times are GMT -7.   It's 10:29 PM.
