Old 11-07-2013, 07:40 AM   #16
lmychajluk
Oddometer: 2,085
Is there are standard tripod mount (1/4 x 20 hole) on the Virb?
What are the helmet mounting options, and how does the lens orientation work?
-Lee
NE ADV Event Calendar (Request Additions here.)
2013 Triumph Tiger 800
2008 Suzuki SV650n (Sold... I miss that bike...)
lmychajluk is offline   Reply With Quote
Old 11-07-2013, 08:54 AM   #17
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,757
It's an extra $6 for the tripod mount. It attaches to the VIRB cradle.
This is both of them together.
Helmet mounting options are pretty much like the GP - a glued base on your helmet and the camera attaches to that.
Not sure what you mean by lens orientation, but for the moment while the Smartphone app is not out yet, I guess you'll just have to eyeball it. There is no laser beam, if that's what you mean.
There is a level to help set it up, but it won't be of much help if it's on top of your helmet while said helmet's on your head.
Emmbeedee is online now   Reply With Quote
Old 11-07-2013, 10:10 AM   #18
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,757
The VIRB can be mounted on a shoulder with this harness. $40 at GPSCity. Click the image to see the page.
Old 11-07-2013, 10:16 AM   #19
atlas cached
OX Ambassador
atlas cached's Avatar
Oddometer: 688
Ooooohhhhhh....... Ahhhhhhh...... VIRB Bra!
Does it come in pink with lace?
atlas cached is offline   Reply With Quote
Old 11-07-2013, 10:19 AM   #20
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,757
I'm sure if you ask nicely they'll fix you up with that.
Emmbeedee screwed with this post 11-07-2013 at 03:46 PM
Old 11-07-2013, 10:35 AM   #21
lmychajluk
Oddometer: 2,085
Some cameras (Contour?) allow you to rotate the lens (either physically or through software), so the image is not dependent on the orientation of the camera.
I was hoping for some type of helmet mount that tucked the unit in against the helmet, and didn't have it out on an arm. Kind of like this (but hopefully smaller):
-Lee
Old 11-07-2013, 04:29 PM   #22
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,757
I noticed Garmin put a strip of foam on the uSD card clip, probably to stop it sliding on its own. Might be worth doing to any gps with this same clip on it.
Old 11-07-2013, 05:07 PM   #23
Mastery
Mr. Funny Man
Mastery's Avatar
Oddometer: 1,373
I don't know how the Ghost works, but it sounds like the VIRB does the same, essentially.
Thanks for the info. Identical to the feature on the Drift Ghost. Now I am really interested in the Virb comparison.
Mastery is online now   Reply With Quote
Old 11-07-2013, 08:02 PM   #24
Squelch
Everyday People
Squelch's Avatar
Oddometer: 1,103
This is a series of Dashboards specific to the Elite model. I'm not sure what each one represents, but I'm sure I'll figure it out eventually.
Great review! I'm pretty sure this is the screen you have visible as you pilot your TIE fighter through the trench run, trying to catch that damn rebel Skywalker...
Squelch is offline   Reply With Quote
Old 11-07-2013, 09:45 PM   #25
andrewhtf
andrewhtf's Avatar
Oddometer: 127
Here's a couple of pictures taken with the lens correction software enabled.
Sorry i just cant resist...
andrewhtf is offline   Reply With Quote
Old 11-08-2013, 04:35 AM   #26
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,757
Now that you mention it, it does look like the Dork Farces video game.
Sent from my Nexus 7 using Tapatalk
Old 11-08-2013, 04:38 AM   #27
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,757
What's your point? Google + automatically made a composite of three images into the one you posted.
Old 11-08-2013, 06:39 AM   #28
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,757
I hadn't noticed but one of the mounts connects the VIRB mounting system to GoPro components!
Wow, that makes sense, and saves me a lot of money buying new parts.
Emmbeedee screwed with this post 11-08-2013 at 05:02 PM
Old 11-08-2013, 05:18 PM   #29
SpeedyR
SE in the SE
Oddometer: 889
i was going to ask about the mounts. I have GP mounts all over my gear and the chesty, etc. Would hate to have to buy/stick all new mounts all over my gear again..
overall what's you impression of the mounts?
I will probably pick up a monterra early next year, and if that goes well, maybe Virb 2 if they have one out by then. :)
SpeedyR is offline   Reply With Quote
Old 11-08-2013, 05:32 PM   #30
Emmbeedee OP
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,757
I think you're going to have a little trouble putting this on the chesty since it's longer than the GP. It can be done, of course, with arms extending out the front but it's going to be sticking out a good 4".
Overall I'm impressed with the material they used to make the cradle and mounts. The mounts have teeth in the engagement area and that may keep them from moving. The knobs are smaller and not as easy to tighten as the GP version but the teeth in the mounts might mean you don't need to tighten the mounts as much as the GP version.
I've got at least 6 broken GP mounts in a year's use of them. Maybe I'm clumsy but they seem really brittle.
Times are GMT -7.   It's 04:51 AM.
