Old 11-08-2013, 11:03 AM   #1
StuInFH OP
Oddometer: 444
What is this fibrous material in brake fluid/system?
Sorry no pic, but easy to describe.
'07 Sherco 2.9
Despite my best intentions, the front MC and caliper got moved around a bit and were lying flat during stripping of frame to weld up breaks. MC may have even been upside down for a few weeks. No matter I thought, needs a full flushing anyway. (yes, it has been neglected because I hesitate to crack a hydraulic system on a low-speed TB that was working flawlessly-my rancher/farmer roots where you never take apart a running motor-don't ask)
After all the clean fluid was sucked out from the caliper with hand vacuum bleeder, there was still little to no lever resistance at MC. Drafted wifey to pump the lever and hold for manual bleeding. After about 10 cycles of this, I noticed a coarse ground pepper-sized dark speck exit the bleed nipple. I thought that was odd given the amount of fluid I had flushed, and kept cycling the lever/flushing, as the lever was still offering little resistance.
A couple bleed cycles later I saw what appeared to be a small piece of wood coming out of the bleed nipple! It was sticking out about a 1/4 inch so I pulled the bleed tubing off and pulled it out by hand. It is ~1/2 inch long by about 1/8 inch wide, and looks like a splinter with jagged ends and edges.
It is fibrous and metallic feeling and has what appears to be a few copper or metallic fibers running through it. It was easy to pull apart, but not falling apart or disolving. It almost seemed like a splintered bit of pad material due to the feel and colors, except it was not as dense. And it was in the fluid of course.
I thought I could look at schematics and MC and Caliper rebuild parts kits to see where a gasket or seal comprised of this type of material is used, but I don't see anything like it in the system.
We continued to bleed the system and found no other debris and the lever only firmed up to about 75% of normal feel. I adjusted the actuator pin at the lever to get maximum travel and I think it will brake well enough for my event Sunday, but the lever can be pulled well past where it used to stop. And it has that darn spongy feel at the end. :-(
Any ideas what it could be?
StuInFH is offline   Reply With Quote
Old 11-08-2013, 11:46 AM   #2
jonnyc21
Trials Ninja
jonnyc21's Avatar
Oddometer: 1,064
I read a post once describing something like this and it turned out the brake line had failed and the fiber like bits where internal pices of the line... Just a thought. Good luck.
jonnyc21 is offline   Reply With Quote
Old 11-08-2013, 03:51 PM   #3
motojunky
Professional Idiot
motojunky's Avatar
Oddometer: 1,087
+1. Replace the brake line.
motojunky is offline   Reply With Quote
Old 11-08-2013, 04:56 PM   #4
DerViking
Shred
Oddometer: 353
The debris does sound like line. Bummer?
Are you bleeding from the top down? I have always had better luck bleeding bottom up with a syringe. I may be missreading your post though. No matter how you bleed it, if you have shit in there,
ATGATT: When you fall off your motorcycle, you will be wearing what you were when you got on your motorcycle. Dress accordingly.
DerViking is offline   Reply With Quote
Old 11-09-2013, 05:32 AM   #5
Gordy
Team Listo
Gordy's Avatar
Oddometer: 23,010
Since you messed with the caliper, I'd suspect it. Did you by chance pump the caliper pistons out and then manually push them back in? You can tear the seals on them and brake lines don't often come apart.
Good luck and keep us posted. We all learn from this stuff!
Gordy is offline   Reply With Quote
Old 11-09-2013, 06:25 AM   #6
motobene
Motoing for 44 years
Oddometer: 1,556
Originally Posted by Gordy View Post
Since you messed with the caliper, I'd suspect it. Did you by chance pump the caliper pistons out and then manually push them back in? You can tear the seals on them and brake lines don't often come apart. Good luck and keep us posted. We all learn from this stuff!
I knew about this one, though have never seen the square rubber seals actually shear off bits. The brake line thing is new to me as well, as I've never had one fail. If you are welding the frame up this sounds like a bike with a lot of hard use and hours? Perhaps the brake line getting smacked hard near the fittings at one point?
I've found good luck simply doing a gravity brake fluid replacement on brakes that have not gotten air into them. Remove all master cylinder fluid except enough to cover the hole I the bottom. Replace with new fluid, then let it work through by gravity.
I pressure bleeding brakes from the caliper up when they have had air in them. I found the barbed fittings from mountain bike brakes to be the same thread as AJP, so I can pressure bleed with a syringe without leaking fluid all over the caliper! You screw them in until they shut off on the bottom of the hole, force bleed, then remove the barbed fitting and let the brakes gravity back bleed. Replace the bleeder screw and voila! No air!
It's a good idea working on brakes to move the pucks (pistons) as little as possible, and usually only in to make room for newer, thicker pads. I also take great care to not get any fluid on the pads. If I am doing a lot of messy brake work, I'll use old pads or spacers, then clean up and fit new pads. If I get a little fluid or grease on pads, I'll spray the crap out of the assembly with brake cleaner before riding the bike. Take care also to wipe off discs with a clean rag or paper towel with brake cleaner. One grab of a disc with greasy finger tips can reduce braking power significantly.
And then there's seasoning. No substitute for this other than a lot of riding time in dust and maybe mud! Seasoning is now well known. If you don't already know about it, it is a critical technique to getting brake power back fast. Seasoning bypasses the hours required to break in new or messed with brakes.
Ride the bike in first or second dragging the front brake. It takes about a minute to get the tiny trials brake disc and pads hot enough to boil water. Ride and stop by your wife with a garden hose and her douse the disk and caliper aggressively. You should briefly see steam and hear a hiss. Do this 4 times and your brakes should get a little stronger every time. Exceptions: Badly oil-fouled pads and air still in the line. Pads are sintered stuff and metal bits. They are porous. It's very hard to get oil out of pads once fouled! The air thing is obvious. You'll either have a firm lever or not.
With seasoning, your brakes will be up to 90% as strong as they can be, right away. Some riding time will usually settle them in that last 10%, particularly if you get into dust or a little mud.
motobene is offline   Reply With Quote
Old 11-09-2013, 06:35 AM   #7
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 13,764
Inspect your brake lines you may find a bubble where the internal line has ruptured and fluid is being squeezed in between the inner line ad the outer sheathing
Either way, what you describe sounds like a failed brake line.
Old 11-09-2013, 06:55 AM   #8
Gordy
Team Listo
Gordy's Avatar
Oddometer: 23,010
I have been throwing dirt and grit into brakes for years to help with glazing and oil residue! Most guys think I am crazy! Why not? You are riding in dirt and mud already.
One little front brake tip that I do occasionally to all of my dirt bikes (and I've seen top SX and MX teams doing this as well) is to zip-tie your brake lever to the grip under moderate pressure overnight or even for a few weeks. It is supposed to work out micro-bubbles and you might be surprised how solid the brake will feel after trying this.
Old 11-09-2013, 10:38 AM   #9
NMTrailboss
Team Dead End
NMTrailboss's Avatar
Oddometer: 6,367
This works! We used to do this in the shop frequently and let them sit overnight with the brake lever zip tied to the grip..especially on real difficult to bleed systems.
NMTrailboss is offline   Reply With Quote
Old 11-09-2013, 10:48 AM   #10
laser17
Oddometer: 923
related Tip - cut up one of your old Mt bike inner tubes and create some big rubber bands. Put them on your handlebar, just inside the grip - double wrapped. You can stretch them over the end of the lever whenever you think you have some air in the system - turn the bars to make sure the master on the brake or clutch side (whatever one your optimizing) is the highest point in the system and leave over night.
laser17 is online now   Reply With Quote
Old 11-10-2013, 05:46 AM   #11
motobene
Oddometer: 1,556
Dirt and especially fine dry dust is a way to slow-season brake pads and accelerate wear-in of new pads. Fine dry dust will also wick out and off oils.
Zip tying the front brake lever? That's one I haven't tried or had to try.
When I hear a new tip I try to figure out what, exactly, is happening, and why. It's the engineer's curse so please forgive me
I've a KTM friend who told me once he's done that trick, not to magically remove air or improve performance, but so his clutch would still function after storage. For a period with KTMs, the master cylinder cup seals, after a period of non use, tended to lose their lip preload on the cylinder walls, and sometimes the master cylinder would not not want to re prime and the rider would come out to find no clutch! Also, and aggravated quick snap-back of the lever could suck air in for a re bleed required.
The trick for that period of KTM was to force the lips to stay pushed out during storage time, not allowing the cup seal to relax back and lose preload... with zip ties or rubber bands. I wonder if this bit of history is what led to this trick being adopted, but improving performance over night became a mental short circuit? I'm not saying you all are wrong about this... just that I don't see the overnight optimization part yet.
Here's why. When the lever is pulled in, the piston moves the cup seal immediately past the fluid re fresh hole and starts to pressurize the now-closed hydraulic. Once pressurized there is no way anything significant can escape, including air.
Also, the system will dynamically de air when in use, if there is somewhere air can get in. When functioning normally, there's not. If you have a tiny bubble from, say, a sub-optimal bleed, it will shrink every time you pressurize the system, then grow when you let off the lever. While shrinking the bubble could explain the trick, that is done over and over when you use the bike, and under more jostling and vibration of the bike to move bubbles up the system and out the refresh hole.
You can test the trick for the mystery de bubbling theory. Before you remove the zip tie or rubber band, pop off the reservoir cap. Carefully watch the refresh port for tiny bubbles coming up when you release and first pump the brake lever. If nothing comes up, nothing has changed. Monitor several times to be sure. No bubbles, no workie.
If you have a lazy cup seal that leaks on the first lever pull before it resets, the zip tie and rubber band trick will eliminate the first-bump problem, but that does not involve an overnight mystery process.
Old 11-10-2013, 06:39 AM   #12
laser17
Oddometer: 923
MB - Please try not to forget, experimentation is a vital part of engineering. There's lots of excellent reasons why many things don't work at 1st glance. But sometimes, if the math doesn't add up, your doing it wrong, or you need new boundary conditions, or maybe even new math. Don't blame it on engineering mentality - because both the Dot 5 and Lever tricks come recommended by very accomplished engineers who are also long time, highly respected mechanics. On top of that you have people telling you it works. The phrase "Don't knock it till you try it" comes to mind in several of your last posts.
Getting off my soapbox now.
Trebor
Old 11-11-2013, 06:21 AM   #13
motobene
Oddometer: 1,556
Trebor
And please don't misunderstand my position. Believe me, real and practical engineering was my career and I've got many thousands of products in use right now around the world under severe applications. I was simply opening up the challenge for you all to explain WHY you are getting results.
Heck look at physics. It wasn't until the 1920s that people realized the fuzzy blobs seen in telescopes were other galaxies beyond counting. And it wasn't until the last few years that the 'apparent knowledge' that the universe is made up entirely of the mass and energy we can directly observe has fallen apart. Now the physicists tell us that all of that stuff... all of that energy, accounts for less that 6% of all the mass and energy that must exist for the math to add up.
A hydraulic system is far less mysterious. Why the zip tie trick is apparently working should be explainable without logical short circuits, or at least well speculated on. So I ask: If increased performance is due to air leaving in a closed hydraulic system, where do 'it' go? I have one possible answer I missed yesterday: microspheres of gasses going slowly into solution under constant pressure. Can't prove that. Can only speculate about it and the perhaps negligible effect they might have on braking power. Can a larger bubble go into solution overnight? Maybe, but probably not.
Old 11-11-2013, 09:30 AM   #14
laser17
Oddometer: 923
I guess we have a different view on things - which is great.
To me it makes sense. ANYTHING simple and cheap that can help extract or keep air/water out of the system is good. I can see definite advantages of keeping the system pressurized. Also, I suggest you go ask a good vacuum engineer how hard it is to remove ALL air and water from a closed system. They use multiple methods to extract molecules from different pumps, to cold traps ect... Those last few pesky molecules are the hardest to get. Your right, there are other things that help bleed the system,but why not try something so easy - you may be surprised - it may help get the last few small bubbles out of a stubborn sticky spot in the fittings, Time alone MAY help - that doesn't make sense to you? Time and pressure are a force to be recon with in many physical systems.
If you think air/water cant permeate the system, then that's another argument I have.
I guess my general point is, that unless you KNOW it DOESNT work, why poo poo it when others say it does. It just comes off as a bit pompus to me. Its not like we are defying the laws of physics here. If fact, I think they line up pretty good in favor of trying this.
MB: This is one of those conversations that goes much better in person as the internet can turn things ugly that aren't meant to be. Please read the above with a smile on your face - im just pushing back cause I think you may be wrong, but know that its really all good.
Old 11-11-2013, 09:36 AM   #15
Gordy
Team Listo
Gordy's Avatar
Oddometer: 23,010
Yes, it works and I have no idea if quantum mechanics is involved or not!
I have also cross-drilled the banjo bolt on the front brake calipers of my KTMs to help with pesky air bubbles that get trapped in there.
Times are GMT -7.   It's 11:01 AM.
