Old 11-10-2013, 07:20 PM   #16
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,207
Originally Posted by syzygy9 View Post
I will buy a new KTM front sprocket (which are also damped...
In case you were not aware, the rubber on the OEM sprocket dampens only noise. It does not have any cush-drive function.
KTM also offers a plain sprocket for a few dollars less. I have not noticed any difference in the noise level.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 11-10-2013, 09:30 PM   #17
syzygy9 OP
syzygy9's Avatar
Oddometer: 298
I am aware of that, a bit of rubber on the outside of the sprocket, the only disadvantage for damped as far as I could tell is that it a little more expensive with the possibility it might actually do something.
__________________________
bikeless no longer! welcome home, 2011 KTM 990 Adventure!
syzygy9 screwed with this post 11-11-2013 at 12:07 AM
syzygy9 is offline   Reply With Quote
Old 11-19-2013, 12:36 AM   #18
two trackin fool
two trackin fool's Avatar
Oddometer: 1,268
second rider in for maintance ......
I am also planning to tear the 990 down . BUT I am having issue with finding a shim kit for the girl . I'm guessing HotCams but not having any luck finding the kit # to order . Any suggestions ??
I have been told the water pump shaft issue was addressed by KTM . Is this true & if so any idea on what year ? Or did they just change the shaft design ?
I ride daily (hate to cage) I do plan to trip the girl & have absolutely NO plan on selling so any maintenance that needs to be done I would do ... 12000 miles on the clock .
Stay Patient and Trust your Journey
two trackin fool is offline   Reply With Quote
Old 11-19-2013, 11:59 AM   #19
CamelBill
Ride It!
CamelBill's Avatar
Oddometer: 500
Shims
Harley Davidson V-Rod shims fit, and can be bought individually at a HD dealer. See the spreadsheet on the HOW (Halls of Wisdom, see thread at top of Orange Crush). So no need to buy a 'kit'
Camel
KTM 1190R, 950S, 500XC-W
FJR, Wing
CO Single Track RR http://advrider.com/forums/showthrea...0#post24875020
CamelBill is offline   Reply With Quote
Old 11-21-2013, 01:11 AM   #20
Jdeks
Departed
Oddometer: 966
I don't recall the exact year the tech bulletin was released, but they updated to a hardened shaft and a teflon seal.
Despite this, it is still pretty much an accepted fact that when you do a major service (ie valves coolant and oil, about every 15 000 km) you should do the pump seal at least as well.
Jdeks is offline   Reply With Quote
Old 11-21-2013, 01:19 AM   #21
two trackin fool
Oddometer: 1,268
Thanks for that info
Old 11-21-2013, 08:37 AM   #22
MortimerSickle
Semi-Adventurer
Oddometer: 12,207
Now I am worried.
Mine has over 45000 km.
So far, so good.
G.H.W.S. 1878-1962
Old 11-21-2013, 10:11 PM   #23
gweaver
Wandering between rooms
gweaver's Avatar
Oddometer: 1,575
One thing I've done that I find invaluable is get a foam core project board and draw outlines of all the major parts removed. Use a nail or something similar to poke holes where mounting bolts go. It's an easy way to make sure you don't lose fasteners while your bike is in pieces. If you arrange the drawings in order, you'll know what order the parts go back on (remove glove box before tanks, etc). The board is also a handy place to write valve clearance specs and other important data (tire pressure, torques, etc.)
G
I just twist and my eyes glaze over, "uh....errr huh huh, weeeeoooooh---doo dat agin, doo dat agin..." -morriswf
I like my women like I like my instant oatmeal- quick, easy, and covered in facts about dinosaurs.
gweaver is offline   Reply With Quote
Old 11-26-2013, 04:38 AM   #24
Jdeks
Departed
Oddometer: 966
Now I am worried.
So far, so good.
Yep, my original pump shaft lasted me about 60 000 km....but gave up the ghost miles form home and was a PITA to replace on the road.
I could probably push the new viton ones and hardened shafts out even more....but for a few $$$ and really not much more extra work, I reckon its cheap insurance to just do it when you do the coolant. Just my 2c
Old 01-12-2014, 09:54 PM   #25
two trackin fool
Oddometer: 1,268
Oil on throttle plate
Hey all ,
Finally was able to start in on my FIRST valve check today and was a little concerned when I open the air box to this
Is this a common state . I have been a little concerned with oil consumption . She is at about 12,500 miles . I have noticed a slight miss now and then in the left pipe which is the rear cyl......
Old 01-12-2014, 10:33 PM   #26
Sumi
Sumi's Avatar
Oddometer: 1,796
http://www.advrider.com/forums/showthread.php?t=940262
Old 01-13-2014, 12:27 AM   #27
two trackin fool
Oddometer: 1,268
Thank You
Times are GMT -7.   It's 08:51 AM.
