Old 01-03-2014, 11:47 AM   #226
JerryH
Oddometer: 5,069
I definitely agree it is not a good idea to apply any force to the fins. But the Vino 125 has two holes in the front face, which is where the holding tool goes. I used the rear face to hold it, which is way stronger than the front, which seems about as fragile as a potato chip.
JerryH is offline   Reply With Quote
Old 01-03-2014, 03:57 PM   #227
Horizontal
Goatin' Around
Horizontal's Avatar
Oddometer: 272
I'm curious if there would be any way of holding the drive end steady from the alternator side? On the Aero it seems possible.
The difference between genius and stupidity is that genius has its limits.
~ Albert Einstein
1983 Honda XL250R 1971 Yamaha DT1E 250 Enduro
Horizontal is offline   Reply With Quote
Old 01-03-2014, 04:39 PM   #228
bikeridermark
Oddometer: 2,347
Originally Posted by RedArrow View Post
You're right, the rollers are supposed to be greased. Glad to hear that you think they'll be OK. I'm looking at about a week until my parts come, so I'll guess I'll just ride till then. Lucky me.
Thanks to you and the others who answered my gasket question. And glad the gasket isn't super-important. I'm happy to leave it be, then.
With the two different types of scooters I've had so far, grease was a no-no in the variator. I've done no research on your aero 125, but I can't imagine grease in an area where it could get thrown on the belt!
bikeridermark is online now   Reply With Quote
Old 01-03-2014, 07:55 PM   #229
DaBinChe
Oddometer: 1,174
On many of those 80's era honda they had grease in the variator/rollers. There is a cap with an oring over the back plate of the variator that keeps all the grease contained. This prolongs the life of the rollers to an incredible amount compared to a dry setup. Don't know why do don't do it anymore, works great.
DaBinChe is offline   Reply With Quote
Old 01-03-2014, 07:59 PM   #230
DaBinChe
Oddometer: 1,174
gitsum ~
I've seen little paint marks on various nuts and bolts on previous bikes and wondered why they were there, as they didn't seem to be serving any "lock-tite" function. I thought it might be some sort of PO Voodoo.
Now I know...
BTW, I just ordered this, so now I have something else to wait for before tearing into my CVT project:
http://www.harborfreight.com/adjusta...nch-36554.html
Went to Andy's, my local trusty auto parts store but they didn't carry anything like it. Closest thing they had for my purposes was a strap wrench or a oil filter wrench. For $5.00, I decided to go with what I ordered.
looking back at your pic of the variator I don't see a spot for the pins of the pin tool to fit into...so not sure if that would work for the variator, maybe the clutch bell if it has holes like most clutch bells do.
Old 01-03-2014, 08:09 PM   #231
bikeridermark
Oddometer: 2,347
Huh, OK. I can't imagine a variator working smoothly with grease in there, but it must have worked.
I've got about 20,000 miles on the sliders in each of my Relexes, and they seem to be fine so far. Will weigh them at next belt change.
Old 01-03-2014, 08:34 PM   #232
scootrboi
scootrboi's Avatar
Oddometer: 1,646
The one I am working on has a lot of years on it-29- but only 12,000 miles. Lots of grease in the variator, but also ground up spacers and a chipped roller. It did sit for 17 years, maybe that did the spacers in. I have been advised to leave it dry with new rollers or sliders. I have to chuckle though, I bought this scooter new, and also bought the shop manual and the service tools for holding the variator and the clutch. From what I am reading, I wonder if I am the only one who did. The variator tool works really well. I will see about the universal holder. They cost me 30 bucks each.
42 years on a Heinkel Tourist
scootrboi is offline   Reply With Quote
Old 01-03-2014, 11:49 PM   #233
JerryH
Oddometer: 5,069
It looks like grease would make the rollers stick, but I believe the rollers on these older scooters are quite a bit heavier than on newer scooters. Seems I remember someone saying the rollers were 16G. Maybe that's why.
Old 01-04-2014, 08:46 AM   #234
Horizontal
Goatin' Around
Horizontal's Avatar
Oddometer: 272
From the NH125 manual:
~ Albert Einstein
Old 01-05-2014, 12:31 PM   #235
Goofaroo
The Piddler
Oddometer: 199
I keep a section of braided nylon rope in my tool box to lock the piston so I can remove variators and such. Just remove the spark plug and feed the rope into the cylinder. You can rotate the engine and use the rope to tell where the piston is on it's stroke. Just feed about a foot or so of the rope into the bore and the the piston will rest against it allowing you to remove the variator.
Goofaroo is offline   Reply With Quote
Old 01-05-2014, 12:44 PM   #236
JerryH
Oddometer: 5,069
You sir have a bright idea. I have never done this on a scooter, but have done it on a few motorcycles, and hundreds of small engines, like those on landscape equipment. Never had an issue. I'm not sure just how fragile a scooter engine is, I can just see bending the rod or something. I learned this technique about 40 years ago. And the old guy who showed it to me learned it as a kid. So it has been around a long time.
Old 01-05-2014, 01:21 PM   #237
Goofaroo
The Piddler
Oddometer: 199
I've been doing it for years as well and never a problem. You can buy a device that is intended to do the same thing that is just a metal post that threads into the spark plug hole but I was afraid that the metal could damage the top of the piston.
Old 01-05-2014, 01:51 PM   #238
scootrboi
scootrboi's Avatar
Oddometer: 1,646
My younger brother suggested I do that when I was changing the timing belt and water pump on my Escort. Just on one cylinder. I used polyester cord and it worked well. The piston is made to bear a great deal of distributed force, like for instance burning gasoline.
Old 01-05-2014, 03:54 PM   #239
YamaGeek
Ancient trailbike padwan
YamaGeek's Avatar
Oddometer: 6,354
This is a small engine shop trick that's been around for a while. It's similar to the screw-in sparkplug-hole piston stop, but without the potential of damaging the top of the piston crown. And because some engine's spark plug holes are angled, those type of 'stops' don't work with them.
We're here because of a love most exestential. (toothy)
YamaGeek is offline   Reply With Quote
Old 01-06-2014, 03:51 PM   #240
Horizontal
Goatin' Around
Horizontal's Avatar
Oddometer: 272
I don't know what's wrong with me, but it even mentioned doing the old rope-in-the-cylinder trick in an old Clymer's manual for my 82 CX500, yet I'd completely forgotten about it. Must be getting old, I guess...
Thanks for reminding me of my impending dotage, Goffaroo.
~ Albert Einstein
Times are GMT -7.   It's 08:28 PM.
