Old 12-01-2013, 03:01 PM   #16
SONICJK OP
Oddometer: 28
Waiting on the tig I decide to build a stove to keep my shop warm. Propane heaters are too expensive an I Have an inexhaustible supply of wood (own a furniture company)
So:
If anyone has ever considered one of these, go for it. It puts out a ton of heat.
I will put a squirrel cage fan blowing into the top section, hopefully keeping superheated air blowing out the vent in the front into the work area.
SONICJK is offline   Reply With Quote
Old 12-02-2013, 03:35 AM   #17
PhiSig1071
What's ******width?
PhiSig1071's Avatar
Oddometer: 2,438
That's just cool. Er, hot?
Which one of you FF's was it?...FOUNDER!
Entia non sunt multiplicanda praeter necessitatem
PhiSig1071 is offline   Reply With Quote
Old 12-02-2013, 02:41 PM   #18
Canuman
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,634
I had one of those double-barrel stoves in my last shop. It was 40' x 60', with 14' ceilings, and you could get the place hot enough to start sweating at below zero.
Just make sure you've got steel, not pot metal barrel bungs. The pot metal melts, and the thing takes off like a rocket!
The Rock 2013 RR
http://advrider.com/forums/showthread.php?t=915172
Dual Sport Luggage Racks: http://www.moto-racks.com
hONORARY mEMBER fIRST aMERICAN cHAPTER tEAM nONGA (pROVISIONAL wING)
Canuman is offline   Reply With Quote
Old 12-02-2013, 05:15 PM   #19
SONICJK OP
Oddometer: 28
Thanks canuman.
I think mine are steel, but I know what you mean! I took the large bung out trying to let a little more air in. When I closed the door smoke built up, billowed out the hole and then lit and it was like a flame thrower for a second I about shit myself!
Old 12-02-2013, 06:55 PM   #20
Canuman
Crusty & Unobliging
Canuman's Avatar
Oddometer: 4,634
Yep. You've had the experience. We built ours with the bungs toward the bottom. Everything went nicely until one cold day when we decided to put the wood to 'er, and the zinc bung just turned into soap. With that big old draft open, everything started roaring and shaking. I swear we could see the fire through the sides of the stove. Luckily, we found a stick of wood of the right diameter, and plugged it. Next day, we had steel in and didn't have a problem afterward.
Likely the cheapest high-output stove that can be found, if you're not particular about EPA.
Originally Posted by SONICJK View Post
Thanks canuman.
The Rock 2013 RR
Old 12-03-2013, 04:12 PM   #21
2WheelTrampin
Oddometer: 3,877
Man I love SR500s, my buddy had one, and prior to blowing it up he'd always beat me in the drags on my ironhead, that thing was bad to the bone!
2WheelTrampin is offline   Reply With Quote
Old 12-07-2013, 08:54 PM   #22
SONICJK OP
Oddometer: 28
Slow progress.
I got the stem pressed out of the new triple, put the SR stem in its place.
Ordered bearings, tigged up some handlebars, got the gussets welded in and the shock mounts welded in.
Slowly coming along.
Pictures soon
Old 02-10-2014, 10:39 AM   #23
fleshpiston
fleshpiston's Avatar
Oddometer: 598
Any updates on this cool build?
and some cheapy shocks that didnt get used
Are these cheapy shocks for sale?
SRX600
SRX250
SR500
KLR650
fleshpiston is offline   Reply With Quote
Old 02-15-2014, 04:43 PM   #24
SONICJK OP
Oddometer: 28
I'm glad you asked haha.
Yeah I have finally gotten back Into it.
Ive even side tracked restoring a 1935 Hardinge Lathe
On the SR I got the tank mocked up in styrofoam
Then striped the wiring harness of all the crap I don't need and welded in a plate for all the electronics
Now should start assembly for testing before final tear down for finish work but there's still a long way to go.
Anyone know how I can get brake lines shortened? I prefer not to buy new ones
Old 02-15-2014, 04:44 PM   #25
SONICJK OP
Oddometer: 28
And sorry on the shocks :) they will get used on a cheap cb360 build that will fund the next bike
Old 02-15-2014, 04:47 PM   #26
SONICJK OP
Oddometer: 28
Oh,
Also got the front brake worked out which was a bitch.
After fighting with making an adapter for forever I finally grabbed the TIG and chopped up and old bracket and welded some 1/2" 6061 to it and redid all the mount points. It turned out well, still needs final cleanup
Old 02-15-2014, 05:02 PM   #27
16VGTIDave
blame Reaver...
16VGTIDave's Avatar
Oddometer: 526
Thanks for the update, you're making progress!
I think you'd be better off getting a custom brake line made. There are many shops that can do it, as well as online shops. It cost me $40 including shipping and taxes to get a braided line made with the correct fittings on each end. Cheaper than a 30 year old OEM line, and it should outlast the bike. I also prefer the feel of the braided line over the squishy rubber lines, so that is a bonus to me...
Keep at it, it helps inspire the rest of us to get to work!
16VGTIDave is online now   Reply With Quote
Old 02-16-2014, 07:33 AM   #28
joe cool
joe cool's Avatar
Oddometer: 997
I'm in for the build
I've been into SRs for a long time.
"One more day I find myself alive
Tomorrow maybe go beneath the ground"
Garcia/Hunter
joe cool is offline   Reply With Quote
Old 02-16-2014, 08:27 AM   #29
SONICJK OP
Oddometer: 28
Thanks Joe,
Although the only thing left SR on this one will be the engine and wheels ha!
Old 02-16-2014, 08:44 AM   #30
fleshpiston
Oddometer: 598
Sweet lathe!
I get all my brake lines here ... http://www.rennsportautoparts.com/
about $22 per line, made to order
SRX600
SRX250
SR500
KLR650
Times are GMT -7.   It's 09:11 PM.
