Old 11-22-2013, 10:22 PM   #31
Offroadie1
Oddometer: 31
$20! Pah! I've thrown more at a dog that was biting my leg.
Offroadie1 is offline   Reply With Quote
Old 11-22-2013, 10:48 PM   #32
pilo OP
Rhymes with below
pilo's Avatar
Oddometer: 915
Country Doc - Hardwire is the way to go. A 4s will run for a little over 2 hours with no power. Remember you need the power to the phone to be 5v so you can't splice in an iphone charge cable without stepping down the power from 12v. The black box I'm working on will have this sorted but for now you'll should look for a marine quality USB plug that has 12v in. Don't get a normal lighter socket with one of those push-in USB plugs. It falls out...ask me how I know! Also it is a good idea to make a support for the power wire going into the phone. A lot of off-road pounding can make the plug on the phone weak/loose.
The odo adjusts with the volume buttons or the touch screen.
Bruno - I understand exactly what you are saying. You want a scaling factor for the distance. From the events I've done the mileage has been surprisingly dead on since typically the sections are pre-run by a number of different people with different setups. Regardless we'll talk about the difficulty to add a scaling factor. Thanks for the feedback.
Also - I'm going to be somewhat away from the keyboard for a few days, so it might take some time to get responses for the next little while.
pilo is offline   Reply With Quote
Old 11-23-2013, 01:05 AM   #33
Happe
Offroad Nut
Happe's Avatar
Oddometer: 679
thanks for the tip with iOS
Updated from 6.1.4 to 7.0.4 and the buttons are fine
Quickest Support ever
Stefan
Happe is offline   Reply With Quote
Old 11-23-2013, 07:28 AM   #34
BC61
BC61's Avatar
Oddometer: 1,259
Check out the Lifeproof case. The plugin is rock steady held by the narrow opening in the case.
BC Moto Adventures https://www.facebook.com/pages/BC-Mo...2554006?ref=hl
My experience at Dakar 2012 www.bc2dakar.com
BC61 is offline   Reply With Quote
Old 11-23-2013, 12:43 PM   #35
kamanya
Andrew to most
kamanya's Avatar
Oddometer: 1,305
Brilliant! Some shekels have arrived in your account from sunny South Africa.
I look forward to trying it out in the field.
I often wonder where that road goes? And that, has usually made all the difference. Appologies to Mr Frost
kamanya is online now   Reply With Quote
Old 11-23-2013, 09:56 PM   #36
theantipaul
Reforming Neandertal
theantipaul's Avatar
Oddometer: 1,152
FYI, I tried out my Scosche remote with this app and the volume controls work with it just like the the volume buttons on the iPhone to adjust tenths.
Now to make a case/mount.
This is going to be cool!
degarate@highwaydirtbikes.com
Man lived, Man suffered, Man died
theantipaul is offline   Reply With Quote
Old 11-25-2013, 03:25 PM   #37
Biped
NooB Again
Biped's Avatar
Oddometer: 323
Couple of questions:
1. If you are stationary, will the mileage continue to accumulate based on GPS, similar to my Garmin. I can "ride several miles" while having lunch. :)
2. How does the iPhone GPS hold up in woods riding with heavy cover. What happens to the trip meter when GPS signal is lost or interrupted. My primary use would be for AMA Dual Sport events.
Added benefits to this app is that you can zero, increment and decrement on the move. Now I just need to find a waterproof case and mount, for those of use not in the desert.
If it moves and it should not, duct tape it, if it does not move and it should WD40 it!
Biped is offline   Reply With Quote
Old 11-25-2013, 03:28 PM   #38
mtbdemon
mtbdemon's Avatar
Oddometer: 988
Also, what mount do you recommend for the Iphone using this app. Thanks!
I am a leaf on the wind, watch me.....ride (I know, it makes no sense)
2007 YZ 250F SOLD
1998 KTM 620 Adventure
2004 KTM 200 EXC
mtbdemon is offline   Reply With Quote
Old 11-25-2013, 03:38 PM   #39
Maineroot
Oddometer: 142
I used the Ram Mount X MOUNT
It looks flimsy- but this held up for over 1500 miles of offroad torture during the Mexican 1000. I zip tied the unit to the frame as a failsafe.
#34 MX1K
TEAM GREENWOOD: Kali Protectives, Hammer Nutrition
Maine Root Handcrafted Beverages, Darco Boot, ATOMIC MOTO,
Klim Riding Gear, Flexx Bars, Seat Concepts Seats, CJ DESIGNS PEGS, FORMA
BOOTS, Tj's Cycle, Austin TX
Maineroot is offline   Reply With Quote
Old 11-25-2013, 06:07 PM   #40
Whatever Dood
No title available
Whatever Dood's Avatar
Oddometer: 36
The code is written so that the ODOs will not advance if you're not moving, and as long as you've got a stable GPS signal. If, however, the signal gets wonky [1] and the app thinks you're moving, then yes, the ODO will advance. Usually this means the ODO will tick up by a hundredth or two. I used the app at the 2013 AMA Shenandoah 500 and I didn't notice it log mileage during either lunch .
Speaking of the Shenandoah 500, the app had no trouble picking up a pretty strong GPS signal (+/- 10 meters), including on the George Washington Nat'l Forest trails/roads with loads of tree cover.
My iPhone 5 survived the S500 like a champ in an Otterbox on a Ram X-mount.
[1] "Wonky" meaning the device may temporarily lose its GPS lock (or whatever). As it reacquires and zooms in on your location the app might think you've moved.
Whatever Dood is offline   Reply With Quote
Old 11-25-2013, 07:07 PM   #41
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,311
Purchased.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
Old 11-25-2013, 09:21 PM   #42
frog
frog's Avatar
Oddometer: 2,774
I never thought I'd buy an Icrap but off to buy a used one.
Sent from my DROID RAZR
Thank you MX1WEST, Highway Dirt Bikes Lindsay Machine, Smart Performance, SPS for the Support
257x Solo Baja 1000
If I had not some strength of will I would make a first class drunkard--Shackleton
frog is offline   Reply With Quote
Old 11-26-2013, 11:33 AM   #43
Whatever Dood
No title available
Oddometer: 36
Thanks very much to everyone who's giving the app a shot. Looking forward to your feedback.
Old 11-26-2013, 11:35 AM   #44
YOGOI
Prick
YOGOI's Avatar
Oddometer: 3,462
The term is "I-Poo" . Lets go rally!!!!
Any bike can be taken off road. The question is; How much fun did you have doing it?
04 950 GO!!!!! 2011 250 XC 89 Transalp 69 350 CL 04 225 XT
08 450 XC-F SOLD to a good home
YOGOI is offline   Reply With Quote
Old 11-26-2013, 12:37 PM   #45
Happe
Offroad Nut
Happe's Avatar
Oddometer: 679
Isn't that for the iPood ?
Times are GMT -7.   It's 11:59 PM.
