Old 12-01-2013, 02:20 AM   #16
OldDog OP
Smelly Adventurer type
OldDog's Avatar
Oddometer: 4,615
Bit of progress over the weekend. Frame is painted and I've got the bike rolling again. Since this pic i've fitted the radiator, brakes etc back up. I'm in a bit of a rush to get the main bits back on as i start a new job on Wednesday which will have me living away from home during the week, don't want any important bits to go missing or (more likely) me forgetting where bits go.
Looks pretty sexy in white, but it gets dirty real easy.
Your time is limited, so don't waste it living someone else's life. - Steve Jobs
Yesterday afternoon I was planning to ride Dakar, this morning I was planning to throw up in my helmet - Boris Mihailovich
Objects in the rear view mirror.....appear to be losing - Me
OldDog is offline   Reply With Quote
Old 12-01-2013, 08:05 AM   #17
willh
willh's Avatar
Oddometer: 42
What's the tank seat arrangement going to be?
willh is offline   Reply With Quote
Old 12-01-2013, 11:40 PM   #18
OldDog OP
OldDog's Avatar
Oddometer: 4,615
At this stage Will I'm gonna go with the standard tank and seat as I want to get the bike streetable, then do the blower which will dictate how the body work will end up. Ideally my plan is to make a tank out of thin alloy sheet laminated and blind rivetted together. Think of the skin on a fighter plan with its exposed rivet heads and you'll get the rough idea. Not easy but should be a good conversation starter
Old 12-07-2013, 04:49 PM   #19
OldDog OP
OldDog's Avatar
Oddometer: 4,615
Well I have it basically back together and running, considering of mnodified the wiring to get the electrics, battery etc to under the seat, I'm pretty happy with that result
The empty space where the battery used to go down at the lower front will be the position for a new fabricated oil tank. Once that is done I'll take off the old oil tank and that's where I'll mount the blower.
Things are going to slow down for a bit as I've taken up a new job which has me out of town all week, so I will be mainly working on it during weekends.
Oh and with the 950S swingarm fitted I'm coming up with a rake of 21 degree and a trail of 103mm. Seems a bit out to me so will remeasure again next weekend.
Cheers
OD
Old 12-07-2013, 06:53 PM   #20
Te Hopo
AKA Deanohit
Te Hopo's Avatar
Oddometer: 1,402
I've always liked the Super Dukes and swore I would own one one day after taking a spin on a SD R.
This is a great sounding project, it looks real promising stripped down with that longer swingarm.
Te Hopo is offline   Reply With Quote
Old 12-08-2013, 11:29 AM   #21
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,115
Extending the forks an inch or three will get the trail back in line. That config looks pretty sweet! Have you considered using an SM or SE oil tank and motor hangers?
snowhawk jockey screwed with this post 12-08-2013 at 11:46 AM
snowhawk jockey is offline   Reply With Quote
Old 12-14-2013, 02:28 PM   #22
OldDog OP
OldDog's Avatar
Oddometer: 4,615
Thanks Te Hopo, yeah mate she's gonna be a beast!
Snowhawk, yeah I wanted to lengthen the forks maybe 2 inchs at the most but I've been told you can't do that with Duke forks. I can maybe get 3/4 inch if I'm lucky. So I'll probably have to get a hold of super moto forks, then I'll need brakes as well.....the list never stops hey? Unless theres a way to modify my adv forks by fitting the bottoms of the super dukes forks into them. I'm going to ask over on Orange crush and and see what the collective knows about this sort of stuff.
Cheers
Old 12-14-2013, 11:08 PM   #23
mousitsas
mousitsas's Avatar
Oddometer: 2,755
Have you ridden the bike as it stands? How does it handle? I cannot see why by changing the swingarm the geometry is affected so much. If so, then can you take some preload off the back to see if you could bring it level? Also, the SD rear shock is very easy to shorten without affecting stroke.
Old 12-16-2013, 12:56 AM   #24
OldDog OP
OldDog's Avatar
Oddometer: 4,615
That's a sensible idea! All I need to do is shorten the chain and finish the battery box and it'll be rideable. I ll give it a try.
Old 12-16-2013, 06:15 AM   #25
tinwelp
Professional Idiot
Oddometer: 142
OD
OD, why fabricate an oil tank? The standard SM oil tank is mounted pretty much where you intend to install your custom tank. I'm all for doing stuff "just because", but why reinvent the wheel when the main point of the project looks like it should be the forced induction? ... of which I'm eager to see how you progress!
Carry on good man!
Cheers... Paul
tinwelp is offline   Reply With Quote
Old 12-16-2013, 06:15 PM   #26
duxrneet
duxrneet's Avatar
Oddometer: 670
Got me droolin' - 2WD would be the cherry on top. If I can encourage you in that direction, I will!
Current: 2004 CBR600F4i, 2001 KTM 520EXC - Past: 1995 XR600R, 1993 DR350 (Dirt Model), 1987 CBR600F
duxrneet is offline   Reply With Quote
Old 12-17-2013, 01:52 AM   #27
OldDog OP
OldDog's Avatar
Oddometer: 4,615
2wd? You guys are a bad influence I tell ya. Re oil tank yeah an em would fit but I'm also after extra capacity and would like to fit oil cooler tubes as well. So have been investigating blower types and was going to use a Sprintex...only it won't fit neatly. I want to use a rootes type blower rather than a turbine as the rootes makes more of that sweet, sweet blower sound. At this point looking at an AMR 500 if I can get one cheap.
Old 12-17-2013, 01:35 PM   #28
Honkey Cat
Tailights Fade!
Oddometer: 1,104
cool project
My favorite philosopher is Cha Ching !
Honkey Cat is offline   Reply With Quote
Old 12-17-2013, 02:02 PM   #29
snowhawk jockey
Slack Jaw Gaper
Oddometer: 1,115
Cheers
http://www.ebay.com/itm/KTM-950SM-95...7cf648&vxp=mtr
Hey Hey! I have a Right side front radial mount four pot caliper for the SM forks, if you end up going that route. I used an EXC line and 16mm master to run it.
snowhawk jockey screwed with this post 12-17-2013 at 02:45 PM
Old 12-19-2013, 03:58 PM   #30
stevh0
Super Retard.
stevh0's Avatar
Oddometer: 1,428
Subscribed.
Sooo... wheres the blower?
06 950S
Yamaha YZ250WR
Ex 1150GS, 650R, Ex 950SE, Ex 950ADV
Ex SM610, FS570, WR450, Africa Twin(s)
stevh0 is offline   Reply With Quote
Times are GMT -7.   It's 12:31 AM.
