Old 12-08-2013, 05:34 PM   #46
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 46,612
Originally Posted by Flash412 View Post
Shogs, you will do FINE. And your NEXT rebuild project will not be anywhere NEAR this anal-hyphen-retentive.
I got a hunderd bucks says you're wrong.
I guess your get up and go needs a coffee. - Drif5
Drif10 is offline   Reply With Quote
Old 12-08-2013, 05:36 PM   #47
*Gravy*
Jedi Loser
*Gravy*'s Avatar
Oddometer: 4,124
Wow Gwen! Super cool thread. I look forward to reading your progress!
:woot
I am overcome with joy at seeing you. However, that is a sausage in my pocket.
*Gravy* is offline   Reply With Quote
Old 12-09-2013, 11:33 AM   #48
Flash412
Elk Biffer
Flash412's Avatar
Oddometer: 8,988
Even her Tupperware contains Tupperware.
Hmmm... no bet.
Click here for Gathering Speed - Tales of Motorcycles and Life
60 countries/6 continents, 40/6 on motorcycles, so far, and counting...
50 US states, 49 via moto. ɹǝpun uʍop uǝǝq ı
Links to Forty years of my Adventure RIDE REPORTS
Helmet laws interfere with natural selection.
Flash412 is offline   Reply With Quote
Old 12-09-2013, 12:12 PM   #49
squish
Out of the office.
Oddometer: 6,203
I'm late to this party, but I will be watching this.
I'd suggest that in place of replacing every screw with stainless. I might cost less and work better to have the hardware cleaned and cad or zinc plated.
You will end up with hardware that you know works in the spot it came out of and you will not open up a chance for all the problems that come with stainless steel in aluminium or stainless, aluminum and regular steel.
Also the other piece of advice I've heard
No matter what do something everyday, no matter how small that moves the project forward.
Even if it's just cleaning or labeling a couple of parts.
This momentum helps to keep the project moving forward. Especially in the late middle stages when the project is at it's most challenging. That period when it seems like it will never get back together again, or be just simply get finished.
On vacation for a spell
squish is offline   Reply With Quote
Old 12-09-2013, 12:53 PM   #50
Flash412
Elk Biffer
Flash412's Avatar
Oddometer: 8,988
All good advice. As a veteran of many successfully completed projects, I'll offer some more.
Harbor Freight sells a cheapo ultrasonic cleaner. Using this with Simple Green is a great way to clean handfuls of small nuts, bolts and washers.
Stainless fasteners are often the absolute WRONG material in certain applications. If you want to substitute them, read up on it so you understand when not to use them. Two words: galvanic corrosion.
The "heat wrench." Bolts that don't want to give it up can often be persuaded with judicious application of a propane flame-tip. Attempting to remove brake disks cold will destroy the bolts. Ten seconds with a heat wrench on the head of each bolt will melt the Loc-Tite and they come right out, happy to be reused.
If you're disassembling BMW transmissions and rear ends and such, put the cases in the oven and heat them to about 350F. Shafts removed from the freezer will drop right in. Do NOT beat the shafts into or out of the cases.
Bearings can be boiled in motor oil on the stove top to safely get them hot enough to drop onto frozen shafts where they will seat properly without any force.
NEVER use LocTite (or equivalent) on any bolts that go into or through body panels.
Set GOALS. Put several sticks in the ground on the calendar for certain milestones such as when given sub-assemblies will be completed. Having a PLAN on the calendar gives great satisfaction when you meet goals that were randomly set in advance, not knowing what you know when you finally reach them. And remember than it really is just a Plan, so if stuff in your life comes up, you CAN let it slip.
Old 12-09-2013, 02:01 PM   #51
kbasa
Colnago!
kbasa's Avatar
Oddometer: 68,335
OBTW... where are the LABELS for all the little compartments?
I'm a ziploc baggie kind of guy. All the fasteners and the functional bit are stored in a single bag. That way, there's no trying to remember whether I need to M6x10 or the M6x15 bolts to get that thing reassembled.
But hey, that's me.
Go GWEN!
IMHO.
Fuck Cancer. Ride bikes. - dave + tina
kbasa is offline   Reply With Quote
Old 12-09-2013, 02:04 PM   #52
kbasa
Colnago!
kbasa's Avatar
Oddometer: 68,335
Yep. I count "buying parts", "reading the manual", "cleaning the shop" and "tool purchase" as an activity, which keeps it moving forward.
Inactivity is the death knell for a restoration, so I don't start until I know I have the time, money and resources in place to go all the way through it.
I didn't obey that one time and, as a result, I have a 1982 Honda CB750F in boxes in my garage. It's been that way for 15 years now.
IMHO.
Old 12-09-2013, 03:32 PM   #53
Flash412
Elk Biffer
Flash412's Avatar
Oddometer: 8,988
Originally Posted by kbasa View Post
I have a 1982 Honda CB750F kit/puzzle in my garage. It's been that way for 15 years now.
fixt.
Old 12-09-2013, 05:23 PM   #54
kbasa
Colnago!
kbasa's Avatar
Oddometer: 68,335
fixt.
Still got the manuals and some photos, even though the photos are of someone else's fully assembled CB750F.
IMHO.
Old 12-09-2013, 08:05 PM   #55
Tman66
Shawn's bro
Tman66's Avatar
Oddometer: 8,809
So nice to see you putting love back into your ride, Gwen.
What's a little blood?
Tman66 is offline   Reply With Quote
Old 12-12-2013, 07:51 AM   #56
Rapid_Roy
finally understands
Rapid_Roy's Avatar
Oddometer: 25,593
I knew nothing of this!
As somebody who keeps every bike he buys, I approve!
What?!
Rapid_Roy is offline   Reply With Quote
Old 12-12-2013, 08:06 AM   #57
Shoganai OP
Let's do some livin'
Shoganai's Avatar
Oddometer: 1,761
Thank you all for posting advice, pointers and humor.
Galvanic corrosion, got it!
Kbasa, I really like and understand "Yep. I count "buying parts", "reading the manual", "cleaning the shop" and "tool purchase" as an activity, which keeps it moving forward."
I've given up trying to fine a non-BMW alternative pin release tools.
I'm going to make one last ditch effort and post in all my threads and the LD Mailing list to see if someone has them I can borrow or lease.
This is what I need.
Sparks has the best prices, but they are still pretty damn spendy.
These are the kind of tools that are so narrow on size tolerances that the wrong ones can make this already tedious project a real PITA.
http://www.sparks-shop.lv/v3/index.p...emid=7&lang=en
1501+1511 = $45.28
1504+1514 = $51.79
1502+1512 = $49.90
This is the OEM supplier for BWM with part numbers and all.
88 88 6 611 131
Stahlwille 1501+1511
Kabelex Round Pin Release Tool, Small. Pin release tool for round receptacles with locking tongue and contact size of 1.5mm. Bushing size 2.9mm inside, 3.3mm outside. This tool has an ingenious feature to protect the tip. A sliding cover is built into the handle. Also used on BMW, Mercedes, Fiat, Opel and VW-Audi. (Note: the factory tool can be marked number 610 301).
Special Order $73.55
88 88 6 611 132
New Number: 83 30 0 495 385
Stahlwille 1504+1514
Kabelex Round Pin Release Tool - Medium. For contact size 2.5mm, Bushing size 4.0mm inside, 4.4mm outside. With sliding cover.
Special Order $84.31
88 88 6 611 133
New Number: 83 30 0 492 708
Stahlwille 1502+1512
Kabelex Round Pin Release Tool - Large. For contact size 3.5mm, Bushing size 4.4mm inside, 5.0mm outside. With sliding cover.
Special Order $79.99
Today I have to clean house, pay bills and wash clothes but I hope to free up enough time to finish the wiring harness table/board. If I can get that done, I'll start pinning the OEM harness to it and begin to split it open, trace and label wires.
This will help me learn to read and understand wiring schematics.
Nana korobi ya oki
"Be who you are and say what you feel because those who matter don't mind and those who mind don't matter "- Dr Seuss
Shoganai is offline   Reply With Quote
Old 12-12-2013, 09:10 AM   #58
El Guero
V4 Whore
El Guero's Avatar
Oddometer: 9,727
Gonna watch this one... Over the course of time, I think I've removed/repaired/replaced just about every piece of my Magna. I'd be tempted to someday pull it apart again like you are doing here, but I'm afraid it would just become a basket case I think you will do better!
El Guero is offline   Reply With Quote
Old 12-12-2013, 09:19 AM   #59
hankgs
Oddometer: 1,880
Awesome thread! I wish I had the balls and know-how to do a project like this...
hankgs is online now   Reply With Quote
Old 12-12-2013, 09:29 AM   #60
Shoganai OP
Shoganai's Avatar
Oddometer: 1,761
I have neither balls nor this mythical know-how you speak of.
If ignorance is bliss, then I'm in Heaven.
Nana korobi ya oki
Times are GMT -7.   It's 06:10 PM.
