Old 12-12-2013, 10:06 AM   #61
*Gravy*
Jedi Loser
*Gravy*'s Avatar
Oddometer: 4,124
Originally Posted by Shoganai View Post
I have neither balls nor this mythical know-how you speak of.
If ignorance is bliss, then I'm in Heaven.
The people that assemble these things at the factories aren't typically rocket surgeons. Just normal folk working hard for a living.
I'd love to tackle a project like this some day.
You're an inspiration Gwen.
I am overcome with joy at seeing you. However, that is a sausage in my pocket.
*Gravy* is offline   Reply With Quote
Old 12-13-2013, 06:29 AM   #62
johnwoodsrides
johnwoodsrides's Avatar
Oddometer: 134
And most of the factory folks couldn't put a whole bike back together, they assemble one or two parts at their station. Sure, they rotate stations, but I doubt they could do a bike start to finish. A buddy of mine works on the floor at HD, even the torque settings are pre-programmed into the computer for the part he installs. He has only 90 seconds to install his part, get it torqued and pick up the next part for the bike that is coming. Doesn't take any mechanical knowledge, at least at HD, not sure how they do it at BMW or Honda or.......
'06 950 SM
johnwoodsrides is offline   Reply With Quote
Old 12-13-2013, 07:30 AM   #63
Shoganai OP
Let's do some livin'
Shoganai's Avatar
Oddometer: 1,761
The first is the Official BMW tools.
The second where I found them WAY Cheaper
Stahlwille 1501+1511
For contact size of 1.5mm. Bushing size 2.9mm inside, 3.3mm outside. $73.55
http://www.toolsource.com/15011511-k...-p-104402.html
Stahlwille 1504+1514
For contact size 2.5mm, Bushing size 4.0mm inside, 4.4mm outside. $84.31
Stahlwille 1502+1512
For contact size 3.5mm, Bushing size 4.4mm inside, 5.0mm outside. $79.99
http://www.mytoolsforyou.com/automot...-95929-07.html
Sale Price: $11.19
contact size 2.5mm,
http://www.mytoolsforyou.com/automot...-95929-06.html
Sale Price: $11.19
contact size 3.5mm,
http://www.mytoolsforyou.com/automot...-95929-02.html
Sale Price: $8.39
Nana korobi ya oki
"Be who you are and say what you feel because those who matter don't mind and those who mind don't matter "- Dr Seuss
Shoganai is offline   Reply With Quote
Old 12-13-2013, 08:01 AM   #64
AntonLargiader
AntonLargiader's Avatar
Oddometer: 4,228
I have the BMW 61 1 132 tool; 4mm ID.
Old 12-13-2013, 08:06 AM   #65
Shoganai OP
Shoganai's Avatar
Oddometer: 1,761
Thanks Anton.
Nana korobi ya oki
Old 12-13-2013, 08:06 PM   #66
Waco
Renegade Sickle Hound
Waco's Avatar
Oddometer: 14,972
I've talked to assembly guys at one of the Cat plants. "Is there a procedure for free-wheeling the final drives in case the engine is down?" Silence.
Support the AMA.
Waco is offline   Reply With Quote
Old 12-14-2013, 11:18 AM   #67
Shoganai OP
Shoganai's Avatar
Oddometer: 1,761
Today I finally get the wiring harness board put together and hung.
This is the original 1993 fuel injection harness. I found a couple of holes and a cluster of cut wires.
I don't have a clue what those cut wires went to, but I'm sure I can find out. Clearly the bike run fine without them because these were not cut by me and I've had it since 1999.
Nana korobi ya oki
Old 12-15-2013, 01:58 PM   #68
Shoganai OP
Shoganai's Avatar
Oddometer: 1,761
The following posts represent the deconstruction of the fuel injection wiring harness.
Some of the pics will have notes. All of the pics are intended to help me remember of what it looked like. After I make this post I'll take it off the board and set it aside for now. I'll leave all the zip ties holding the wires together to keep each cluster together for now.
Then I'll start on the main harness.
I did this to avoid cutting any wires while removing the covering.
Steve reminding me I cut this off while trying to scavenge parts for another project. I still have to connector.
Nana korobi ya oki
Old 12-15-2013, 01:59 PM   #69
Shoganai OP
Shoganai's Avatar
Oddometer: 1,761
As far as I can tell, the joining of the green/white wires and the yellow/brown wires must have been done this way due to assemble needs, not function needs.
I have a couple of observations.
One: If stupid is as stupid dose then I'm fairly stupid.
Two: Anything that hurts that bad should look worse.
Three: 18 year old electrical tape feels like baby snot mixed with contact cement.
Four: #11 Exacto blades rammed under thumb nails when Stupid forgot about not cutting towards one's self SUX!
Nana korobi ya oki
Old 12-15-2013, 02:19 PM   #70
doc4216
Chronic High Fiver
doc4216's Avatar
Oddometer: 404
Note-bloody hand needs repaired!
"A straight road never made a skilled rider"
'13 Tiger 800 Roadie
doc4216 is offline   Reply With Quote
Old 12-15-2013, 02:27 PM   #71
Shoganai OP
Shoganai's Avatar
Oddometer: 1,761
Nana korobi ya oki
Old 12-15-2013, 02:56 PM   #72
doc4216
Chronic High Fiver
doc4216's Avatar
Oddometer: 404
Totally made my day!!! lol, "just a flesh wound"
Old 12-16-2013, 10:11 AM   #73
Shoganai OP
Shoganai's Avatar
Oddometer: 1,761
Main wiring harness mounted on the board. Due to the large number of connections, I'm going to identify and tag each one before
cutting it open.
At least it can't hurt, might help and looks good on paper.
I keep thinking this is one of those times where you might hear, "Hold my beer and watch this".
Nana korobi ya oki
Old 12-16-2013, 09:33 PM   #74
Bonsai Elephant
Bonsai Elephant's Avatar
Oddometer: 18,756
Impressive stuff Shogs, but a quick question, as someone else who has never done this I could only approach this by building the new loom over the existing loom, I figured that was the object of it.
Photos, notes, tags, none of that would help, and memory sure as hell wouldn't!
Is there any particular reason why you didn't choose to do that?
Bonsai Elephant is offline   Reply With Quote
Old 12-16-2013, 09:58 PM   #75
Shoganai OP
Shoganai's Avatar
Oddometer: 1,761
When I'm ready to build the new ones that's what I'll be doing. Right now all I'm doing is inspecting and dissecting. I'm learning how it's put together by taking it apart. Today all I did was learn to read schematics, compared Clymer to original German versions, translate stuff to English and print large format schematics and label them.
Nana korobi ya oki
Times are GMT -7.   It's 06:41 AM.
