Old 11-25-2013, 08:28 PM   #1
DOUBLE-O G OP
Smooth Operator
DOUBLE-O G's Avatar
Oddometer: 2,563
Honda XRM Dual Sport 125
Another hybrid, this one from the Philippines:
SPECIFICATIONS
Engine Type4 - Stroke OHC Air Cooled
Displacement124.8 cc
Bore & Stroke52.4 mm x 57.9 mm
Starting SystemElectric / Kick
Ignition SystemDC-CDI (Capacitor Discharge Ignition)
Transmission TypeConstant Mesh 4-Speed
Gear Shift PatternRotary Type / N-1-2-3-4
Suspension (Front)Telescopic Fork
Suspension (Rear)Twin
Brake System (Front)Hydraulic Ventilated Disk
Brake System (Rear)Mechanical Leading Trailing
Combination Brake SystemN/A
Tires Size (Front)2.50 - 17 M/C 33L
Tires Size (Rear)2.50 - 17 M/C 38L
Wheels TypeSpoke
Over-all Dimensions (LxWxH)1,902mm x 805mm x 1,072mm
Wheelbase Dimensions1,239 mm
Dry Weight99 Kg
Seat Height776 mm
Ground Clearance136 mm
Fuel Tank Capacity3.8 Liters
FuelUnleaded Gasoline (93+ or above octane rating)
Fuel SystemCarburetor
Engine Oil Capacity0.9 Liter
Automatic Headlight On (AHO)Equipped
Parking BrakeN/A
Key ShutterN/A
Side Stand SwitchN/A
Maximum Horse Power [kW (PS)]6.9 (9.4) @ 7,500 rpm
Maximum Torque (N.m)10.4 @ 5,000 rpm
http://www.hondaph.com/showcase/xrm125-dual-sport
The site is in English!
2013 Honda Super Cub
DOUBLE-O G is offline   Reply With Quote
Old 11-25-2013, 08:31 PM   #2
DOUBLE-O G OP
Smooth Operator
DOUBLE-O G's Avatar
Oddometer: 2,563
Old 11-25-2013, 09:17 PM   #3
damasovi
damasovi's Avatar
Oddometer: 2,627
i do not know what to say.. i know dp bike is a compromise but this one looks odd....
Damasovi
A motorcycle or scooter always turn a bad day into a great time!
KLR 650, Honda Beat scooter!!
damasovi is offline   Reply With Quote
Old 11-25-2013, 09:45 PM   #4
brianwheelies
Iron toocus
brianwheelies's Avatar
Oddometer: 3,703
Or, more appropriately, ugly!
Originally Posted by Skowinski View Post
Speaking of dumps, that coffee is working for sure, gotta scurry and perch on the thundermug...
brianwheelies is offline   Reply With Quote
Old 12-27-2013, 07:16 PM   #5
brianwheelies
Iron toocus
Oddometer: 3,703
This bike may look better with a low front fender.
The specs look good like front and rear disc brakes
Old 12-27-2013, 08:03 PM   #6
MarylandStrom
Oddometer: 338
I like the looks of the bike, but the front fender is killing me. Maybe a lower version would look good, but more than likely a different style high fender would work.
MarylandStrom is offline   Reply With Quote
Old 12-27-2013, 11:59 PM   #7
JerryH
Oddometer: 5,069
It's obviously an underbone type frame, and the engine looks like the same type pf design used for decades in Cubs and Trail 90s. Probably has an auto clutch. I noticed in the specs it says "rotary transmission" That's the one thing I did not like about the Cub. It went around in circles, with no stops. N-1-2-3-4-N-1-2-3--4. Could be very hard to find neutral at a stop, and there was no clutch to pull in. And I agree that fender is ugly. Maybe if it weren't so big.
JerryH is offline   Reply With Quote
Old 12-28-2013, 09:30 AM   #8
gitsum79
Oddometer: 91
Looks like a Honda Wave to me. They just swapped it out with knobby tires, high fender, taller handlebars and a different headlight/fairing.
They should have included a high mounted exhaust and a skid plate.
2009 Honda Rebel 250
2012 Tomos Nitro 150
gitsum79 is offline   Reply With Quote
Old 12-28-2013, 06:04 PM   #9
tdrrally
tdrrally's Avatar
Oddometer: 3,330
21st century trail 110
1980 TS125 project in the corner
tdrrally is offline   Reply With Quote
Old 12-29-2013, 11:16 AM   #10
STROMVADER
STROMVADER's Avatar
Oddometer: 2,100
I'll take the black one. It could use knobbier tires, a skid plate and high mount exhaust though. We NEED something like this over here in the states.
You only LIVE once. Make it COUNT.
F*CK CANCER
Godspeed Dad! RIP 1944-2010
STROMVADER is offline   Reply With Quote
Old 12-30-2013, 04:35 PM   #11
gnadenlos
gnadenlos's Avatar
Oddometer: 77
I like it! I've always wanted a scooter - this one is kinda cool. I test
rode the Zuma and was a bit disapointed and bummed.
We tend to mock what we don't understand!
gnadenlos is offline   Reply With Quote
Old 01-03-2014, 11:49 AM   #12
Horizontal
Goatin' Around
Horizontal's Avatar
Oddometer: 272
Looks like a bike assembled by a hurricane. I'll pass.
The difference between genius and stupidity is that genius has its limits.
~ Albert Einstein
1983 Honda XL250R 1971 Yamaha DT1E 250 Enduro
Horizontal is offline   Reply With Quote
Old 01-06-2014, 12:03 AM   #13
BAJAborn
Oddometer: 45
Considering the world economy, it could very well be the future of DP bikes.
We are all ignorant. . . . .but only in different things.
BAJAborn is offline   Reply With Quote
Old 07-24-2014, 09:14 AM   #14
YamaGeek
Ancient trailbike padwan
YamaGeek's Avatar
Oddometer: 6,173
These bikes have been available in the Far East for years, and yes I like it.
Look at the specs, long stroke thumper 125cc with wide ratio 4 speed gearbox, this bike was meant to play in widely divergent conditions, those of you criticizing it on looks should first ride one before passing judgement.
We're here because of a love most exestential. (toothy)
YamaGeek is offline   Reply With Quote
Old 07-24-2014, 09:39 AM   #15
JerryH
Oddometer: 5,069
Not sure if I like it or not. I like the concept. If it has a real clutch and a centerstand, along with a decent load capacity, I would definitely be interested. The Trail 90/110 has a very low rated load capacity, but could carry nearly twice that without problems. But as cool as it is, I never cared for it's clutchless transmission. But the Trail was built a long time ago, and almost certainly better built and of higher quality than this. There are still millions of Trails running around out there. Like the Cub they are based on, you could beat them to death and they still ran. I just can't see this doing that.
A 200cc or 250cc version would make a great replacement for my XT225 that I sometimes have trouble getting on, due to the high seat height. Not looking for an MX bike.
Times are GMT -7.   It's 10:52 PM.
