Old 11-06-2013, 03:36 PM   #1
bobframe OP
Oddometer: 343
Mounting a heat controller
I am frustrated with the portable heat controller that I bought with my Gerbing heated jacket in 2011...too many wires, wires too short, need extensions, controller has to clip on to something but nothing works very well, etc.
So, anybody solved this with a permanent controller mounted on their '06 1200GS (or something similar)?
I did this on my Honda ST1300 and it was a very clean installation (though when I removed certain body panels the wiring complicated things a bit) and it was easy to simply plug in and dial things up.
I hate to drill holes in my GS, but I love cold weather riding and at a certain point, the heated jacket has to work.
May I see your permanent controller installation?
bobframe is offline   Reply With Quote
Old 11-06-2013, 03:44 PM   #2
spartanman
regret minimizer
spartanman's Avatar
Oddometer: 1,104
Velcro works great. No holes.
spartanman is offline   Reply With Quote
Old 11-06-2013, 04:06 PM   #3
Beezer
Oddometer: 5,935
I made a transistor controller for mine (1150 GS). the power transistor is on the battery box & the control pot in the starter cover
Beezer is offline   Reply With Quote
Old 11-06-2013, 04:16 PM   #4
gto
Slacker
Oddometer: 42
I've had a permanent controller that I've kept and moved to each new bike. In removing it from my last bike, my thoughts were yours exactly... too many wires. So, I bought this: http://www.warmnsafe.com/dual-remote...-heat-troller/
One wire from the battery (a pigtail), and the remote dual controller on top of my clutch reservoir. Brilliant. and, it works brilliantly.
Gary
2014 R1200GSW
2001 Kawasaki Sherpa
gto is offline   Reply With Quote
Old 11-06-2013, 04:31 PM   #5
jdub
Dawg bytes reel gud
jdub's Avatar
Oddometer: 1,894
+1, except I use that industrial strength alternative: Dual-Lock. One piece on the left side aluminum tank cover, another on the back of the controller.
During warm weather the controller stays inside a jacket pocket while hanging in the closet. In cooler weather I remove the seat, plug the controller into the pigtail left connected to the battery, route the cord between the tank and seat and then stick the controller to the tank's Dual-Lock. Stays there in easy reach of my left hand all winter.
Current: 2014 R1200GSW
jdub is offline   Reply With Quote
Old 11-06-2013, 04:38 PM   #6
Hikertrash
Oddometer: 2,993
Remote heat troller velcroed on top of my brake fluid resevoir.
Hikertrash is offline   Reply With Quote
Old 11-06-2013, 06:18 PM   #7
* SHAG *
Unstable
* SHAG *'s Avatar
Oddometer: 4,432
I have mine zip tied to the frame below the seat. Yes, I have to reach a little for it but it's been there a long time and I can find it easy
2013 Yamaha TW200 2k
99-RT- Graphite 50k Gone
01-GS- Mandarin 42k Gone
05-GS- Rock Red 92k
06-GS- Dakar-40k Sold
* SHAG * is offline   Reply With Quote
Old 11-06-2013, 06:24 PM   #8
LaurelPerryOnLand
Oddometer: 3,482
Probably overkill for your single focused need:
http://www.webbikeworld.com/r4/dispatch-1/
Plug your heated clothing directly into this controller...you can adjust it EXACTLY to the heat level you like with 32 different levels available. No other controllers needed or required.
Here's my pictorials of the INSTALL of my 06 GS and 06 RT
GS: http://advrider.com/forums/showthread.php?t=870449
RT: http://advrider.com/forums/showthread.php?t=870941
LaurelPerryOnLand is offline   Reply With Quote
Old 11-06-2013, 08:59 PM   #9
RomaDakota
Illuminatus!
RomaDakota's Avatar
Oddometer: 1,531
http://www.advrider.com/forums/showp...8&postcount=17
I velco the wireless heat controller to the inside of the left hand guard. I have the plugin attached to the frame under the seat. Once mounted, I have to plug in however that is the only wire; I control the dual heat from the wireless controller.
КМЗ Dnepr MT11 // КМЗ M72 // ИЖ Planeta 5 // КМЗ MV750 // Урал М63 // BMW R1200GS 30th
RomaDakota is offline   Reply With Quote
Old 11-06-2013, 09:17 PM   #10
_cy_
Oddometer: 6,436
R80G/S .. switched to wireless dual controller with old style Gerbing.
velcro with safety lanyard looped into handlebar.
going wireless is the answer to wires running everywhere.
extra wire length gets tucked inside inner pocket. with one wire coming out of jacket to power cord.
_cy_ screwed with this post 11-13-2013 at 09:29 PM
_cy_ is online now   Reply With Quote
Old 11-07-2013, 08:34 AM   #11
AMEretired
Oddometer: 119
+1 Makes it easy to switch between bikes as well.
AMEretired is offline   Reply With Quote
Old 11-07-2013, 09:30 AM   #12
orgo
Oddometer: 323
Try the 3M Dual Lock instead of velcro much more secure
orgo is offline   Reply With Quote
Old 11-07-2013, 09:36 AM   #13
papa-alpha
Oddometer: 42
I clip the Gerbing dual controller in the leather case on the back side of my tank bag. Works well. Wires are long enough from there to stand up without unplugging.
papa-alpha is offline   Reply With Quote
Old 11-07-2013, 09:39 AM   #14
NoVa Rider
Oddometer: 2,960
My warmnsafe permanent dual mount on a 2011 GSA:
NoVa Rider is offline   Reply With Quote
Old 11-07-2013, 10:00 AM   #15
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,477
Those will work on a standard GS as well.
Jim
JimVonBaden is online now   Reply With Quote
Times are GMT -7.   It's 04:43 PM.
