Old 12-13-2013, 06:41 PM   #76
XC Rider OP
Motorcycle Vagabond
XC Rider's Avatar
Oddometer: 3,039
UPDATE
Sorry I didn't take any pictures while doing the fab work, but there really wasn't that much to document. In any case, here is my first go at a front fender.
Fender is just a plastic Maier fender that I had lying around from who knows what or when. To mount it to the forks, I used a fork brace for a DRZ that I had to cut in half because the fork tubes are farther apart when in the Versys triples than in the DRZ triples. I then fabbed up an adapter plate to mount the fender to the fork brace pieces using some scrap aluminum that I had laying about the shop. In fabbing up the adapter mounting plate, I decided to extended it to the front of the fender to help possibly support a future fender bag!?
Overall I'm pretty happy with it. I think it's plenty sturdy enough for what it needs to do. However, from an aesthetic point of view, I don't like the fact that you can see the fork brace in two pieces. I much prefer the design that JDrocks has, where his fender mounting bracket lays on top of the fork brace pieces. I'll probably mock up another version over the Christmas holiday.
Tomorrow, if the weather allows it, I'll be headed down to another inmate's garage to get some help with tuning in the suspension for my weight and riding style. So please keep your fingers crossed for me that the rain/wintry mix that they've been forecasting does not happen!
XC Rider
"Motorcycles have put me in touch with wonderful people. As a result of that, I have an elevated idea about how good everybody in the world is." - Ted Simon
My Ride Reports.
SpotWalla: WHERE IS XC RIDER!?
XC Rider is offline   Reply With Quote
Old 12-13-2013, 07:16 PM   #77
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,715
You need JD's BFH! Lay the DRZ brace over a piece of flat bar and whack on it till it submits. Though it doesn't look that bad right now. Maybe cut the bolts off shorter and find some acorn nuts at the hardware store.
Good luck, thanks for posting. I'm enjoying reading about the work on your bike.
David
'13 VFR1200D, '13 XVS950, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Mountains, Moose, and Miles: a Montanan's Alcan Highway Story
Continental Divide and More: the "No Dust" Tour of WY and MT
MTrider16 is offline   Reply With Quote
Old 12-13-2013, 07:28 PM   #78
2old2Bbold
was 2bold2getold
Oddometer: 1,732
Man, get some alloy flat stock and tig that brace back together.
2old2Bbold is offline   Reply With Quote
Old 12-14-2013, 04:54 AM   #79
dentvet
Oddometer: 1,370
I'm thinking that the front wheel is symmetrical?
In that case the spare disc could be handy in two scenarios. 1. Somehow you warp or bend the left disc on your trip 2. you are running knobbies and they get scalloped or cupped before they wear completely out.
Solution, dismount the front wheel and install it the other way.
The disc doesn't weigh more than a can of Guinness so why not drag it along as a spare?
dentvet is offline   Reply With Quote
Old 12-14-2013, 08:01 AM   #80
Kawidad
Kawidad's Avatar
Oddometer: 4,849
Or just bolt the new center piece on using the existing bolts and run it again as a fork brace.
Nice build BTW.
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 12-14-2013, 08:23 AM   #81
littlelionmonster
Rerutnevda ylranG
littlelionmonster's Avatar
Oddometer: 865
Hey Dennis. - sent you a pm about the water jet.
littlelionmonster is offline   Reply With Quote
Old 12-15-2013, 03:36 PM   #82
2fast4u
Oddometer: 747
I run both rotors on my rat Ninja and flip the wheel when the knobbies start cupping. I have 7000 miles on the tire and it is a BIG BLOCK! I do have to note it is a stock Ninja 17" wheel and the tire is a back tire, but i can't tell much if any difference no matter the direction.
2fast4u is offline   Reply With Quote
Old 12-15-2013, 08:01 PM   #83
Roadracer_Al
louder, louder, louder!
Roadracer_Al's Avatar
Oddometer: 1,605
When my wife & I did the Alaska Bucket List Trip this spring, I wanted to try Heidenaus, and of course they didn't have the right tires for her Versys, so we ran a narrower rear on her front rim.
My front tire on my front rim was thorougly worn out in less than 5k miles, but her rear-on-the-front was still good when we got home @ 8k miles.
Just don't go Darkside on us.
Suck, Squeeze, Bang, Blow
Roadracer_Al is offline   Reply With Quote
Old 12-17-2013, 12:30 PM   #84
NorthernTraveler
Long time Adventurer
NorthernTraveler's Avatar
Oddometer: 462
Minor Issues
I've got a rat Versys roughly based on JDRocks setup.
It's an '08 I picked up cheap after being crashed. Damaged/destroyed front wheel, front fender, fairing, handlebars, radiator, ignition key, tank and scrapped up right side.
It how has DRZ400 forks (shortened travel 2"), '83 KZ550 front wheel (19", 7 spoke, single rotor), super moto front fender, new radiator from eBay, KLR kickstand, saddlebag mounts, luggage rack, self made skid plate.
I did a 10,100 miles trip this summer to the west coast and back spending quite a bit of time playing in the Rockies. Had a few issues.....
1. Kickstand collapsed... at lunch one day I was lubing the chain... using the old school method of sitting on the ground next to the bike, lubing a section, rocking the bike up on the sidestand while spinning the rear wheel with my right foot to get the next section. Repeat as needed to get the whole chain. About the 3rd time I rocked it up, the kickstand collapsed at the upper bend dropping the bike upon me! Couldn't get my foot out and couldn't lift the bike up. Fortunately got somebody to help me get the bike up. So... you should strengthen the kickstand where it bends out. Take a piece of tubing the size of the tubing in the kickstand about 6" long. Slice it down one side and open it out so it's 'U' shaped. Hold it up against the kickstand beside the outward bend, mark it to cut along the centerline of the kickstand tubing. This will give you a piece kinda like a almost flat V (looking from the side) that is U shaped (looking from the top). Weld it in place.
2. The headlight mount crapped out on me while riding Skyline Trail in Utah... the middle section was deeply rutted and the bouncing side to side broke the mounts where it bolts to the frame. I welded 3/4"x1/8" flat stock from the bottom bolt up to the lower tube on both sides. Then I welded more of the same stock from the top bolt to the same place overlapping the bottom piece. On one of the top braces (I think the left side) I used one last piece to make a piece of angle iron - this helps keep it from flopping side to side. All the braces were drilled for the mounting bolts to go through. Longer bolts and washers help spread the load.
3. The stator crapped out. Started having charging problems... bike wouldn't start. Jumped it, got it going, pushed on. Replaced battery, no joy. Bought a charger, put pig tail on battery, charged at night, could start 2-3 times and run all day. Changed regulator - no joy. Made it home, opened up the side cover, top two coils on the stator were burned black. Had checked it with meter along the way, seemed OK, must be harder to check than I thought! Wonder if the stator burned because maybe not getting enough oil splashed on it with the motor rotated back. Bike now has 46k miles.
Bike was fun and fast on the road, but too top heavy on the rougher off road stuff. Rode that bike because I had a feeling I'd be on pavement more than I'd like - Versys was great on gravel and pavement, wished I'd had my DR650 or XRL on the harder stuff... but probably would have been whining on the highway.
Oh, ran Shinko 705's.... rear lasted the whole trip, front did the trip plus I've added another 2k to it with it still going.
Broke my little finger on the Overland Trail Stagecoach route in SW Wyoming... darn wet callichi clay! Had had bark busters, took them off for this trip.
NorthernTraveler is offline   Reply With Quote
Old 12-21-2013, 07:49 AM   #85
XC Rider OP
Motorcycle Vagabond
XC Rider's Avatar
Oddometer: 3,039
A little bit of a snafu....
In the above picture you're looking at the area just above the counter shaft sprocket.
End result......a very sad bike.
XC Rider
My Ride Reports.
Old 12-21-2013, 07:54 AM   #86
WayneJ
2015 LFC Mayor
WayneJ's Avatar
Oddometer: 5,782
What happened Dennis?
AMA-563452 - AW-6274 / '98 ST1100 - '01 DRZ400s
Want to help the Fox family (H14 and CampCook)? Details here.
More details here.
20% Smug Mug Credit
WayneJ is offline   Reply With Quote
Old 12-21-2013, 07:55 AM   #87
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,271
did the engine case get damaged? Hard to tell from the pic, for me anyway.
That's a shame. I know you'll get back at it right away. Hope you weren't injured. Good luck.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 12-21-2013, 07:56 AM   #88
XC Rider OP
Motorcycle Vagabond
XC Rider's Avatar
Oddometer: 3,039
A short video to show what the problem is...
XC Rider
My Ride Reports.
Old 12-21-2013, 07:58 AM   #89
XC Rider OP
Motorcycle Vagabond
XC Rider's Avatar
Oddometer: 3,039
Hard to believe, but yes, I did break off a piece from the engine case. Trying to figure out what to do at the moment. The good news is that I'm fine (just a little bruised up, but nothing a week or so wont fix). Detail account coming up shortly.
XC Rider
My Ride Reports.
Old 12-21-2013, 08:15 AM   #90
Kawidad
Kawidad's Avatar
Oddometer: 4,849
Times are GMT -7.   It's 12:47 AM.
