Old 01-04-2014, 03:10 PM   #106
XC Rider OP
Motorcycle Vagabond
XC Rider's Avatar
Oddometer: 2,941
Alright, I got what I need to repair the "spewing oil" part of the damage. Like I'd said earlier, in the crash I broke in half a small piece (oil pipe) that mounts to the crankcase, just above & in front of the counter shaft sprocket. I also broke about 50% of the boss which is the upper mounting point for this piece. Luckily I did not compromise any other part of the structure of the crankcase (at least from what I can tell, aside from the fin that acts like a guard around 30% of the counter shaft sprocket). So my plan was to put in a stud in place of where the upper mounting bolt usually screwed in, as long as I had a few threads left to properly locate the stud. Then JB weld the stud in place, and fasten the upper part of the pipe oil onto this stud with a nut.
First things first, the area in question.
In this picture you can see the jagged edge of the broken off fin that went around about 1/3 of the counter shaft sprocket. You can also see the two holes (top & bottom, to which the oil pipe delivers the oil). There's a spot in the middle as well that allows oil to flow out of or in (not sure which, not that it really matters). And then at the top you can see the broken mounting point, and the stud in place. We did a dry fit after properly cleaning up the area to make sure that the stud would be properly held in place. Lucky for me, there were about 3 or 4 full thread left which allowed to "secure" the stud in place. We fitted the pipe in place to make sure, and everything looked good. Having passed this test, I pulled out the stud, and then put some JB weld in the the threads and screwed the stud in place. I then added more JB weld over stop of the stud to hold it in place if a side force were to act on it. Here is the result.
Now to let it sit for 24 hours to let the JB weld cure to full strength. At that time we'll put the pipe oil on, test run the bike, and give it another once over to look for any other damage that we may not have noticed at this point (hopefully this will be none).
Keep your fingers crossed for me!
In the mean time I've been busying myself with route planning and making shipping arrangements. So far I've got a little over 200 place of interest waypoints plotted, and right at 10,000 miles of routes laid out. I still need to plot out waypoints for Switzerland, Austria, Germany, Denmark, Sweden, Norway, and the Netherlands. And I need to lay out routes through all of the above, plus Italy. As far as shipping arrangements are concerned, as much as I wanted to air freight the bike over, it looks like I'll have to settle for sea freight. From what I've found so far, air freighting is just too damn expensive! If you know someone, who knows someone can help me out in that regard, let me know!
XC Rider
"Motorcycles have put me in touch with wonderful people. As a result of that, I have an elevated idea about how good everybody in the world is." - Ted Simon
My Ride Reports.
SpotWalla: WHERE IS XC RIDER!?
XC Rider is offline   Reply With Quote
Old 01-05-2014, 04:02 PM   #107
XC Rider OP
Motorcycle Vagabond
XC Rider's Avatar
Oddometer: 2,941
Got the bike buttoned back up today, ran it, and no oil came spewing out from anywhere!
Now to figure out what to do about this little void...
Option 1: OEM headlight assembly & trim.
Pro: No fabrication needed, plug 'N play, fills the void perfectly.
Con: $274.00! I've looked, but so far no luck finding one used or salvage.
Option 2: Hayabusa headlight
Pro: Haven't seen one in person, but it appears to be a similar shape. Twin bulb for low & high beam.
Con: May have to do some fab work to mount it and make it blend in.
Option 3: Buell headlight.
Pro: I like the look of twin head lights, side by side.
Con: Definite fab work require to mount and make it blend in with the lines of the bike.
Option 4: Dominator headlight.
Pros & Cons: Just about the same as the Buell headlight.
Option 5: Moose species headlight.
Pro: Cheap.
Con: Will more than likely need fab work to mount and blend. I'm concerned about the amount of light this light will put out.
Option 6: Random chopper headlight.
Pro: Cheap, and approximately the right size to fill most of the space.
Con: I'm not sure, but I think it uses a single bulb (dual filament) in order to achieve low beam & high beam.
I will also be mounting on the bike this pair of auxiliary LED lights (Cree 3 Led light, model 30 I think).
XC Rider
My Ride Reports.
Old 01-05-2014, 05:31 PM   #108
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,231
I am a fan of Buell/Dom.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 01-05-2014, 06:20 PM   #109
MTrider16
Ridin' in MT
MTrider16's Avatar
Oddometer: 1,668
Since you have the Advmonsters, I like the stacked look the best.
This guy is also working on a an aftermarket stack design for the 990 Ktm.
http://www.advrider.com/forums/showthread.php?t=933485
'13 VFR1200D, '13 XVS950, '09 F800GS, 07 CRF250X
Riding roads in Montana - Big Sky Country
www.mtrider16.smugmug.com
Mountains, Moose, and Miles: a Montanan's Alcan Highway Story
Continental Divide and More: the "No Dust" Tour of WY and MT
MTrider16 is online now   Reply With Quote
Old 01-06-2014, 05:11 AM   #110
JaxObsessed
RushMoran....... :D
JaxObsessed's Avatar
Location: From Alabama to Newfoundland it's all Appalachian
Oddometer: 13,135
Denis, I have an ADVmonster faring and led headlight setup on the way to my porch for my GS front end. It looks awesome, can't wait to get it on my bike.
If you didn't know, I'm putting a complete YZ front end on my 650 with the ADVmonster faring.
The yz mod is tried and true... it bolts right up using the yamy berings and the bmw races. No fabrication needed.
a photo of the faring on a crf
I ordered a black one with turn signals.
ADVers are out of control and that's their charm, they don't line up, they don't have standards they follow, each and every one does their own thing. They know how to ride free - BugSister.
Jax mediocre photo thread
20% Smugmug discount coupon
JaxObsessed is offline   Reply With Quote
Old 01-06-2014, 08:48 AM   #111
XC Rider OP
Motorcycle Vagabond
XC Rider's Avatar
Oddometer: 2,941
Sounds awesome Jack! What lights are you putting in the fairing for high beam & low beam?
XC Rider
My Ride Reports.
Old 01-06-2014, 04:47 PM   #112
JaxObsessed
RushMoran....... :D
Oddometer: 13,135
Quoting the entire post for the ironic irony.
I PMed 4 play (after seeing this post in your thread) cause I really liked the faring on his bike...
I am using the same setup as 4Play.
2X
Model 60 LED off road flood light
See detailed description for pictures of the light pattern.
30 degree Beam
3600 lumens
Cree XM-L U2 LEDs
2.4 amps (28 watts) @12v
aluminum housing
Length: 70mm , Diameter 55mm
Black durable coating
o-ring sealed housing
one meter wire lead
includes flat mount mounting option - (stainless)
shatter resistant lens
Sold Individually
sanjoh (ADVmonster guy) added a dimmer for the low beam that is overridden when you switch on the high beam. On high both lights are full on. Described as brighter than the sun.
even on high, it uses way less juice than my stock 55wx2
Originally Posted by 4play View Post
All motorcycles are a compromise in one area or another. What those of us that build these are doing is taking advantage of an excellent engine/gearbox & shifting the compromises closer to our needs.
Front wheel, never heard of ANYONE having an non collision issue although Dave gave me a head start with a spoked 21".
As far as a single disc, the 320mm rotor on mine is the same as the 100hp KTM 950SE comes with stock & I don't hear anyone complain about those? Mine stops well, no it's not a dual disc street bike setup again compromise, but it works very well.
R1 shock, I don't think I've ever owned a dual sport bike that I didn't have re sprung & re valved. Mine was re valved by Pete Russel of Nost & works better than a stock KTM Adventure which is arguably the best offroad capable Adventure bike you can buy. My total cost including spring & modified valving was $220. That's why people fool with it. Perfect? No, perfect would have a larger piston & more cooling area.
I've ridden with DR650's, 950KTM SE's & Adventures, XR650R's. L's & KTM690's. The bottomless low speed sand was the only place I lusted after one of the singles. High speed sand, no worries. One ride in particular myself & a DR slabbed it back to Phx from Benson. I can run 85mph all day comfortably, his DR was hating life, again compromise...
These are never going to be dirtbikes, but they do make very capable offroad Adventure bikes vs a stock Versys being compromised for cost & compromised for street use.
components.
My compromise is a two up capable street bike that can explore the endless trails of AZ without hurting itself or me, I do have a real dirt bike for the really tight nasty stuff. I like the bike well enough to be considering building a KLRsys style frame specifically for my
Old 01-06-2014, 04:53 PM   #113
JaxObsessed
RushMoran....... :D
Oddometer: 13,135
Thank you 4Play!
Mentioning your actual name saved me significant bucks.
Old 01-06-2014, 09:17 PM   #114
XC Rider OP
Motorcycle Vagabond
XC Rider's Avatar
Oddometer: 2,941
2X
Thanks for confirming my suspicions. I may have to PM Sanjoh just to see what a setup similar to this would cost me.
XC Rider
My Ride Reports.
Old 01-08-2014, 05:53 AM   #115
JaxObsessed
RushMoran....... :D
Oddometer: 13,135
Old 01-08-2014, 08:52 AM   #116
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 4,924
Looks nice, spring is just around the corner
Old 01-08-2014, 09:02 AM   #117
JaxObsessed
RushMoran....... :D
Oddometer: 13,135
Looks AWESOME~!!!!! IMO
Thanks sanjoh!!!
Old 01-08-2014, 03:57 PM   #118
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 8,989
Looks fine. I was just hoping that you wouldn't go with the Moose unit.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is online now   Reply With Quote
Old 03-01-2014, 11:42 AM   #119
XC Rider OP
Motorcycle Vagabond
XC Rider's Avatar
Oddometer: 2,941
UPDATE!!!
After a brief hiatus, due to work obligations, I have finally got the bike fully back together again and ready to be put on the road! I just completed the install of my new headlight. Here we go!
So we had last left off with the fix on the broken mount for one of the oil pipes near the counter shaft sprocket. What remained was taking care of the busted up headlight. I thought about putting in a new OEM light, but I figured if it broke that easily, I'd hate for it to happen again. I also figured that this would be another way for me to make the bike my own, and different from all others. So in the end here's what I ended up using.
Low Beam: Hella 90mm DE Series
High Beam: Also a Hella 90mm
From what I've read, Hella lights have a good reputation, they use an H9 bulb which will be easier for me to source in Europe if need be, and the light output ought to be better than stock. Now the only issue that remained was that I would need to fabricate a mount and headlight bucket for these babies!
XC Rider
My Ride Reports.
Old 03-01-2014, 12:00 PM   #120
XC Rider OP
Motorcycle Vagabond
XC Rider's Avatar
Oddometer: 2,941
So the lights came in; here they are with a typical flash drive for size comparison. High beam on the left, low beam on the right.
And I had to make them fit nicely in here...
First a couple of base plates coming off the stock mounting points for the OEM headlight assembly...
And a quick mock up of the headlight bucket, and how the lights would fit in the opening...
All of what you see above happened in December and early January. Then I got super busy at work and was not able to do a single thing on the bike until last week. With the rush of needing to get the bike buttoned up so that it can ship out to Europe end of March, I really didn't remember to take pictures as I went. But, here are the end result pictures.
Headlight bucket completed with lights mounted in place (mounting the lights was a little bit of a PITA as you have to first install some "bushings" in the bucket, then mount the set screws on the lights themselves and then press the set screws into the pre-mentioned bushings. And of course all those little parts are made of plastic! To say the least it was a bit nerve racking, being careful not to break any of the plastic bits. Luckily I had done my research ahead of time and had a good plan of attack. I'm happy to report that all went successfully.)
And now, mounted in the bike!
Two things left to do with the lights now:
1) Wait for the sun to set so that I can aim the lifts properly, and 2) fit a lexan light protector over top or purchase some of that plastic film headlight protector.
I can't wait to get this thing back out on the road!
XC Rider
My Ride Reports.
Times are GMT -7.   It's 04:14 PM.
