Old 12-27-2013, 10:47 AM   #16
TwinDuro
Befuddled Adventurer
TwinDuro's Avatar
Oddometer: 318
That's a good lookin' spring, an Eibach to boot! I love the location of the Seahorse case. There's nothing worse IMHO, when a repair/adjustment needs to be made, then having to dig for a tool kit at the bottom of a saddlebag or pannier.
One thing I've always wondered about the XT350 is why Yamaha went with a 428H chain instead of a 520. The 428H is surely strong enough, but it makes a guy wonder...
"Remember, you may have to grow old, but you don't have to mature." - Red Green
TwinDuro is offline   Reply With Quote
Old 12-27-2013, 11:47 AM   #17
NortwestRider OP
TRIPOD ADVENTURER !!
NortwestRider's Avatar
Oddometer: 3,895
520 conversion has been ordered!!.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
GS500ADV..THE PURPLE EXPLORE
[B
NortwestRider is offline   Reply With Quote
Old 12-27-2013, 12:04 PM   #18
gearheadE30
gearheadE30's Avatar
Oddometer: 873
What ratio are you running? I ended up with 16/45 on my conversion which puts me at 6k revs at 70 mph fwiw.
Are you going to do a fork swap or anything on the front? If not, I ended up putting 20wt fork oil in along with ~1.5" spacers and it made a massive difference. the forks still deflect a lot, though.
I highly recommend a manual timing chain tensioner, as I've had 2 stock auto tensioners fail on mine now. The auto tensioners also appear to over-tension the chain from what I've seen.
I've used mine as a similar overland-type bike and it does really well. Cycleracks rear rack is great, as is a Clarke 4 gallon tank. I get about 55-60 mpg on mine.
I don't know what your riding conditions are going to be like, but if you can relocate the battery, the TT350 airbox is a good upgrade because the air filter is much larger and seals better than the panel filter in the XT. The TT also flows a lot more air, allowing for raised needles and different jetting.
2005.5 KTM 950 Adventure and 2012 KTM 200 XC-W
1991 BMW 318is turbo track car
1989 Chevrolet Caprice Classic Wagon sleeper tow car
1992 Subaru SVX daily
3 Months Exploring the US on a 950
gearheadE30 is offline   Reply With Quote
Old 12-27-2013, 12:05 PM   #19
gearheadE30
Oddometer: 873
Originally Posted by NortwestRider View Post
Got my new rear spring today, took about 3 weeks to get.
What rate did you get?
Old 12-27-2013, 12:23 PM   #20
NortwestRider OP
Oddometer: 3,895
I might do a TT fork swap if I can find it cheap. I will have to go look up what ratio I went with,can't remember .I went with a 700lb spring ,I couldn't find out what stock was but read on this thread that another big boy got a 750lb for his and it was a little to stiff.I 'm going to do mostly off-road touring at first,mostly dirt /gravel roads with some 2 track and single track.Hopefuly someday this will be my RTW bike .
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 12-27-2013, 12:29 PM   #21
NortwestRider OP
Oddometer: 3,895
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 12-28-2013, 04:10 PM   #22
NortwestRider OP
Oddometer: 3,895
Put the new spring on the shock today.
Mounted my new tank panniers I got for Christmas.
I needed a spark arrester since the PO removed the stock one,I'm the KING of CHEAP so instead if buying a stock insert ( $100 ) I built one.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 12-28-2013, 06:22 PM   #23
NortwestRider OP
Oddometer: 3,895
The finished product. !!
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 01-01-2014, 07:21 PM   #24
NortwestRider OP
Oddometer: 3,895
Got a high lift bike lift today, man it makes working on the bike easy.
Also built a rear rack to hold my KOLPIN 1.5 gallon gas can.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 01-01-2014, 07:46 PM   #25
L.B.S.
Oddometer: 1,320
Niiiice
:jealous:
Project looking good, NWR
L.B.S. is offline   Reply With Quote
Old 01-01-2014, 08:09 PM   #26
NortwestRider OP
Oddometer: 3,895
$225 lift was $145 today. !!.
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 01-01-2014, 09:06 PM   #27
Outwardbound
Oddometer: 688
Where ?
Outwardbound is offline   Reply With Quote
Old 01-01-2014, 09:10 PM   #28
NortwestRider OP
Oddometer: 3,895
Harbor frieght BUT it was a 1 day 25% off coupon.The lift is on sale for $184 without the coupon .
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 01-04-2014, 06:17 PM   #29
NortwestRider OP
Oddometer: 3,895
Well I spent a good 5 hours out in the shed at 40 degrees and got my pannier racks 90% built.I still need to make the bars that go from the racks to the frame where the pass pegs were.
And YES that is a clubman handle bar bracing the the 2 sides in the back..it had the right bend I was looking for and I was never going to use the bars anyway.
And it is with panniers on .
2012 Honda NC700XAR
1994 KTM440 exc
1983 IT490
[B
Old 01-04-2014, 07:54 PM   #30
Ginger Beard
I have no soul
Ginger Beard's Avatar
Oddometer: 6,501
This is a great build thread, really enjoying it!!
"I have great faith in fools; self-confidence my friends call it." ~Edgar Allen Poe~
My Scramster Build
3 weeks solo: Overland Expo East ,Barber Vintage Fest and beyond
Ginger Beard is online now   Reply With Quote
Times are GMT -7.   It's 09:58 AM.
