Old 12-22-2013, 02:26 PM   #76
Randy
Randy's Avatar
Oddometer: 2,449
Originally Posted by 1stiski View Post
Also painted the headers with 2000 heat coat., now to let dry for 24 hours then bake to cure in the oven at 250 degrees for 20 minutes, then they are ready
Ummm... With all the painting you've done I'm sure you already know this but...
If you're going to bake it in the kitchen oven, you better make sure the wife is gonna be gone for awhile.... I've baked lots of painted parts in the oven, and no matter how long you let it air cure, the heat of the oven still drives off more volatiles... and stinks up not only the oven, but the whole house if not careful. A box fan blowing out keeps the fumes in the house down though, unless it's too cold out. But, I've also had the experience where it made the next meal cooked in the oven taste a little "off"...
"Ummm... I don't know honey... Yeah, it does taste a little weird.... Ummm, think maybe it's a little old?"
That little experience taught me to run the oven on the self cleaning cycle after baking paint...
That's why she needs to be gone for a good long while...
Like I said, you probably already allowed for this, but just in case...
Don't wanna to spoil the Christmas turkey....
"some might call it a 'midlife crisis', I prefer to call it a renaissance of thought and action"... "Life is too short to do anything other than that about which you are absolutely passionate."..."Adventure is a frame of mind, set upon by action, not defined by equipment."..."It all boils down to your ability to say "SCREW IT" and really mean it"....Randy
Randy is offline   Reply With Quote
Old 12-22-2013, 02:33 PM   #77
1stiski OP
Ride that nasty thing
1stiski's Avatar
Oddometer: 1,671
LOL , yeah that would not be good . I do have access to an oven that's outdoors at a camp under a shelter , I may go that route . Just to be safe .
2015 BMW R1200RT 600 miles
2003 Harley XL883 CAFE
1stiski is offline   Reply With Quote
Old 12-23-2013, 03:39 PM   #78
1stiski OP
1stiski's Avatar
Oddometer: 1,671
Today, worked on getting my wiring in order. Have to make a special mount for the resistors that are needed for the LED signals to operate properly. Took off the gas tank to make life easer while doing this part. I've got some ideas I need to toss around before I decide on a final solution.
1stiski screwed with this post 12-24-2013 at 05:04 AM
Old 12-24-2013, 02:01 PM   #79
1stiski OP
1stiski's Avatar
Oddometer: 1,671
Today, finished up with the part of the new wiring harness that goes under the tank. Zip tied and put the tank back on and also remounted the rear wheel tire and put it back on.
Taking shape, like the stance
Old 12-24-2013, 02:59 PM   #80
schnutzy
schnutzy's Avatar
Oddometer: 403
now this is a harley i could see myself buying.
"While it may be to early to drink scotch, it is never to early to think about drinking scotch."
2012 Suzuki TU250x
schnutzy is offline   Reply With Quote
Old 12-24-2013, 03:22 PM   #81
1stiski OP
1stiski's Avatar
Oddometer: 1,671
Looking forward to see how the color matched tail and faring all chime into the look .
Old 12-24-2013, 03:58 PM   #82
Randy
Randy's Avatar
Oddometer: 2,449
Looking good!
When ya gettin' the bodywork back? And, just out of curiosity, 'bout what's the paint work gonna run?
Looking forward to seeing this thing finished, and hearing your review of the overall package, comfort, etc...
Old 12-25-2013, 05:40 AM   #83
1stiski OP
1stiski's Avatar
Oddometer: 1,671
Looking good!
Well since the fairing is plastic and the cowl is fiberglass gel coat, they each require some different prep. I'm guessing between $200-400 for the job. I'll post up once I get notification they are done. Should have em done by next week.
Old 12-25-2013, 07:27 AM   #84
B02S4
Aye
B02S4's Avatar
Oddometer: 1,123
Did you clearcoat the polished portion of the wheels?
B02S4 is offline   Reply With Quote
Old 12-25-2013, 08:04 AM   #85
1stiski OP
1stiski's Avatar
Oddometer: 1,671
The wheels from the factory were never clear-coated. I actually like that they weren't. It made it easy to do the re-do. I'll keep them this way without going the clear-coated option because I would rather have to polish them on occasion than have to deal with any oxidation that starts under a clear coat. Makes life easier.
Old 12-26-2013, 04:18 PM   #86
1stiski OP
1stiski's Avatar
Oddometer: 1,671
Worked on my resistor array for the LED turn signals. Made a plate, and mounted up the resistors, then utilized a nice tab on top of the oil tank to mount. Couldn't ask for a better location. Soldered the ends in the proper places.
Keen eyes will note my dyslexia kicking in. Left and Right resistors switched, LOL,, Yeah, left is right, right is left..
TA DA. Signals work, this is the four-ways flashing
Fitment of the left side rear sets and shifter.
1stiski screwed with this post 12-26-2013 at 04:26 PM
Old 12-29-2013, 02:09 PM   #87
1stiski OP
1stiski's Avatar
Oddometer: 1,671
Not a whole lot of progress today. But did manage to mount up the right side rear-sets / brake slave / footpegs.
Old 12-29-2013, 09:15 PM   #88
jiml53
jiml53's Avatar
Oddometer: 14
Lookin good
It's coming along nicely. Have you thought about trimming down the cam cover? Just a thought.
Jim
13 Super Tenere, 14 FLHXS, 02 FXDXT, 85 FXRC and 88 R100RS
jiml53 is offline   Reply With Quote
Old 12-30-2013, 02:30 AM   #89
1stiski OP
1stiski's Avatar
Oddometer: 1,671
Jim
cam? Rocker Box cover . Nope .
Old 12-30-2013, 07:04 AM   #90
Hughlysses
Hughlysses's Avatar
Oddometer: 3,433
He's talking about trimming down the cam cover similar to this:
2007 Buell XB12X Ulysses
1983 Honda VT500FT Ascot
Hughlysses is offline   Reply With Quote
Times are GMT -7.   It's 10:18 PM.
