Old 03-14-2014, 11:28 AM   #31
ktm_dakar
Oddometer: 74
Check out the 2014 Blais Racing Services Team Posters! Looking forward to an awesome season.
ktm_dakar is offline   Reply With Quote
Old 03-24-2014, 07:26 PM   #32
ktm_dakar
Oddometer: 74
http://vimeo.com/89960822
Awesome video of the Youth National Hare and Hound at NHHA Round 3 in Idaho this past weekend. Blais Racing's Cole Timboe would take the PeeWee Class win and Braydon Bland would finish 2nd Overall in the Super Mini Class. Great Job Guys!
Old 03-26-2014, 12:31 PM   #33
ktm_dakar
Oddometer: 74
Blais Racing 2008-2011 KTM 400/450/530 XC-W/EXC, 2009-2010 Husaberg FE390, 450,570, FX450 Aluminum Oil Pump Gears
These gears are modeled after the upgraded 2011 KTM Gears. Never have a failure again. They only fit XC-W/ EXC KTM Models. Does not fit XCF/SXF models!
I have seen way too many of the stock plastic gears fail in these engines and decided to have these made. They have been tested in my team race bikes and freinds bikes for over a year without any issues.
Problem with the plastic gears is if you run low on oil at one time the oil pumps start to seize up and then the large gear is stripped out where it meets the clutch basket. Once it strips out your engine will run without any oil pumping until the crank, piston, and cylinder is destroyed. With these gears you will at least get signs and notice your engine slowing before it is completely destroyed.
This kit comes with large and small gears along with a new clutch cover gasket for additional cost if needed and instructions. You do need to have good mechanical knowledge to install these gears.
Gasket option is only for KTM Models.
This is what happens when your KTM 450/530 EXC/XCW Oil Pump Gear Fails. Not to mention the crank is gone too causing this top end damage. Normally about $2500 in repairs. Fix the issue before it happens! $89.95.
http://blaisracingservices.com/ktm/k...ump-gears.html
Old 05-09-2014, 05:57 PM   #34
ktm_dakar
Oddometer: 74
Check out our youth riders race reports from National Hare and Hound Round 6! Cole Timboe PeeWee rider and Braydon Bland Super Mini point of view.
http://blaisracingservices.com/blais...-round-6-.html
Old 05-09-2014, 06:01 PM   #35
ktm_dakar
Oddometer: 74
Braydon Blands helmet cam footage from NHHA Round 6. He had a great Battle with Super Mini champ Jarrett Megla!
Old 05-09-2014, 06:03 PM   #36
ktm_dakar
Oddometer: 74
Some NHHA Round 6 helmet cam footage from Ben Meza and Brendan Crow! Check it out! Dead engine start with 100+ riders at one time into the sand dunes at Little Sahara OHV.
Old 05-19-2014, 05:10 PM   #37
ktm_dakar
Oddometer: 74
Sweet edit featuring Blais Racing's Skyler Howes on his KTM 300XC Race Bike!
Old 05-19-2014, 05:15 PM   #38
ktm_dakar
Oddometer: 74
Samco Orange Silicone Radiator hose kit for your 2012-2014 KTM 450/500 EXC/XC-W. This kit eliminates the thermostat for extra coolant flow and cleans up the look of you bike. Always in stock!
http://blaisracingservices.com/samco...at-bypass.html
Old 05-19-2014, 06:09 PM   #39
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,329
I just dropped a Blais Racing jetting kit into my 530 after coming back from Baja. The Blais Jet kit replaced the JD one that I put in there initially. All I can say is that the Blais jetting is much better than the already good JD jetting. It's much crisper, the throttle is snappier off the bottom and seems to pull a bit more on top.
Two thumbs up for a quality kit. Thanks
Yellow Pig is online now   Reply With Quote
Old 05-20-2014, 11:56 AM   #40
ktm_dakar
Oddometer: 74
Thanks for the great feedback. A lot of time and testing went into that jetting kit. It's pretty much perfect. http://blaisracingservices.com/ktm/k...tting-kit.html
We also have kits for the RFS bikes, 450/505 SXF/XCF, & 07-10 250 XCF/SXF models.
Old 05-25-2014, 09:01 AM   #41
bpeterson
I just tweeted it
bpeterson's Avatar
Oddometer: 1,030
Question - If I install the Samco hoses, do I also need to install the thermostat eliminator ($9.95 part?). Bike is a 2014 350-exc-f
also, any need to the additional radiator fan as well, to keep the bike running cooler?
thanks in advance,
Brian
'14 KTM 350 EXC-F
'04 GS Adv
'02 DR-Z 400S - for sale soon
'06 TE 610 - sold
bpeterson is offline   Reply With Quote
Old 05-26-2014, 12:28 PM   #42
ktm_dakar
Oddometer: 74
thanks in advance,
All you need is the hose kit to direct the flow better and more efficient. You can run the stock fan setup still as it doesn't affect that at all. The Eliminator washer was designed a long time ago before the hoses came around to be able to remove the thermostat from the housing in case it failed. Be sure to use advrider discount code for an additional 5% off. Thanks!
Old 05-26-2014, 12:35 PM   #43
ktm_dakar
Oddometer: 74
JD Jetting Fuel Injection Tuners, Power Surge 6X for 2012-2014 KTM 500 EXC/ XCW. Part Number JDKTX07. This programmer is preset to run perfect with the stock exhaust and screw in endcap removed. The push of a few buttons and you can adjust your bike for an aftermarket exhaust. Keep your bike running longer and cooler with the added fuel it needs. In stock! $204.95. Use advrider coupon code for an additional 5% off.
http://blaisracingservices.com/ktm/ktm-4-stroke-parts/ktm-motor/drive-line/jd-jetting-fuel-injection-tuner-2012-2014-ktm-500-exc/-xcw.html
Old 05-26-2014, 01:14 PM   #44
bpeterson
I just tweeted it
bpeterson's Avatar
Oddometer: 1,030
Cool, thanks! And thanks for the discount.
Brian
'14 KTM 350 EXC-F
'04 GS Adv
'06 TE 610 - sold
Old 06-16-2014, 11:34 AM   #45
ktm_dakar
Oddometer: 74
Blais Racing's Braydon Bland takes the Super Mini Win in Monticello, Utah! Check out his race report!
http://blaisracingservices.com/wp/br...in-monticello/
Times are GMT -7.   It's 05:40 PM.
