Old 12-06-2013, 06:22 PM   #1
phillyrube OP
Oddometer: 1,239
Reasons to Buy a Sportster.....
and not a Twin Cam:
http://www.jamesrussellpublishing.bi...buyharley.html
phillyrube is online now   Reply With Quote
Old 12-06-2013, 06:35 PM   #2
JerryH
Oddometer: 5,069
That article has been around for a while, and as far as I can tell from my own research, it give a pretty accurate description of the Twin Cam, one of Harley's biggest mistakes (until this new "Street" series)
But as far as reasons to buy a Sportster, at least a used Sportster, there are plenty. You can get the unique Harley riding experience, the feel and the sound, for a very low price. And it is a good solid bike, lasts a long time, and can be modded and repaired. Unlike Japanese bikes, plenty of parts are available for it. They also hold their value pretty well. If you buy a $4500 used Sportster, and take good care of it, it probably won't depreciate much over the years.
JerryH is offline   Reply With Quote
Old 12-06-2013, 06:40 PM   #3
phillyrube OP
Oddometer: 1,239
And here are the reasons why NOT to buy a Japanese, German, British, Italian, Chinese, Croation, ad nauseum...
http://www.jamesrussellpublishing.biz/whynojapbike.html
Old 12-06-2013, 07:04 PM   #4
JerryH
Oddometer: 5,069
There are some inaccuracies in that, but not that many. I have always hated the term "powersports" dealer. The ones that use that term are the most likely to sell several brands, and are also the ones most likely to rip you off. But Harley and Victory dealers will rip you off as well. One of the biggest problems, especially with Japanese bike manufacturers is they constantly change things. They routinely drop models and come out with new ones. That is definitely not good for the customer. And along with that comes a lack of parts for models more than 10 years old.
You can get parts for pretty much any Harley, but they don't come from H-D, they come from the aftermarket. H-D owners are lucky to have a HUGE aftermarket.
As for Victory, they may be an American company, but they have adopted the Japanese way of doing things. Again, constant changes and lack of parts availability. I really like the original V92C, but would not buy one, because parts are no longer available for it.
There are rare exceptions. I own a Japanese motorcycle that was made and sold from 1985 through 2006 with no changes but paint colors. Mine is an '02, but I can get parts for it through 2016, because the '06 models are the same and use the same parts.
Whoever wrote that is obviously an American bike aficionado, but even Harley is starting to copy the Japanese methods of design and manufacturing. That's where the Twin Cam, V-Rod, and the new Street came from. So it seems the Sportster is still the only original style Harley left, and I am expecting them to downgrade that pretty much any time.
Old 12-06-2013, 07:09 PM   #5
JerryH
Oddometer: 5,069
Originally Posted by hexnut View Post
JerryH, the man with the most expertise in all things Harley not to have ever owned one. Just freakin wow.
Everything I have ever posted about Harley is common knowledge. There is tons of information out there about every brand of motorcycle that has ever existed. That is one neat thing about the internet. Knowledge is now available to everyone.
Old 12-06-2013, 07:16 PM   #6
DAKEZ
DAKEZ's Avatar
Oddometer: 19,719
Outdated Victory Propaganda Ranks right up there with EVERY BMW Final Drive after 2005 is going to catch fire and burn your bike down.
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ is offline   Reply With Quote
Old 12-06-2013, 07:22 PM   #7
wrecked'em
satisfied enzyte user
Oddometer: 447
victory propaganda? he says over and over again to buy a sportster. but im sure you will tell us what defects Harleys have.
tiger 1050
wrecked'em is offline   Reply With Quote
Old 12-06-2013, 08:03 PM   #8
woodnbow
woodnbow's Avatar
Oddometer: 1,683
Duh, Twin Cams are better than the Evo single cam, therefore four cams are just that much better... All true Harley riders know this!
HD just needs to stretch the sporty frame, mount a wideglide with fairing on the front end and bags on the rear and then bore and stroke the old 4Cam to 100" or so. Boom!
woodnbow is offline   Reply With Quote
Old 12-06-2013, 08:24 PM   #9
Birdmove
Birdmove's Avatar
Oddometer: 1,740
I have not read that article, but to me, the Sportster is HD's best motorcycle. The pre-2004 XLs were rigid motor mounts and quite a bit lighter. The 2004 and later have rubber engine mounts, and are smoother, but much heavier. The earlier had a trap door transmission. The newer ones you must split the cases to access the trans. I have owned 2 Sportsters. A 1984 XLX 1000 and a 2006 XL883. Both were good bikes. I prefer a Sportster with longer shocks and fork tubes like my 2006 XL883. The XL883R and XL1200R were favorites due to better cornering clearance of the longer suspension, and a dual front brake disk set up. Also the XL1200S was a keeper.
The Sportsters come with gear driven camshafts. Twin Cam owners pay a pot full of money to have the chain driven cams with 2 chains and 2 tensioners converted to gear drive.
Sportsters are currently the lightest HDs, but are still heavy enough for good stability on a freeway in my opinion.
Hydraulic valve lifters are a feature of all current HDs, meaning no valve adjustments needed.
My 1984 averaged 66 miles per US gallon. My 2006 XL883 could return 65 mpg on longer rides if I too back highways and stayed off the freeways.
My personal opinion is that a Sportster, with the peanut tank, is about as good looking as a motorcycle gets. But I also love the 2007 Royal Enfield Bullet, and the early Triumph Bonnevilles (the Meridan Triumph- not the "new" Triumph).
I consider an 800 pound behemoth to be a land barge and not a motorcycle. Hence I am a Sportster fan and not a fan of HD big twins. I once dropped my 2006 XL883 in a parking mishap. It ended up laying with the top of the bike lower than the bottom due to an incline. At 58, I was able to pick it upright by myself with no help. Try that with an FL model.
MY Sportsters were both able to corner nicely on twisty roads. No, they were not sportsbikes, but I had fun in the corners with both. I believe it was a mistake for HD to drop all the Sportsters with decent cornering clearance and go to ALL lowered models.
These are my opinions, and as long as a person is happy with whatever they ride, then good for them. For me, an XL883 has enough power to keep a big grin on my ugly face, and I may well buy another used one soon.
Jon in Keaau, Hi. USA
2008 SYM HD200 (wife's ride)
2009 Kymco People 150 and coming soon, another dual sport mc
Birdmove is offline   Reply With Quote
Old 12-06-2013, 08:39 PM   #10
ShardPhoenix
Наглый ублюдок
ShardPhoenix's Avatar
Oddometer: 871
You've heard it here ladies and gentleman, with the power of the interwebs at your fingertips you can now become an expert on everything, despite having no real experience.
I'm going to go read up on brain surgery and sign up for a medical practitioner's website to give advice on the removal of brain tumors.
I ride 652ccs of slug.
ShardPhoenix is offline   Reply With Quote
Old 12-06-2013, 09:28 PM   #11
kag
Wander Lust
kag's Avatar
Oddometer: 1,687
Never been a huge fan of the 883.....only reason to own one is so you can trade it in this coming spring. Actually the wife learned to ride on her 883, put 4k on it and traded it for a triumph.
The 1200 though is a different story.....fun bike
“Always drink upstream from the herd”
2007 Yamaha TW 200 / 2008 Buell Ulysses
2013 Triumph Tiger 800r / 2014 KTM 1190 EDS
kag is offline   Reply With Quote
Old 12-06-2013, 09:29 PM   #12
Reduxalicious
Reduxalicious's Avatar
Oddometer: 139
1. Bought used, below NADA Value, and the bike only had 9K on the Odo
2. Bull-shit, I can pull up 6 different site's that offer all kinds of goodies for the Guzzi.
3. One of the most well-known and respected Guzzi Dealers/Mechanics in the ENTIRE COUNTRY is in my city, once again I'm good, Though I did search before actually buying one to make sure there was a dealer near me--Good point, though there are equally the same amount of Japanese dealers as Harley.
4. The Mechanic I take my bike to is excellent very down to Earth and a great guy, There's bad Mechanics for EVERY brand of EVERY vehicle out there.
5. Once again I bought used so, who knows.
6. Uh, I can still find engine parts for my 36 year old Kawasaki just as easily as I can find parts for my Harley and Guzzi, In fact the Engine on the KZ is getting rebuilt as I type, Not a very Valid point.
7. see #6, to make it a point the 2008 1200 Sport was only offered for 1 year in the US, guess what? I can still find parts galore including engine parts
8 9 & 10: Once again this is across all dealerships.
11. $150 for Oil, Shaft Oil, Transmission Oil Change + Valve check and tightening is not really what I would call Highway robbery.
12. I can find the performance parts and handlebars and seats quite easily.
13. Uhh, what?
14. Once again, I can't comment, 55 MPG at 65 MPH is good enough for me.
15. Used bike, can't comment
16. LOL WHAT?! Honda Mechanics, Harley Mechanics, Yamaha Mechanics and Kawasaki Mechanics, all could of gone to some school such as UTI and be just as inexperienced as each other.
17."No more of this dishonesty and unprofessionalism. Go back to Harley-Davidson. They don't mistreat their customers!"" Harley Davidson Forum.. That is all.
18. Yea uh--No, I haven't been mistreated yet.. In fact this Dealership taught me how to do my own Valve Adjustments and how to change the Oils on my bike. BUT DEAR GOD HE WANTS TO ROB ME OF MY MONEY!
19. Bla, Bla Political bullshit
20. Never looked into it. But odds are if my Engine detonated it would be easier and cheaper to just buy a new bike over a new engine.
21. Okay, okay--Lots of horror stories about this so, I'll give him this, only if he admits that the Harley Dealership on my end of Houston also doesn't keep things in stock and also takes weeks to get said parts.
22. Handlebars-He can get them, Extended brake lines and cables, YES SIR- they'll come off another model, Extended wires? You betcha--Even offered lower foot pegs and a lower seat! -gasps-
23. I don't plan to sell this bike so uh, yea what ever.
24. I touched on this above but, Valve adjustment on the Guzzi takes all of 30 minutes, in fact the "Money Grubbing Dealer" Showed me how to do it, as for the KZ.. that's a bit of a weekend challenge but fuck it, it's like a muscle car--Wrenching is love.
25. Once again, my Dealer showed me all kinds of different tires I can use, even got me a Center-Stand off a Norge so I could change the Rear-Tire at home. But yea, Liar and thieves and what not
26. Aprilia Mana-Bars + risers, that is all.
27. For Harley, the suspension parts are foreign made, most of the electronics are foreign made, They're as American made as my mom's Nissan, being assembled in the US and all, My Guzzi is probably a mixture of Italian/Japanese parts as well, I don't know but I wouldn't be surprised nor would I care.
28. No thank you
That is all.
For the topic at hand, 08 FXDB 35K miles and still going strong, not one thing wrong with the engine.
1977 Kawasaki KZ1000
2008 MotoGuzzi 1200 Sport
Reduxalicious screwed with this post 12-06-2013 at 09:35 PM
Reduxalicious is offline   Reply With Quote
Old 12-06-2013, 11:17 PM   #13
fallingoff
Oddometer: 3,677
13. Uhh, what?
28. No thank you
That is all.
To add
I bought a new set of higher bars for my wife's 696
From Ducati with all the extended cables and brake lines in the kit.
Same with a seat from Ducati.
Now he says shovel parts are easy to obtain.
Plain bullshit.
I have to hunt on eBay,Craig's list in the USA
To find any.
I like the sound of a hd
But better than other bikes. No.
My old bevel head at full song
Around a canyon corner
Music.
Cheers
fallingoff is offline   Reply With Quote
Old 12-07-2013, 04:23 AM   #14
Oriondk
Oddometer: 310
I had a '94 1200 for 13 years, changed the shocks and fork springs, exhaust, and air cleaner, and other than the position of the foot pegs wouldn't change any other thing about the bike. Great bike. Saw as high as 55 mpg on some slower rides.
Life's too mysterious,
Don't take it serious.
DAVE
Oriondk is offline   Reply With Quote
Old 12-07-2013, 05:15 AM   #15
kraven
Hegelian Scum
kraven's Avatar
Oddometer: 4,823
Holy grammar assassin, Batman.
I couldn't make it through paragraph 3, but I get the overall tone and mindset.
More power to them for having an opinion and expressing it. But I'm not getting dragged into a thing over this.
Yeah, the Sportster is a good bike. It's not the only one. Different strokes, mang.
So there I was walking into a biker bar in Chattanooga with liberty spikes on my head and a drag queen beside me... - bcurvin
kraven is offline   Reply With Quote
Times are GMT -7.   It's 06:43 PM.
